Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 11-30-2019, 18:57   #16 (permalink)
.::THE ROCK::.'s Avatar
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 1,943
Originally Posted by .::THE ROCK::. View Post
detect info yet
Z3X EasyJtag Software ver. 3.6.1.17
Loading eMMC GEN1 Firmware... IO: 1800 mV
Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63
CMD Pullup Level:1980 mV
CMD Active Level:2145 mV
Box IO Level:1800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 150100514436334D4203DDA4A869760C
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 07/2019  Rev.0x3
eMMC NAME: QD63MB , S/N: 3718555753
eMMC NAME (HEX): 514436334D42
EMMC ROM1 (Main User Data)   Capacity: 29820 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 361 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
  Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x02 , width 8bits  , Partition config [179]: 0x08.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
 Device support partitioning feature
 Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QD63MB_3718555753_20191130_1440.extcsd
Caution: invalid main GPT header, but valid a backup header!
Warning: Invalid CRC on main header data; loaded backup partition table.
Warning! Main and backup partition tables differ!
Warning! Main partition table CRC mismatch! Loaded backup
Warning! One or more CRCs don't match. You should repair the disk!
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Disk identifier (GUID): 00000000-0000-0000-0000-000000000000
Logical sector size: 0x200  bytes ,First/Last usable sector: 34,61071326
Partition info successfully found
------ Detected 42 partitions ------
P0 (BOOT_PARA) [0x8000 0x100000] Size: 1.0MB
P1 (RECOVERY) [0x108000 0x2000000] Size: 32.0MB
P2 (PARA) [0x2108000 0x80000] Size: 512.0KB
P3 (OPPORESERVE1) [0x2188000 0x800000] Size: 8.0MB
P4 (OPPORESERVE2) [0x2988000 0x4000000] Size: 64.0MB
P5 (OPPORESERVE3) [0x6988000 0x4000000] Size: 64.0MB
P6 (OPPO_CUSTOM) [0xa988000 0x100000] Size: 1.0MB
P7 (EXPDB) [0xaa88000 0x1400000] Size: 20.0MB
P8 (FRP) [0xbe88000 0x100000] Size: 1.0MB
P9 (VBMETA) [0xbf88000 0x800000] Size: 8.0MB
P10 (NVCFG) [0xc788000 0x2000000] Size: 32.0MB
P11 (NVDATA) [0xe788000 0x4000000] Size: 64.0MB
P12 (METADATA) [0x12788000 0x2000000] Size: 32.0MB
P13 (PROTECT1) [0x14788000 0x800000] Size: 8.0MB
P14 (PROTECT2) [0x14f88000 0x878000] Size: 8.468MB
P15 (SECCFG) [0x15800000 0x800000] Size: 8.0MB
P16 (PERSIST) [0x16000000 0x3000000] Size: 48.0MB
P17 (SEC1) [0x19000000 0x200000] Size: 2.0MB
P18 (PROINFO) [0x19200000 0x300000] Size: 3.0MB
P19 (MD1IMG) [0x19500000 0x6400000] Size: 100.0MB
P20 (SPMFW) [0x1f900000 0x100000] Size: 1.0MB
P21 (SCP1) [0x1fa00000 0x100000] Size: 1.0MB
P22 (SCP2) [0x1fb00000 0x100000] Size: 1.0MB
P23 (SSPM_1) [0x1fc00000 0x100000] Size: 1.0MB
P24 (SSPM_2) [0x1fd00000 0x100000] Size: 1.0MB
P25 (GZ1) [0x1fe00000 0x1000000] Size: 16.0MB
P26 (GZ2) [0x20e00000 0x1000000] Size: 16.0MB
P27 (NVRAM) [0x21e00000 0x4000000] Size: 64.0MB
P28 (LK) [0x25e00000 0x100000] Size: 1.0MB
P29 (LK2) [0x25f00000 0x100000] Size: 1.0MB
P30 (BOOT) [0x26000000 0x2000000] Size: 32.0MB
P31 (LOGO) [0x28000000 0x1000000] Size: 16.0MB
P32 (DTBO) [0x29000000 0x1000000] Size: 16.0MB
P33 (TEE1) [0x2a000000 0x500000] Size: 5.0MB
P34 (TEE2) [0x2a500000 0xb00000] Size: 11.0MB
P35 (ODM) [0x2b000000 0x10000000] Size: 256.0MB
P36 (VENDOR) [0x3b000000 0x39800000] Size: 920.0MB
P37 (SYSTEM) [0x74800000 0x12c000000] Size: 4.687GB
P38 (CACHE) [0x1a0800000 0x1b000000] Size: 432.0MB
P39 (USERDATA) [0x1bb800000 0x5888fbe00] Size: 22.132GB
P40 (OTP) [0x7440fbe00 0x2b00000] Size: 43.0MB
P41 (FLASHINFO) [0x746bfbe00 0x1000000] Size: 16.0MB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0074800000 (4.687GB)
Unable to read prop.plist , code : 2
Detected USERDATA USERDATA : 0x01BB800000 (22.132GB)
Unable to mount USERDATA , code : 95
Done.
Selected eMMC Interface
INVALID GPT OR CTC MISMATCH HOW TO SOLVE
Old 12-01-2019, 06:52   #17 (permalink)
ALI_MAFIA's Avatar
Member: 537240
Sonork: 100.1660416
Thanks Meter: 229
i can make it revive if u have vcc and vccq point in isp pinout. i have pinout but vcc nad vccq not have . usb use for vcc nad vccq power but it not full wrok when write full factory rom.
Old 12-01-2019, 08:35   #18 (permalink)
ali_ipi's Avatar
Member: 1655288
Thanks Meter: 64
http://www.martview-forum./threads/a...m.16027/page-2
https://www.********************/thr...m.16027/page-2
Old 12-01-2019, 08:39   #19 (permalink)
ali_ipi's Avatar
Member: 1655288
Thanks Meter: 64
OPPO A1K AFTER FRP / WIPE USER DATA DEAD ONLY (MEDIATEK USB PORT)
www.martview-forum.
Old 12-01-2019, 09:08   #20 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 1,943
no bro not have vcc nad vccq pinout
Old 12-02-2019, 13:08   #21 (permalink)
Member: 784847
Thanks Meter: 44
hello
write only .extcsd
hopefully it will be ok
File Type: rar QD63MB_2437573335_20191120_1314.rar (241 Bytes, 5 views)
Old 12-02-2019, 13:52   #22 (permalink)
Member: 2756153
Thanks Meter: 6
Wink solved?
Bro same me... need this dump
solved now?
#mobiledoctor
The Following User Says Thank You to arslanmughal065 For This Useful Post:
Old 12-02-2019, 16:01   #23 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 1,943
Originally Posted by arslanmughal065 View Post
:d solved now?
#mobiledoctor
yes bro, thank for support
Old 12-02-2019, 16:16   #24 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 1,943
Arrow Oppo a1k dead solved
OPPO A1K SOLVED A print was accidentally cut off the top of the CMD, which caused not to be set on. TRYing many files and many more partitions in the phone went wrong. FINALY it got fixed in this way with the file OG with TOOL.
JUMPAR HELP MY BINNY PAJI HARD WORK
Page generated in 0.44574 seconds with 8 queries
