Old 04-15-2017, 15:46   #1 (permalink)
Member: 1674109
Thanks Meter: 36
Need Expert help to recover Oppo R831k
Dear respected sir
i have problem with oppo r831k with data wipe and casie failed
set is on and hang on oppo logo
i do follow steps to recover this kind of problem with the help of
https://www.youtube.com/watch?v=4bP57ln4DKc
here is the log
---------- eMMC Device Information ----------
EMMC CID : 90014A4834473164040503A28750A1BA
EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2
EMMC Manufacturer ID: 0090 , OEM ID: 014A
EMMC Date: 10/2014 Rev.0x5
EMMC NAME: H4G1d , S/N: 60983120
EMMC NAME (HEX): 48344731642000
EMMC ROM1 (Main User Data) Capacity: 3728 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01
Backup saved: H4G1d _ 60983120_20170415_1939.extcsd
Searching for partition tables...
Partitioning not detected...
Done.
now sir please tell me where i am wrong
now when i connect to flash with cm2
log says
Wait for phone...
Phone found! [ 68 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : 00B000B000B000B000B000B000B00000
eMMC Flash : NOT INSTALLED
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
can any body tell me whats going on with that now no emmc detect can any body help me to solve this
Old 04-15-2017, 17:31   #2 (permalink)
Member: 2553197
Thanks Meter: 32
Originally Posted by mutewitness View Post
Dear respected sir
here is the log
Done.
log says
Wait for phone...
Phone found! [ 68 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
use spflashtool at least write preloader with mtk vendor tab
Old 04-18-2017, 10:58   #3 (permalink)
Member: 1674109
Thanks Meter: 36
i write it bro but same now what to do
Old 04-18-2017, 12:13   #4 (permalink)
Member: 818380
Thanks Meter: 56
use easyjtag plus write by vendor mtk, write preloader and uboot
Old 07-16-2017, 14:02   #5 (permalink)
john_john's Avatar
Member: 310833
Thanks Meter: 10
Anybody sulotion this..?
Old 07-19-2017, 09:28   #6 (permalink)
naushad09's Avatar
Member: 216094
Thanks Meter: 321
if you using whatsup then contact me ill solved your problem.
pm me your contact no ill do it via team viewer
Old 07-21-2017, 10:01   #7 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
emmc not detected after format
most probably dead usual thing with hynix emmc
replace emmc may help
Old 07-21-2017, 15:02   #8 (permalink)
john_john's Avatar
Member: 310833
Thanks Meter: 10
after change emmc same result..
Page generated in 0.20841 seconds with 9 queries
