09-20-2013, 08:14 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Age: 44
Member: 129486 Status: Offline Thanks Meter: 66 | N7100 repair done but http://forum.gsmhosting.com/vbb/f672...e-but-1699774/ EasyJtag Suite ver.: 1.0.67.0 started. Operating system ver.: Windows 7 (build 7600). Successefuly connected to box on COM32 Box S/N: , ,FW Ver.: 01.47 Box Working Mode: JTAG Box. Box Drivers version: 3.0.0.0, are OK Active Reader Channel : 00200000 Card AttrCardATR : 3B7D95000080318065B0831148C883009000 Card AttrVendorName : Z3X Team Card AttrSysName : Z Card AttrVendorSerial : 2012-003 Card AttrICCType : ISO7816A Z3X Card Serial : A Z3X Card Version : 22 Z3X Card Activation [JTAG] : 1 Resources ver. : MainRC ver.OCD040Z001 (C)2012 z3x-team.com Successefuly connected to box on COM32 Box S/N: , ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:1608 mV CMD Active Level:2310 mV EMMC CID 15010056545530304D005F9626045FA1 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufactorer ID: 15 EMMC OEM ID: 0100 EMMC Date: 05/2012 FW rev.0x0 HW rev.0x0 EMMC Serial #: 1603675652 EMMC NAME: VTU00M EMMC Capacity: 15028 MB (High Density Card) ============================================= Extended CSD rev 1.6 (MMC 4.5) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x3f] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x04] Tag Resources Size [TAG_RES_SIZE: 0x00] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 65536 KiB Background operations status [BKOPS_STATUS: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x10] Access size [ACC_SIZE: 0x07] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x50] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x01d5a000] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x02] I/O Driver Strength [DRIVER_STRENGTH: 0x00] Card Type [CARD_TYPE: 0x07] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x48] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x01] High-density erase group definition [ERASE_GROUP_DEF: 0x00] ============================================= Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked ============================================= User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x01 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000bb Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00 Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be Released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status[EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 Writing file...E:\EasyJtag\N7100\N7100_Rom2_Alive_Boot_BN. bin Successefuly connected to box on COM32 Box S/N: , ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:1598 mV CMD Active Level:2320 mV EMMC CID 15010056545530304D005F9626045FA1 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufactorer ID: 15 EMMC OEM ID: 0100 EMMC Date: 05/2012 FW rev.0x0 HW rev.0x0 EMMC Serial #: 1603675652 EMMC NAME: VTU00M EMMC Capacity: 15028 MB (High Density Card) Writing 00100000 bytes to 00000000 ...ROM2 Write Speed: 163 kB/s Done !!! Writing file...E:\EasyJtag\N7100\N7100_Rom1_Alive_Dump_BN\ N7100_Rom1_Alive_Dump_BN.bin Successefuly connected to box on COM32 Box S/N: 1414FF0180A9D84A, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:1619 mV CMD Active Level:2320 mV EMMC CID 15010056545530304D005F9626045FA1 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufactorer ID: 15 EMMC OEM ID: 0100 EMMC Date: 05/2012 FW rev.0x0 HW rev.0x0 EMMC Serial #: 1603675652 EMMC NAME: VTU00M EMMC Capacity: 15028 MB (High Density Card) Writing 20000000 bytes to 00000000 ...ROM1 Write Speed: 221 kB/s Done !!! <ID:0/030> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> N7100XXALIE_N7100OJVALI9_N7100XXALIE_HOME.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/030> Odin v.3 engine (ID:30).. <ID:0/030> File analysis.. <ID:0/030> SetupConnection.. <ID:0/030> Initialzation.. <ID:0/030> Set PIT file.. <ID:0/030> DO NOT TURN OFF TARGET!! <ID:0/030> Get PIT for mapping.. <ID:0/030> Firmware update start.. <ID:0/030> boot.img <ID:0/030> NAND Write Start!! <ID:0/030> recovery.img <ID:0/030> system.img <ID:0/030> modem.bin <ID:0/030> cache.img <ID:0/030> hidden.img <ID:0/030> RQT_CLOSE !! <ID:0/030> RES OK !! <ID:0/030> Completed.. <OSM> All threads completed. (succeed 1 / failed 0) <ID:0/030> Removed!! |
09-20-2013, 08:47 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
unknown baseband: this mean modem part of phone not work: 1. can be bad hardware. 2. can be bad efs. 3. modem part can be not flashed. if phone flashing full by odin, then just repair EFS via any software even free way exist. just check in google EFS repair N7100 via EFS tool. | |
The Following User Says Thank You to blang For This Useful Post: |
