11-13-2015, 09:50 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: GOOD
Member: 388862 Status: Offline Thanks Meter: 107 | N7105 KLMAG4FE4B-B002 not fix Z3X EasyJtag Software ver. 2.0.5.1 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 17170DXXXXXXXXX, ,FW Ver.: 01.52 CMD Pullup Level:1742 mV CMD Active Level:1835 mV eMMC Device Information EMMC CID : 00000000000000000000000000000000 EMMC CSD : 00000000000000000000000000000000 EMMC Manufacturer ID: 0000 , OEM ID: 0000 EMMC Date: 00/1997 Rev.0x0 EMMC NAME: , S/N: 0 EMMC NAME (HEX): 20202020202000 EMMC ROM1 (Main User Data) Capacity: 0 MB EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.0 (MMC 4.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: _ 0_20151005_1642.extcsd Done. Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 2.0.5.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1742 mV CMD Active Level:1835 mV This eMMC is not Samsung! Done. Running:SAMSUNG: eMMC firmware update... EMMC NAME: Confirmed eMMC Part Number: KLMAG4FE4B-B002 Z3X EasyJtag Software ver. 2.0.5.1 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 17170DXXXXXXXXX, ,FW Ver.: 01.52 CMD Pullup Level:2041 mV CMD Active Level:2640 mV This eMMC is not Samsung! Done. You must select a valid extCSD file first! |
