Old 03-27-2020, 15:18   #1 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,450
Need Info About Data Recovery Via Nand "Technological Pins"
Hi Team I Saw Few Image SD Technological Pins Interface How Can We Extract Data Using It...After Solder Detect N Dump Rom How Can We Extract Data From It..?
The Following User Says Thank You to hitech care For This Useful Post:
Old 03-27-2020, 19:26   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
nand pins can use with nand adapter ro read nand image
but to create bunare image you need convert nand to binary.
it's a not simple
Old 03-28-2020, 09:07   #3 (permalink)
Member: 1834832
Thanks Meter: 1,450
it's a not simple
Error Correction (ECC Correction) Need To Done After Dump N Need To Bypass Controller (CPU) Need To Reverse It (As Processor Store Data In "Split" From) Right..File Structure Mostly Not Available In Nand Right Need Raw Recovery...
I Think These Are Steps
Add To Transformation Graph
XOR Conversion For The Pages
Split N Joining By Blocks N Dumps..
Can U Guide Me How Can I Apply These Process Any Tools Available...?I Know Process Is Complex But I Wanna Try May Be It Works..
https://blog.acelaboratory.com/pc-30...y-process.html
I Use This As Reference I Know Its Very Complex Process
Page generated in 0.14708 seconds with 9 queries
