12-13-2016, 16:35 | #1 (permalink) |
Crazy Poster Join Date: Jan 2014
Member: 2109196 Status: Offline Thanks Meter: 6 | need info about xiaomi 3s emmc change |
12-13-2016, 19:21 | #2 (permalink) |
Freak Poster Join Date: Oct 2011 Location: uf1 b0x land
Member: 1675290 Status: Offline Thanks Meter: 177 | if this qualcomm put empty emmc to broken board then flash it with miflash edl mode qualcomm 9008 tested almost all xiaomi qualcomm |
The Following 2 Users Say Thank You to bagus.dps For This Useful Post: |
12-13-2016, 19:24 | #3 (permalink) |
Member: 1675290 Status: Offline Thanks Meter: 177 | u can also put emmc from another board if request password just flash it via edl mode or use TP ... flash using miflash for 64bit win or miflash beta for 32 bit win . also tested btw dwyor broo.. |
The Following User Says Thank You to bagus.dps For This Useful Post: |
12-14-2016, 05:29 | #5 (permalink) |
Member: 1675290 Status: Offline Thanks Meter: 177 | already check this type tested replace by empty kmr82 ( to empty emmc just factory reset using emmc box ) then flash via miflash edl mode using XIOMI EDL JIG try with or without battery ... this is tested solution ... if not solved maybe your board have other problem |
12-14-2016, 05:47 | #7 (permalink) | |
Member: 2109196 Status: Offline Thanks Meter: 6 | Quote:
12-14-2016, 19:37 | #8 (permalink) | |
02-02-2017, 03:53 | #9 (permalink) | |
Member: 1675290 Status: Offline Thanks Meter: 177 | Quote:
erase and factory erase emmc then flash via factory image .... put emmc ... back to board done ... there is no security just regular qualcomm job | |
The Following 4 Users Say Thank You to bagus.dps For This Useful Post: |
02-21-2017, 07:54 | #10 (permalink) |
Freak Poster Join Date: Jan 2013 Location: rajkot
Member: 1864687 Status: Offline Thanks Meter: 22 | need help i changed emmc but not seccesed plzzz check this post http://forum.gsmhosting.com/vbb/f672...essed-2195710/ |
04-21-2017, 09:21 | #11 (permalink) |
No Life Poster Join Date: Mar 2004 Location: pccomp Age: 42
Member: 59173 Status: Offline Sonork: 100.1585568 Thanks Meter: 225 | tell me please what emmc type was on board and with what type you replaced ? mean emmc version important here ? original is 5.1. can put here 5.0 ? |
05-10-2017, 12:09 | #14 (permalink) | |
Member: 59173 Status: Offline Sonork: 100.1585568 Thanks Meter: 225 | Quote:
in 4 forums different users have same problem. after replace emmc - phone show only MI logo and restart. but you say all Ok. HOW ? here also we use original EMMC and still same. is not any other HW problem. be sure. maybe you flash some patched firmware ? in screen you show - is say FBGA153 in this phone emmc is BGA221 not 153. | |
The Following User Says Thank You to *Diablo* For This Useful Post: |
