02-19-2018, 09:02 | #1 (permalink) |
Registered User Join Date: Nov 2013 Location: Somewhere
Member: 2072293 Status: Offline Thanks Meter: 9 | Need Help from seniors i have never seen any emmc detect by pc which i tried to repair, always i thought my be i could not make connection proper. i decided to buy microscope and did it. i have all stuff which help to repair emmc, but still not have skill it. today i open and make proper connection Samsung J700f which is running in good, i want to be sure that in past i make connection emmc that all was dead, so this time i am plan to running in good condition mobile to make connection and check or read emmc info but still show this logs - eMMC_tool Suite ver. 1.4.9.0 (release date: 12.12.2017) Microsoft Windows 7 (64 bit) build 7600 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 2022 EasyJTAG Box Serial = ************ Card Serial = ****-**** EasyJTAG Box Firmware = 2.21 Changelog: 12.12.2017 (ver 1.4.9.0) Fix: Bugs that have been found through your crash report Fix: RandomVerify function Fix: Creation of GPT for Samsung (write by vendor) Fix: Failed to mount large Fat partitions (explorer) Fix: Extraction from contact2.db (explorer) Fix: Error in the "build.prop" parser Fix: CID Parser Add: Support for EasyJtag Plus Box Add: Path for TempDir and InitialDir (option in settings) Add: Unpack Lenovo QSB (utilities) Add: Selecting a PIT file from CSC (write by vendor Samsung) Add: Detect for encrypted dumps from GPG Box Add: Detect for FullDiskEncryption Partition (explorer) Add: LinearVerify of the Partition (read by vendor) Add: Information base about emmc compatibility (thanks to phonemicrodb) Add: Resizing the window (for small screen resolutions) Add: Converting large partitions in SparseImage when reading by vendor (option in settings) Add: Mounting SparseImage (explorer) Add: Automatic backup of the EFS partition for Samsung (read by vendor) Add: Formatting of EFS partition for Samsung on request (write by vendor) Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 Mhz CMD Pullup Level: 3250 mV CMD Active Level: 3315 mV Can't init device. Reason: CMD Timeout Error adapter all ready connected 100ohm resisters from 1.8v to data and cmd. other tool also not show information they giving error like emmc not connected. i m sure all connections are ok. where i am wrong doing steps. please help me. one more thing need to be clear, how to use emmc e- socket? how i can sure this emmc will put in this socket and which side to use as 162/186,529,153,221 help me. |
02-20-2018, 09:38 | #2 (permalink) |
Member: 2072293 Status: Offline Thanks Meter: 9 | Blang Sir this time show card is password lock - Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 Mhz Can't init device. Reason: CARD is Password Locked how to solve this ? |
02-20-2018, 11:18 | #3 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi For First if yo need experiences try find any Qualcomm old phone because this models is so easy for connect ISP ,J700f is very badly connection Personally I think you can't access eMMC With Password Locked but you can try "Remove Password" Button in eMMC tools Tab/Advanced Opt |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
02-28-2018, 09:40 | #4 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,528 | Quote:
