Old 12-04-2013, 00:18   #1 (permalink)
Saulcell's Avatar
Member: 278939
Sonork: 100.1593095
Thanks Meter: 382
Red face need help with i9300 EMMC repair
this is error Retry writing adress 0x00000000
here log
Writing file...E:\JtagBox\Easy JTAG\Samsung\I9300\EMMC_ROM1_00000000_20000000.bin
Successefuly connected to box on COM32
Box S/N: 0E0E0F14F3059C50, ,FW Ver.: 01.47
Loading eMMC Addon Firmware...
CMD Pullup Level:1320 mV
CMD Active Level:1866 mV
EMMC CID 15010056545530304D00AE8F39615F45
EMMC CSD D02701320F5903FFF6DBFFFF8E40406D
EMMC Manufactorer ID: 15
EMMC OEM ID: 0100
EMMC Date: 05/2012 FW rev.0x0 HW rev.0x0
EMMC Serial #: 2928621921
EMMC NAME: VTU00M
EMMC Capacity: 15028 MB (High Density Card)
Writing 000020000000 bytes to 00000000 ...ROM1
Old 12-04-2013, 05:33   #2 (permalink)
Member: 576776
Thanks Meter: 133
Wink
here log
EMMC OEM ID: 0100
EMMC NAME: VTU00M
Hi,this file is upload server z3x jtag 4mb y 512mb.
Old 12-05-2013, 08:45   #3 (permalink)
Member: 330372
Thanks Meter: 26
i have same issue
actually i don't know the right process
here i tell you what i am doing
1. soldered the eMMC
2. open the eMMC TOOL section in software z3x-jtag
3. clicked on Dtect emmc Card
4. wright eMMC Card
5. selected the file EMMC_ROM2_00000000_00200000.bin which i downloaded fron shell
6. got the following error
EasyJtag Suite ver.: 1.0.88.0 started.
Operating system ver.: Windows 7 (build 7600).
Successefuly connected to box on COM74
Box S/N: 1616050E687C8750, ,FW Ver.: 01.47
Box Working Mode: JTAG Box.
Box Drivers version: 3.0.0.0, are OK
CMD Pullup Level:2134 mV
CMD Active Level:2433 mV
EMMC CID 15010056545530304D0039B9073D7F8B
EMMC OEM ID: 0100
EMMC Date: 07/2012 FW rev.0x0 HW rev.0x0
EMMC Serial #: 968427325
EMMC NAME: VTU00M
Extended CSD rev 1.6 (MMC 4.5)
Card Supported Command sets [S_CMD_SET: 0x01]
HPI Features [HPI_FEATURE: 0x01]:
implementation based on CMD13
Background operations support [BKOPS_SUPPORT: 0x01]
Max Packet Read Cmd [MAX_PACKED_READS: 0x3f]
Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f]
Data TAG support [DATA_TAG_SUPPORT: 0x01]
Data TAG Unit Size [TAG_UNIT_SIZE: 0x04]
Tag Resources Size [TAG_RES_SIZE: 0x00]
Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05]
Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07]
Extended partition attribute support [EXT_SUPPORT: 0x03]
Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a]
Power off notification [POWER_OFF_LONG_TIME: 0x3c]
Cache Size [CACHE_SIZE] is 65536 KiB
Background operations status [BKOPS_STATUS: 0x00]
TRIM Multiplier [TRIM_MULT: 0x02]
Secure Feature support [SEC_FEATURE_SUPPORT: 0x55]
Boot Information [BOOT_INFO: 0x07]
Device supports alternative boot method
Device supports dual data rate during boot
Device supports high speed timing during boot
Boot partition size [BOOT_SIZE_MULTI: 0x10]
Access size [ACC_SIZE: 0x07]
High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01]
High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01]
Reliable write sector count [REL_WR_SEC_C: 0x01]
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x50]
Sleep current (VCC) [S_C_VCC: 0x07]
Sleep current (VCCQ) [S_C_VCCQ: 0x07]
Sleep/awake timeout [S_A_TIMEOUT: 0x11]
Sector Count [SEC_COUNT: 0x01d5a000]
Partition switching timing [PARTITION_SWITCH_TIME: 0x01]
Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x02]
I/O Driver Strength [DRIVER_STRENGTH: 0x00]
Card Type [CARD_TYPE: 0x07]
CSD structure version [CSD_STRUCTURE: 0x02]
Command set [CMD_SET: 0x00]
Command set revision [CMD_SET_REV: 0x00]
Power class [POWER_CLASS: 0x00]
High-speed interface timing [HS_TIMING: 0x00]
Erased memory content [ERASED_MEM_CONT: 0x00]
Boot configuration bytes [PARTITION_CONFIG: 0x48]
No access to boot partition
Boot config protection [BOOT_CONFIG_PROT: 0x00]
Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x01]
High-density erase group definition [ERASE_GROUP_DEF: 0x00]
Boot write protection status registers [BOOT_WP_STATUS]: 0x00
Boot Area Write protection [BOOT_WP]: 0x00
Power ReadOnly locking: possible
Permanent ReadOnly locking: possible
Read Only lock status: not locked
User area write protection register [USER_WP]: 0x00
FW configuration [FW_CONFIG]: 0x00
RPMB Size [RPMB_SIZE_MULT]: 0x01
Write reliability setting register [WR_REL_SET]: 0x1f
Write reliability parameter register [WR_REL_PARAM]: 0x05
Enable background operations handshake [BKOPS_EN]: 0x00
H/W reset function [RST_N_FUNCTION]: 0x00
HPI management [HPI_MGMT]: 0x00
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000bb
Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
General Purpose Partition Size
[GP_SIZE_MULT_4]: 0x000000
[GP_SIZE_MULT_3]: 0x000000
[GP_SIZE_MULT_2]: 0x000000
[GP_SIZE_MULT_1]: 0x000000
Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000
Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000
Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00
Periodic Wake-up [PERIODIC_WAKEUP]: 0x00
Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01
Native sector size [NATIVE_SECTOR_SIZE]: 0x00
Sector size emulation [USE_NATIVE_SECTOR]: 0x00
Sector size [DATA_SECTOR_SIZE]: 0x00
1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00
Class 6 commands control [CLASS_6_CTRL]: 0x00
Number of addressed group to be Released[DYNCAP_NEEDED]: 0x00
Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000
Exception events status[EXCEPTION_EVENTS_STATUS]: 0x0000
Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000
Packed command status [PACKED_COMMAND_STATUS]: 0x00
Packed command failure index [PACKED_FAILURE_INDEX]: 0x00
Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00
Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00
Writing file...E:\Mobile Software\Z3X\jtag\dump\EMMC_ROM2_2Mb_BOOT\EMMC_ROM 2_00000000_00200000.bin
CMD Pullup Level:2794 mV
CMD Active Level:2794 mV
EMMC OEM ID: 0100
EMMC NAME: VTU00M
Writing 000000200000 bytes to 00000000 ...ROM1
eMMC ACK Error !!!
Writing file...E:\Mobile Software\Z3X\jtag\dump\EMMC_ROM1_512Mb_USER\EMMC_R OM1_00000000_20000000.bin
CMD Pullup Level:2155 mV
CMD Active Level:2464 mV
EMMC OEM ID: 0100
EMMC NAME: VTU00M
eMMC ACK Error !!!
Old 12-05-2013, 08:46   #4 (permalink)
Member: 330372
Thanks Meter: 26
i have same issue
4. wright eMMC Card
i also mark the area with red colour which i dont know how to deal i man is there any change require or not
please help me i get lots handset in this problem
EMMC OEM ID: 0100
EMMC NAME: VTU00M
EMMC OEM ID: 0100
EMMC NAME: VTU00M
eMMC ACK Error !!!
EMMC OEM ID: 0100
EMMC NAME: VTU00M
eMMC ACK Error !!!
Old 12-07-2013, 16:24   #5 (permalink)
Member: 1906979
Sonork: 100.1681049
Thanks Meter: 162
the process you done is write, problam is in emmc chip.
Old 12-07-2013, 18:02   #6 (permalink)
Registered User
Member: 1128665
Sonork: 100.1605565
Thanks Meter: 11
EasyJtag Suite ver.: 1.0.79.0 started.
Successefuly connected to box on COM23
Box S/N: 0E0EF91E9C0BD63D, ,FW Ver.: 01.47
Z3X Card Serial : AA37-2959 , ver: 22
CMD Pullup Level:1680 mV
CMD Active Level:2258 mV
EMMC CID 15010056545530304D002F604D288F2B
EMMC OEM ID: 0100
EMMC Date: 08/2012 FW rev.0x0 HW rev.0x0
EMMC Serial #: 794840360
EMMC NAME: VTU00M
Writing file...F:\BOX\EasyJtag\ki9300\EMMC_ROM2_00000000_0 0200000.bin
CMD Pullup Level:1670 mV
EMMC OEM ID: 0100
EMMC NAME: VTU00M
Writing 000000200000 bytes to 00000000 ...ROM2
eMMC ACK Error !!!
Old 12-11-2013, 05:23   #7 (permalink)
Member: 576776
Thanks Meter: 133
Smile
EMMC OEM ID: 0100
EMMC NAME: VTU00M
EMMC OEM ID: 0100
EMMC NAME: VTU00M
eMMC ACK Error !!!
Hi brother , you can add for my skype [email protected], i can help with this problem ok...
good bye.
Old 12-11-2013, 05:27   #8 (permalink)
Member: 576776
Thanks Meter: 133
Exclamation
Originally Posted by kripalu View Post
i have same issue
4. wright eMMC Card
EMMC OEM ID: 0100
EMMC NAME: VTU00M
EMMC OEM ID: 0100
EMMC NAME: VTU00M
eMMC ACK Error !!!
EMMC OEM ID: 0100
EMMC NAME: VTU00M
eMMC ACK Error !!!
this problem is bad wire comunication with emmc adapter bro, you can check this solder wire point emmc ok, i can repair 40 mobilphone emmc i9300 full work bro. you can contac me ok.
Old 12-15-2013, 19:07   #9 (permalink)
drjaved_akhter's Avatar
Member: 585807
Thanks Meter: 781
write boot 2mb file see this
Old 12-16-2013, 09:44   #10 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,558
all answer here
http://forum.gsmhosting.com/vbb/f672...nnect-1691327/
Page generated in 0.28434 seconds with 8 queries
