10-31-2018, 15:32 | #1 (permalink) |
Freak Poster Join Date: Feb 2015 Location: Libya
Member: 2340647 Status: Offline Thanks Meter: 69 | SM-G355H Boot Repair Problem G355H Still dead after repair Is there any error in the logo: Code: 31/10/2018 01:27:26 م> Looking for EasyJTAG box... 31/10/2018 01:27:26 م> EasyJTAG API ver. 2100 31/10/2018 01:27:26 م> Setting IO Levels to 1.8V 31/10/2018 01:27:26 م> Setting frequence to 6 Mhz 31/10/2018 01:27:26 م> EasyJTAG Box Serial = FBE84B4C2A0EC2BE 31/10/2018 01:27:26 م> EasyJTAG Box Firmware = 2.30 31/10/2018 01:27:26 م> Setting interface to EasyJtag2/ISP 31/10/2018 01:27:26 م> Setting bus width to 1 Bit 31/10/2018 01:27:26 م> Setting frequence to 6 Mhz 31/10/2018 01:27:26 م> CMD Pullup Level: 1818 mV 31/10/2018 01:27:26 م> CMD Active Level: 1871 mV 31/10/2018 01:27:26 م> eMMC Init returned = 0 31/10/2018 01:27:26 م> EMMC Device Information : 31/10/2018 01:27:26 م> EMMC CID: 1501004B3558594D4203A30DF483C1ED 31/10/2018 01:27:26 م> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 31/10/2018 01:27:26 م> EMMC Manufacture : SAMSUNG , EMMC NAME: K5XYMB , HEX: 4B3558594D42 , S/N: A30DF483 , rev. 0x03 31/10/2018 01:27:26 م> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2014 31/10/2018 01:27:26 م> EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) 31/10/2018 01:27:26 م> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 31/10/2018 01:27:26 م> EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) 31/10/2018 01:27:26 م> EMMC Permanent Write Protection: No 31/10/2018 01:27:26 م> EMMC Temporary Write Protection: No 31/10/2018 01:27:26 م> Extended CSD Information : 31/10/2018 01:27:26 م> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 31/10/2018 01:27:26 م> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) 31/10/2018 01:27:26 م> Boot Bus Config: 0x00 , width 1bit 31/10/2018 01:27:26 م> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 31/10/2018 01:27:26 م> Supported partition features [PARTITIONING_SUPPORT]: 0x07 31/10/2018 01:27:26 م> Device supports partitioning features 31/10/2018 01:27:26 م> Device can have enhanced technological features in partitions and user data area 31/10/2018 01:27:26 م> Device can have extended partitions attribute 31/10/2018 01:27:26 م> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 31/10/2018 01:27:26 م> Backup saved: K5XYMB_A30DF483_20181031_132726.extcsd 31/10/2018 01:27:26 م> EMMC Init completed. 31/10/2018 01:27:26 م> 31/10/2018 01:27:27 م> Scanning soft partitions 31/10/2018 01:27:27 م> GPT header is found and is valid 31/10/2018 01:27:27 م> Partition: fixnv1, [000000400000 - 0000007C0000], size: 0000003C0000 (3.75 MB) 31/10/2018 01:27:27 م> Partition: fixnv2, [0000007C0000 - 000000B80000], size: 0000003C0000 (3.75 MB) 31/10/2018 01:27:27 م> Partition: sbl1, [000000B80000 - 000000D80000], size: 000000200000 (2.00 MB) 31/10/2018 01:27:27 م> Partition: sbl2, [000000D80000 - 000000F80000], size: 000000200000 (2.00 MB) 31/10/2018 01:27:27 م> Partition: wdsp, [000000F80000 - 000001480000], size: 000000500000 (5.00 MB) 31/10/2018 01:27:27 م> Partition: wdsp_backup, [000001480000 - 000001980000], size: 000000500000 (5.00 MB) 31/10/2018 01:27:27 م> Partition: modem, [000001980000 - 000002380000], size: 000000A00000 (10.0 MB) 31/10/2018 01:27:27 م> Partition: modem_backup, [000002380000 - 000002D80000], size: 000000A00000 (10.0 MB) 31/10/2018 01:27:27 م> Partition: fota_sig, [000002D80000 - 000002DC0000], size: 000000040000 (256. KB) 31/10/2018 01:27:27 م> Partition: ota, [000002DC0000 - 0000035C0000], size: 000000800000 (8.00 MB) 31/10/2018 01:27:27 م> Partition: runtimenv1, [0000035C0000 - 000003980000], size: 0000003C0000 (3.75 MB) 31/10/2018 01:27:27 م> Partition: runtimenv2, [000003980000 - 000003D40000], size: 0000003C0000 (3.75 MB) 31/10/2018 01:27:27 م> Partition: param, [000003D40000 - 000004000000], size: 0000002C0000 (2.75 MB) 31/10/2018 01:27:27 م> Partition: efs, [000004240000 - 000005640000], size: 000001400000 (20.0 MB) 31/10/2018 01:27:27 م> Partition: prodnv, [000005640000 - 000005B40000], size: 000000500000 (5.00 MB) 31/10/2018 01:27:27 م> Partition: odin_reserved, [000005B40000 - 000005B80000], size: 000000040000 (256. KB) 31/10/2018 01:27:27 م> Partition: kernel, [000005B80000 - 000006A80000], size: 000000F00000 (15.0 MB) 31/10/2018 01:27:27 م> Partition: recovery, [000006A80000 - 000007980000], size: 000000F00000 (15.0 MB) 31/10/2018 01:27:27 م> Partition: csc, [000007980000 - 00000F180000], size: 000007800000 (120. MB) 31/10/2018 01:27:27 م> Partition: system, [00000F180000 - 000056580000], size: 000047400000 (1.11 GB) 31/10/2018 01:27:27 م> Partition: hidden, [000056580000 - 000058380000], size: 000001E00000 (30.0 MB) 31/10/2018 01:27:27 م> Partition: userdata, [000058380000 - 0000E8FFBE00], size: 000090C7BE00 (2.26 GB) 31/10/2018 01:27:27 م> GPT header successfully parsed 31/10/2018 01:27:27 م> 31/10/2018 01:27:27 م> Get firmware version 31/10/2018 01:27:27 م> 31/10/2018 01:27:28 م> Brand = samsung 31/10/2018 01:27:28 م> Manufacturer = samsung 31/10/2018 01:27:28 م> Model = SM-G355H 31/10/2018 01:27:28 م> Phone platform = sc8830 31/10/2018 01:27:28 م> CPU Abi = armeabi-v7a 31/10/2018 01:27:28 م> Android release = 4.4.2 31/10/2018 01:27:28 م> Firmware version = KOT49H.G355HXXU0ANHA 31/10/2018 01:27:28 م> Firmware date = Wed Aug 20 01:00:10 KST 2014 |
11-02-2018, 12:19 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
2) you need to write latest firmware, like G355HXXS0AQA6 (05.01.2017), but you wrote a ANH version (08.2014) | |
11-02-2018, 17:33 | #4 (permalink) |
Member: 2340647 Status: Offline Thanks Meter: 69 | Same problem after write G355HXXS0AQA6 file: Code: Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.3.0.0 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: FBE84B4C2A0EC2BE, ,FW Ver.: 02.30 CMD Pullup Level:1816 mV CMD Active Level:1870 mV Box IO Level:1800 mV CLK Rate:12000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 1501004B3558594D4203A30DF483C1ED eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 12/2014 Rev.0x3 eMMC NAME: K5XYMB , S/N: 2735600771 eMMC NAME (HEX): 4B3558594D42 IC Name: Samsung , KMK5X000YM-B314/4GB+LPDDR2 6Gb(x32) @FBGA162 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: K5XYMB_2735600771_20181102_1552.extcsd Found Data areas (firmware parts) count is: 22 Partition info successfully found --------------------------------------------- P0 (SBL1) [0x400000 0x200000] Size: 2.0MB P1 (SBL2) [0x600000 0x200000] Size: 2.0MB P2 (EFS) [0x800000 0x1400000] Size: 20.0MB P3 (PARAM) [0x1c00000 0x800000] Size: 8.0MB P4 (KERNEL) [0x2400000 0x1400000] Size: 20.0MB P5 (RECOVERY) [0x3800000 0x1400000] Size: 20.0MB P6 (CSC) [0x4c00000 0x9600000] Size: 150.0MB P7 (SYSTEM) [0xe200000 0x51400000] Size: 1.269GB P8 (HIDDEN) [0x5f600000 0x8000000] Size: 128.0MB P9 (OTA) [0x67600000 0x800000] Size: 8.0MB P10 (FIXNV1) [0x67e00000 0x3c0000] Size: 3.750MB P11 (FIXNV2) [0x681c0000 0x3c0000] Size: 3.750MB P12 (WDSP) [0x68580000 0x500000] Size: 5.0MB P13 (MODEM) [0x68a80000 0xa00000] Size: 10.0MB P14 (RUNTIMENV1) [0x69480000 0x3c0000] Size: 3.750MB P15 (RUNTIMENV2) [0x69840000 0x3c0000] Size: 3.750MB P16 (WDSP_BACKUP) [0x69c00000 0x500000] Size: 5.0MB P17 (MODEM_BACKUP) [0x6a100000 0xa00000] Size: 10.0MB P18 (FOTA_SIG) [0x6ab00000 0x40000] Size: 256.0KB P19 (ODIN_RESERVED) [0x6ab40000 0x40000] Size: 256.0KB P20 (PRODNV) [0x6ab80000 0x500000] Size: 5.0MB P21 (USERDATA) [0x6b080000 0x7df7be00] Size: 1.967GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000E200000 (1.269GB) Build ID: KOT49H Display Build ID: KOT49H.G355HXXS0AQA6 Release ID: 4.4.2 Device Model: SM-G355H Device Name: kanas3gxx Architecture ABI: armeabi-v7a Device manufacturer: samsung Device Platform: sc8830 Product ID: kanas Build Description: kanas3gxx-user 4.4.2 KOT49H G355HXXS0AQA6 release-keys Samsung CPU: sc7735s --------------------------------------------- Done. |
11-03-2018, 21:40 | #7 (permalink) |
Freak Poster Join Date: Sep 2015
Member: 2463805 Status: Offline Thanks Meter: 32 | Try once format and write dump Try format and write ROM 1,2 and user bin and extCSD file. And also checkis there any damages in clk CMD lines before write dump. |
The Following User Says Thank You to pirunthan7 For This Useful Post: |
