09-07-2019, 07:08 | #1 (permalink) |
Major Poster Join Date: Jan 2019
Member: 2887331 Status: Offline Thanks Meter: 2 | Netflix does not work after taking the dump. I took a memory dump from a good tv, after soldering the tv works fine, only netflix problem. Apparently, netflix does not work on rooted devices. Is there any number in the original memory that should be sent to the other one? Soldering memory from a good motherboard gives the same symptom, maybe the memory and the processor on the motherboard are paired with each other? The only difference is the S/N number ??? and H/W reset function [RST_N_FUNCTION]: ??? and Partitioning Setting [PARTITION_SETTING_COMPLETED]: ??? Does it matter? The first photo is the original memory, second photo after recording the dump. https://zapodaj.net/cb8c661690761.jpg.html https://zapodaj.net/938d46bb8ed67.jpg.html |
The Following User Says Thank You to valdix23 For This Useful Post: |
