05-27-2017, 11:45 | #1 (permalink) |
Insane Poster Join Date: Sep 2006
Member: 346261 Status: Offline Thanks Meter: 21 | Oppo 831k change emmc not OK CMD Pullup Level: 3145 mV CMD Active Level: 3217 mV EMMC Device Information : EMMC CID: 1501004B3755303030082013C221C0C2 EMMC CSD: D02701320F5903FFF6DBFFE18E404028 EMMC Manufacture Name: SAMSUNG EMMC NAME: K7U000 , S/N: 2013C221 , rev. 08 EMMC NAME (HEX): 4B3755303030 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000) Backup saved: K7U000_2013C221_20170527_172650.extcsd EMMC Init completed. Writing eMMC Register ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Successfully HiPower mode is OFF CMD Pullup Level: 3135 mV CMD Active Level: 3227 mV EMMC Device Information : EMMC CID: 1501004B3755303030082013C221C0C2 EMMC CSD: D02701320F5903FFF6DBFFE18E404028 EMMC Manufacture Name: SAMSUNG EMMC NAME: K7U000 , S/N: 2013C221 , rev. 08 EMMC NAME (HEX): 4B3755303030 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000) Backup saved: K7U000_2013C221_20170527_172654.extcsd EMMC Init completed. HiPower mode is OFF CMD Pullup Level: 3155 mV CMD Active Level: 3227 mV EMMC Device Information : EMMC CID: 1501004B3755303030082013C221C0C2 EMMC CSD: D02701320F5903FFF6DBFFE18E404028 EMMC Manufacture Name: SAMSUNG EMMC NAME: K7U000 , S/N: 2013C221 , rev. 08 EMMC NAME (HEX): 4B3755303030 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000) Backup saved: K7U000_2013C221_20170527_173106.extcsd EMMC Init completed. Opening file: MT6572_Android_scatter.txt The new format of scatter config_version: V1.1.1 platform: MT6572 preloader_oppo72_14079.bin Found 3 supported eMMC CID: name = 'P1J94L' hex = 0x50314A39344C [MICRON] name = 'H4G1d' hex = 0x483447316404 [SKHYNIX] eNAND_H26M31002GPR/4GB @FBGA153 eNAND_H9DP32A4JJBCGR-KEM/4GB @FBGA153 eNAND_H9TP32A4GDBCPR-KGM/4GB @FBGA162 eNAND_H9TP32A8JDACPR-KGM/4GB @FBGA162 name = 'H4G1d' hex = 0x483447316404 [SKHYNIX] eNAND_H26M31002GPR/4GB @FBGA153 eNAND_H9DP32A4JJBCGR-KEM/4GB @FBGA153 eNAND_H9TP32A4GDBCPR-KGM/4GB @FBGA162 eNAND_H9TP32A8JDACPR-KGM/4GB @FBGA162 The size of the last section has been updated HiPower mode is OFF CMD Pullup Level: 3165 mV CMD Active Level: 3238 mV EMMC Device Information : EMMC CID: 1501004B3755303030082013C221C0C2 EMMC CSD: D02701320F5903FFF6DBFFE18E404028 EMMC Manufacture Name: SAMSUNG EMMC NAME: K7U000 , S/N: 2013C221 , rev. 08 EMMC NAME (HEX): 4B3755303030 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000) Backup saved: K7U000_2013C221_20170527_173112.extcsd EMMC Init completed. Repairing eMMC CID... Success! Now Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0] to finalize CID Patch ! HiPower mode is OFF CMD Pullup Level: 3104 mV CMD Active Level: 3217 mV EMMC Device Information : EMMC CID: FE014E50314A393430082013C221C156 EMMC CSD: D02701320F5903FFF6DBFFE18E404028 EMMC Manufacture Name: MICRON EMMC NAME: P1J940 , S/N: 2013C221 , rev. 08 EMMC NAME (HEX): 50314A393430 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000) Backup saved: P1J940_2013C221_20170527_173121.extcsd EMMC Init completed. Operation: Write by vendor (MediaTek) Partition name: PRELOADER Filename: preloader_oppo72_14079.bin , Offset: 000000000000 , filesize: 103796 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 360.77 Kb/s Partition name: MBR Filename: MBR , Offset: 000000C00000 , filesize: 512 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 49.64 Kb/s Partition name: EBR1 Filename: EBR1 , Offset: 000000C80000 , filesize: 512 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 61.30 Kb/s Partition name: UBOOT Filename: lk.bin , Offset: 000002920000 , filesize: 271368 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 828.81 Kb/s Partition name: BOOTIMG Filename: boot.img , Offset: 000002980000 , filesize: 4857856 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 938.05 Kb/s Partition name: RECOVERY Filename: recovery.img , Offset: 000002F80000 , filesize: 5791744 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 937.97 Kb/s Partition name: SEC_RO Filename: secro.img , Offset: 000003980000 , filesize: 135168 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1239.99 Kb/s Partition name: LOGO Filename: logo.bin , Offset: 000004000000 , filesize: 502031 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 815.93 Kb/s Partition name: EBR2 Filename: EBR2 , Offset: 000004300000 , filesize: 512 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 74.75 Kb/s Writing DL_Info... Writing DL_Info done Writing eMMC Register ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x00 All done Flash Fail Help me !!!!!!! |
The Following User Says Thank You to caoleduy For This Useful Post: |
05-27-2017, 12:55 | #3 (permalink) | |
Freak Poster Join Date: Jul 2008
Member: 818380 Status: Offline Thanks Meter: 56 | Quote:
