05-26-2015, 09:54 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: tamilnadu,india
Member: 660093 Status: Offline Sonork: 100.1602344 Thanks Meter: 277 | N7100 invalid RBMB Data write rom2(Rom2 2Mb) write rom1(Rom1 512MB) & repair Extcsd it's correct way ? |
05-27-2015, 12:03 | #2 (permalink) |
Freak Poster Join Date: Sep 2009 Location: Indonesia
Member: 1112585 Status: Offline Sonork: 100.1645028 Thanks Meter: 91 | if its Samsung EMMC, beter first reset & format then repair ExtCSD, then writes Rom2(if boot from rom2(boot1)) last Rom1. or it's hardware problem (Unknown baseband.?) |
05-27-2015, 13:49 | #3 (permalink) |
Member: 660093 Status: Offline Sonork: 100.1602344 Thanks Meter: 277 | Thank's for ur Replay ...Yesterday night i did Again repair Emmc here is the log: Code: EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB Sending Internal Reconfiguration Request... Waiting configuration Apply! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB Wiping Card... Please do not touch it! Please don't forget to repair extCSD from backup! Done. Running:SAMSUNG: MoviNAND Factory Reset... Skip loading eMMC Addon Firmware CMD Pullup Level:670 mV CMD Active Level:1062 mV Sending Smart Wipe Request... Wiping Card... Please do not touch it! Please don't forget to repair extCSD from backup! Done. extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\V3W00M_4157498717_20150402_1854.extcsd Running:Repair extCSD... Z3X EasyJtag Software ver. 2.0.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:670 mV CMD Active Level:1062 mV Writing... Done. Running:Change BOOT CONFIG... Z3X EasyJtag Software ver. 2.0.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:670 mV CMD Active Level:1062 mV Writing eMMC Register... Written: REG : 179 VAL :48 Done. Running:Change BOOT WIDTH... Z3X EasyJtag Software ver. 2.0.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:670 mV CMD Active Level:1062 mV Writing eMMC Register... Written: REG : 177 VAL :1 Done. Checking NAND Image : E:\Easy Jtag\N7100\EMMC_00000000_00200000.bin File successefuly loaded! Processing file...E:\Easy Jtag\N7100\EMMC_00000000_00200000.bin Z3X EasyJtag Software ver. 2.0.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:670 mV CMD Active Level:1062 mV Input file : E:\Easy Jtag\N7100\EMMC_00000000_00200000.bin Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 884 kB/s Checking NAND Image : E:\Easy Jtag\N7100\N7100_Rom1_Alive_Dump_BN.bin File successefuly loaded! Processing file...E:\Easy Jtag\N7100\N7100_Rom1_Alive_Dump_BN.bin Z3X EasyJtag Software ver. 2.0.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:670 mV CMD Active Level:1062 mV Input file : E:\Easy Jtag\N7100\N7100_Rom1_Alive_Dump_BN.bin Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM) Done. Write Speed: 2862 kB/s Z3X EasyJtag Software ver. 2.0.0.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0404131EE6D0E70A, ,FW Ver.: 01.52 CMD Pullup Level:742 mV CMD Active Level:2196 mV eMMC Device Information EMMC CID : 15010056335730304D00F7CE655D6028 EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 06/2013 Rev.0x0 EMMC NAME: V3W00M , S/N: 4157498717 EMMC NAME (HEX): 56335730304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.7 (MMC Unknown) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: V3W00M_4157498717_20150402_1926.extcsd Done. |
05-29-2015, 16:14 | #4 (permalink) |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Indeed your eMMC RPMB block are corrupted and there are no way to recover original data. You should replace this eMMC. However you can still use it for repair non exynos devices. EXYNOS MCU are storing important data in RPMB |
The Following User Says Thank You to NoName® For This Useful Post: |
05-30-2015, 07:36 | #5 (permalink) |
Member: 660093 Status: Offline Sonork: 100.1602344 Thanks Meter: 277 | It's there anyway to Recover Phone old Condition ? Because before phone was worked just showing Unknown baseband only ......what is the procdure to write Rom via Emmc on this phone ? |
05-31-2015, 17:37 | #7 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: PAKISTAN
Member: 585807 Status: Offline Thanks Meter: 781 | Quote:
then repair and write rom 1 and rom 2 .i hope your problem solved ..... rpmb 128 kb set.................... | |
06-01-2015, 09:12 | #9 (permalink) | |
i solved this problem many time.............. | |
06-17-2015, 17:17 | #10 (permalink) |
Product Supporter Join Date: Jul 2010 Location: MobilesFactory,trichy,TN,India Age: 33
Member: 1347585 Status: Offline Sonork: 100.1596390 Thanks Meter: 467 | Hi drjaved_akhter same problem after repair and format & Rom2 and Rom 1 .. In Download mode not Show the Rpmb data error after flash back to blinking ... in dl shows the rpmb error ... mobile history is after update blinking (wrong pit file or wrong flash by customer ) |
06-17-2015, 20:22 | #11 (permalink) | |
