Oppo A1k CPH1923 Reset oppo but still pin lock i try one oppo A1k click Reset oppo but phone still on pin lock here is log ---------- eMMC Device Information ---------- eMMC CID : 150100514436334D4203DC62A8A0760B eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2019 Rev.0x3 eMMC NAME: QD63MB , S/N: 3697453216 eMMC NAME (HEX): 514436334D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 290 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QD63MB_3697453216_20190912_1511.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Detected 42 partitions ------ P0 (BOOT_PARA) [0x8000 0x100000] Size: 1.0MB P1 (RECOVERY) [0x108000 0x2000000] Size: 32.0MB P2 (PARA) [0x2108000 0x80000] Size: 512.0KB P3 (OPPORESERVE1) [0x2188000 0x800000] Size: 8.0MB P4 (OPPORESERVE2) [0x2988000 0x4000000] Size: 64.0MB P5 (OPPORESERVE3) [0x6988000 0x4000000] Size: 64.0MB P6 (OPPO_CUSTOM) [0xa988000 0x100000] Size: 1.0MB P7 (EXPDB) [0xaa88000 0x1400000] Size: 20.0MB P8 (FRP) [0xbe88000 0x100000] Size: 1.0MB P9 (VBMETA) [0xbf88000 0x800000] Size: 8.0MB P10 (NVCFG) [0xc788000 0x2000000] Size: 32.0MB P11 (NVDATA) [0xe788000 0x4000000] Size: 64.0MB P12 (METADATA) [0x12788000 0x2000000] Size: 32.0MB P13 (PROTECT1) [0x14788000 0x800000] Size: 8.0MB P14 (PROTECT2) [0x14f88000 0x878000] Size: 8.468MB P15 (SECCFG) [0x15800000 0x800000] Size: 8.0MB P16 (PERSIST) [0x16000000 0x3000000] Size: 48.0MB P17 (SEC1) [0x19000000 0x200000] Size: 2.0MB P18 (PROINFO) [0x19200000 0x300000] Size: 3.0MB P19 (MD1IMG) [0x19500000 0x6400000] Size: 100.0MB P20 (SPMFW) [0x1f900000 0x100000] Size: 1.0MB P21 (SCP1) [0x1fa00000 0x100000] Size: 1.0MB P22 (SCP2) [0x1fb00000 0x100000] Size: 1.0MB P23 (SSPM_1) [0x1fc00000 0x100000] Size: 1.0MB P24 (SSPM_2) [0x1fd00000 0x100000] Size: 1.0MB P25 (GZ1) [0x1fe00000 0x1000000] Size: 16.0MB P26 (GZ2) [0x20e00000 0x1000000] Size: 16.0MB P27 (NVRAM) [0x21e00000 0x4000000] Size: 64.0MB P28 (LK) [0x25e00000 0x100000] Size: 1.0MB P29 (LK2) [0x25f00000 0x100000] Size: 1.0MB P30 (BOOT) [0x26000000 0x2000000] Size: 32.0MB P31 (LOGO) [0x28000000 0x1000000] Size: 16.0MB P32 (DTBO) [0x29000000 0x1000000] Size: 16.0MB P33 (TEE1) [0x2a000000 0x500000] Size: 5.0MB P34 (TEE2) [0x2a500000 0xb00000] Size: 11.0MB P35 (ODM) [0x2b000000 0x10000000] Size: 256.0MB P36 (VENDOR) [0x3b000000 0x39800000] Size: 920.0MB P37 (SYSTEM) [0x74800000 0x12c000000] Size: 4.687GB P38 (CACHE) [0x1a0800000 0x1b000000] Size: 432.0MB P39 (USERDATA) [0x1bb800000 0x5888fbe00] Size: 22.132GB P40 (OTP) [0x7440fbe00 0x2b00000] Size: 43.0MB P41 (FLASHINFO) [0x746bfbe00 0x1000000] Size: 16.0MB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0074800000 (4.687GB) Unable to read prop.plist , code : 2 --------------------------------------------- Detected USERDATA USERDATA : 0x01BB800000 (22.132GB) Unable to mount USERDATA , code : 95 Done. Selected eMMC Interface Checking security ... Z3X EasyJtag Software ver. 3.6.1.14 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: F0491474C976AB1B, ,FW Ver.: 02.48 CMD Pullup Level:2097 mV CMD Active Level:2753 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514436334D4203DC62A8A0760B eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2019 Rev.0x3 eMMC NAME: QD63MB , S/N: 3697453216 eMMC NAME (HEX): 514436334D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 290 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Done. |
Its Mtk cpu u need to do wipe userdata & android clear frp (userdata should be erased ) |
yes after wipe user data and remove frp my phone done OK now Problem solved Thanks |
