07-25-2019, 03:58 | #1 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: Morocco-Khenifra
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | oppo a1k after format only mediatek usb port how to fix it ? Quote:
07-25-2019, 16:47 | #2 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: India
Member: 1095362 Status: Offline Thanks Meter: 70 | Quote:
Bro, Can u share pinout? where is gnd?? did u use clk,cmd,d0 only. Z3X EasyJtag Software ver. 3.6.1.11 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 06009012EE2027F8, ,FW Ver.: 01.63 Warning: CMD Pullup Level (0 mV) too low , check cables etc.! CMD Active Level:237 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD CRC Error Done. Z3X EasyJtag Software ver. 3.6.1.11 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 06009012EE2027F8, ,FW Ver.: 01.63 CMD Pullup Level:2031 mV CMD Active Level:2949 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. | |
07-27-2019, 17:15 | #6 (permalink) |
Junior Member Join Date: May 2012
Member: 1763347 Status: Offline Sonork: md.salam76 Thanks Meter: 1 | oppo cph 1923 a1k format with ufi after only mediatek usb port Factory Reset... Creating filesystem... Done. Writing cache... Wrote 80170784 blocks, expected to write 110592 blocks Done. Creating filesystem... Done. Writing userdata... Unknown chunk type 0x0000 at 0x00E0A0C4 Wrote 50103502 blocks, expected to write 5802235 blocks Done. Done. format after only mediatek usb port how to solve? |
07-27-2019, 21:54 | #7 (permalink) |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | admin please delete posts out of subject any suggestion to fix the phone ? thank you any help i still didn't fix the phone yet Last edited by layder; 09-25-2019 at 18:33. Reason: merge posts |
11-25-2019, 08:08 | #11 (permalink) |
Freak Poster Join Date: Sep 2012 Location: KSA
Member: 1813906 Status: Offline Sonork: 100.1618216 Thanks Meter: 33 | I have done 4 oppo a1k never use format for any oppo. if you have qualcomm device then only Reset OppO if you have Mediatek device use only wipe user data . |
The Following User Says Thank You to sharrymz For This Useful Post: |
01-02-2020, 06:45 | #15 (permalink) |
Freak Poster Join Date: Dec 2015 Location: MansehrA KPK (Pakistan) Age: 29
Member: 2505147 Status: Offline Sonork: [email protected] Thanks Meter: 183 | same here .... only mtk port after formate |
The Following User Says Thank You to awanbrother For This Useful Post: |
