Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 32
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 1,943 | Oppo a1k after frp / wipe user data dead only (mediatek usb port) |
The Following User Says Thank You to .::THE ROCK::. For This Useful Post: |
![]() | #10 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 1,943 | Other forum with dump solved.... https://www.********************/thr...670/post-45897 |
![]() | #11 (permalink) | |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 1,943 | Quote:
![]() | #13 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 1,943 | detect info yet Code: Z3X EasyJtag Software ver. 3.6.1.17 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:1980 mV CMD Active Level:2145 mV Box IO Level:1800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100514436334D4203DDA4A869760C eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2019 Rev.0x3 eMMC NAME: QD63MB , S/N: 3718555753 eMMC NAME (HEX): 514436334D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 361 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QD63MB_3718555753_20191130_1440.extcsd Caution: invalid main GPT header, but valid a backup header! Warning: Invalid CRC on main header data; loaded backup partition table. Warning! Main and backup partition tables differ! Warning! Main partition table CRC mismatch! Loaded backup Warning! One or more CRCs don't match. You should repair the disk! Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Detected 42 partitions ------ P0 (BOOT_PARA) [0x8000 0x100000] Size: 1.0MB P1 (RECOVERY) [0x108000 0x2000000] Size: 32.0MB P2 (PARA) [0x2108000 0x80000] Size: 512.0KB P3 (OPPORESERVE1) [0x2188000 0x800000] Size: 8.0MB P4 (OPPORESERVE2) [0x2988000 0x4000000] Size: 64.0MB P5 (OPPORESERVE3) [0x6988000 0x4000000] Size: 64.0MB P6 (OPPO_CUSTOM) [0xa988000 0x100000] Size: 1.0MB P7 (EXPDB) [0xaa88000 0x1400000] Size: 20.0MB P8 (FRP) [0xbe88000 0x100000] Size: 1.0MB P9 (VBMETA) [0xbf88000 0x800000] Size: 8.0MB P10 (NVCFG) [0xc788000 0x2000000] Size: 32.0MB P11 (NVDATA) [0xe788000 0x4000000] Size: 64.0MB P12 (METADATA) [0x12788000 0x2000000] Size: 32.0MB P13 (PROTECT1) [0x14788000 0x800000] Size: 8.0MB P14 (PROTECT2) [0x14f88000 0x878000] Size: 8.468MB P15 (SECCFG) [0x15800000 0x800000] Size: 8.0MB P16 (PERSIST) [0x16000000 0x3000000] Size: 48.0MB P17 (SEC1) [0x19000000 0x200000] Size: 2.0MB P18 (PROINFO) [0x19200000 0x300000] Size: 3.0MB P19 (MD1IMG) [0x19500000 0x6400000] Size: 100.0MB P20 (SPMFW) [0x1f900000 0x100000] Size: 1.0MB P21 (SCP1) [0x1fa00000 0x100000] Size: 1.0MB P22 (SCP2) [0x1fb00000 0x100000] Size: 1.0MB P23 (SSPM_1) [0x1fc00000 0x100000] Size: 1.0MB P24 (SSPM_2) [0x1fd00000 0x100000] Size: 1.0MB P25 (GZ1) [0x1fe00000 0x1000000] Size: 16.0MB P26 (GZ2) [0x20e00000 0x1000000] Size: 16.0MB P27 (NVRAM) [0x21e00000 0x4000000] Size: 64.0MB P28 (LK) [0x25e00000 0x100000] Size: 1.0MB P29 (LK2) [0x25f00000 0x100000] Size: 1.0MB P30 (BOOT) [0x26000000 0x2000000] Size: 32.0MB P31 (LOGO) [0x28000000 0x1000000] Size: 16.0MB P32 (DTBO) [0x29000000 0x1000000] Size: 16.0MB P33 (TEE1) [0x2a000000 0x500000] Size: 5.0MB P34 (TEE2) [0x2a500000 0xb00000] Size: 11.0MB P35 (ODM) [0x2b000000 0x10000000] Size: 256.0MB P36 (VENDOR) [0x3b000000 0x39800000] Size: 920.0MB P37 (SYSTEM) [0x74800000 0x12c000000] Size: 4.687GB P38 (CACHE) [0x1a0800000 0x1b000000] Size: 432.0MB P39 (USERDATA) [0x1bb800000 0x5888fbe00] Size: 22.132GB P40 (OTP) [0x7440fbe00 0x2b00000] Size: 43.0MB P41 (FLASHINFO) [0x746bfbe00 0x1000000] Size: 16.0MB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0074800000 (4.687GB) Unable to read prop.plist , code : 2 --------------------------------------------- Detected USERDATA USERDATA : 0x01BB800000 (22.132GB) Unable to mount USERDATA , code : 95 Done. Selected eMMC Interface |
