11-15-2016, 08:24 | #1 (permalink) |
Junior Member Join Date: Dec 2015 Location: india
Member: 2505615 Status: Offline Thanks Meter: 3 | N7100 stil dead after boot repair WITH EASY JATAG Z3X EasyJtag Software ver. 2.2.0.1 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 06010016636F12BE, ,FW Ver.: 01.55 CMD Pullup Level:2021 mV CMD Active Level:2433 mV Box IO Level:3300 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 15010056545530304DF1C7E73FE78FBE EMMC CSD : D02701320F5903FFF6DBFFFF8E406008 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 08/2012 Rev.0xF1 EMMC NAME: <b>VTU00M</b> , EMMC NAME (HEX): 56545530304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: <b>Yes<b> EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: VTU00M_3353821159_20161114_2000.extcsd Done. Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 2.2.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:2021 mV CMD Active Level:2433 mV Box IO Level:3300 mV CLK Rate:14000 khz EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Sending Internal Reconfiguration Request... Waiting configuration Apply! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it! <font color="red">Please don't forget to repair extCSD from backup!</font> Done. Z3X EasyJtag Software ver. 2.2.0.1 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 06010016636F12BE, ,FW Ver.: 01.55 CMD Pullup Level:2031 mV CMD Active Level:2866 mV Box IO Level:3300 mV CLK Rate:140000 khz Setup firmware update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Success! Flashing eMMC firmware... Success! Repairing eMMC CID... Success! <font color="green">eMMC firmware is updated now! </font> <font color="green">Please reconnect all eMMC lines before next operation!</font> <font color="green">Please don't forget to repair <b>extCSD</b> from backup!</font> <font color="green">Please don't forget to configure <b>BOOT</b> sizes!</font> Done. Running:Repair extCSD... Z3X EasyJtag Software ver. 2.2.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:2031 mV CMD Active Level:2866 mV Box IO Level:3300 mV CLK Rate:140000 khz Writing... Done. Running:Change BOOT CONFIG... Z3X EasyJtag Software ver. 2.2.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:2031 mV CMD Active Level:2866 mV Box IO Level:3300 mV CLK Rate:140000 khz Writing eMMC Register... Written: REG : 179 VAL :48 Done. Running:Change BOOT WIDTH... Z3X EasyJtag Software ver. 2.2.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:2031 mV CMD Active Level:2866 mV Box IO Level:3300 mV CLK Rate:140000 khz Writing eMMC Register... Written: REG : 177 VAL :1 Done. Z3X EasyJtag Software ver. 2.2.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:2031 mV CMD Active Level:2866 mV Input file : C:\Users\sidhhi\Desktop\v\N7100_Rom1_Alive_Dump_BN .bin Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM) Done. Write Speed: 7673 kB/s Z3X EasyJtag Software ver. 2.2.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:2031 mV CMD Active Level:2866 mV Input file : C:\Users\sidhhi\Desktop\v\EMMC_00000000_00200000.b in Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 1305 kB/s |
11-15-2016, 10:21 | #2 (permalink) |
Insane Poster Join Date: Apr 2012 Location: Kerala
Member: 1753851 Status: Offline Thanks Meter: 32 | Bro Please Follow Steps 1. Detect Emmc 2. Remove Write Protection 3. Do MoviNAND Factory Reset 4. Do MoviNAND Format And Reset 5. Do Emmc Firmware Update 6. Do Repair extCSD 7. Write Rom1 ( 512mb ) 8. Write Rom2 ( 4mb ) 9. Un-solder All Wires And Assemble Mobile 10. Insert Jig And Battery. Mobile Will Enter To Download Mode . Then Full Flash Your Phone 11. Root And Repair Imei 13. Done |
11-15-2016, 10:43 | #3 (permalink) |
Member: 1753851 Status: Offline Thanks Meter: 32 | Sorry There Are Some Mistake Try This 1. Detect Emmc 2. Remove Write Protection 3. Do MoviNAND Factory Reset 4. Do MoviNAND Format And Reset 5. Do Emmc Firmware Update 6. Do Repair extCSD 7. Write Rom1 ( 512mb ) 8. Write Rom2 ( 4mb ) 9. Do Boot Config 10. Un-solder All Wires And Assemble Mobile. Insert Jig And Battery. Mobile Will Enter To Download Mode . Then Full Flash Your Phone |
The Following 2 Users Say Thank You to Suhaib3boys For This Useful Post: |
