09-23-2019, 08:56 | #1 (permalink) |
Freak Poster Join Date: Mar 2009 Location: KRJ
Member: 993718 Status: Offline Thanks Meter: 91 | oppo a3s back camera not work after remove pattern after remove pattern oppo a3s cph1803 back camera not work only black screen show front camera working good i try on 2 set first i ignored but last Saturday i unlocked one now customer tell me back camera is not working i don't have log or screen shot log not save in z3x folder please help me to resolve this issue thank you |
12-11-2019, 08:05 | #7 (permalink) | |
Freak Poster Join Date: Aug 2007
Member: 575576 Status: Offline Thanks Meter: 25 | Quote:
is there any solution for this... | |
12-12-2019, 17:26 | #11 (permalink) |
No Life Poster Join Date: Oct 2007 Location: EGYPT
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | NOT hardware bro this bug in software after oppo reset i xtraxt ofp and flash phone now working |
The Following 2 Users Say Thank You to elpring For This Useful Post: |
12-12-2019, 23:25 | #13 (permalink) |
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | EXTRACT OFP AND FLASH eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 7 (64 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = 10FFE00C1DB260E5 Card Serial = AA636424 EasyJTAG Box Firmware = 1.63 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting frequence to 21 MHz CMD Pullup Level: 1691 mV CMD Active Level: 1742 mV Can't init device. Reason: CMD Timeout Error Setting frequence to 21 MHz CMD Pullup Level: 2021 mV CMD Active Level: 3052 mV EMMC Device Information : EMMC CID: 150100514536334D4206D2DDD2F8B5E8 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: D2DDD2F8 , rev. 0x06 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2018 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 121005 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_D2DDD2F8_20191212_162108.extcsd EMMC Init completed. Get firmware version Setting frequence to 21 MHz CMD Pullup Level: 2031 mV CMD Active Level: 3083 mV EMMC Device Information : EMMC CID: 150100514536334D4206D2DDD2F8B5E8 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: D2DDD2F8 , rev. 0x06 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2018 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 121005 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_D2DDD2F8_20191212_162131.extcsd EMMC Init completed. Opening file: patch0.xml Setting frequence to 21 MHz CMD Pullup Level: 2031 mV CMD Active Level: 3104 mV EMMC Device Information : EMMC CID: 150100514536334D4206D2DDD2F8B5E8 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: D2DDD2F8 , rev. 0x06 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2018 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 121005 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_D2DDD2F8_20191212_162154.extcsd EMMC Init completed. Opening file: rawprogram0.xml The size of the last section has been updated Setting frequence to 21 MHz CMD Pullup Level: 2041 mV CMD Active Level: 3093 mV EMMC Device Information : EMMC CID: 150100514536334D4206D2DDD2F8B5E8 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: D2DDD2F8 , rev. 0x06 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2018 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 121005 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_D2DDD2F8_20191212_162221.extcsd EMMC Init completed. Opening file: rawprogram0.xml The size of the last section has been updated Could not open file: C:\UFI\files\Android\Oppo\A3S\CPH1803EX_11_A.20_19 0923_27fe4659\CPH1803EX_11_A.20_190923_27fe4659\ve ndor.img Setting frequence to 21 MHz CMD Pullup Level: 2021 mV CMD Active Level: 3083 mV EMMC Device Information : EMMC CID: 150100514536334D4206D2DDD2F8B5E8 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: D2DDD2F8 , rev. 0x06 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2018 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 121005 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_D2DDD2F8_20191212_162719.extcsd EMMC Init completed. Operation: Write by vendor (Qualcomm/HiSilicon/Omap) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0003A3DFBE00 GPT-partitioning done Partition name: oppodycnvbk Filename: dynamic_nvbk.bin , Offset: 000000005000 , filesize: 10485760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 835.71 KB/s Partition name: oppostanvbk Filename: static_nvbk.bin , Offset: 000000A05000 , filesize: 10485760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 894.85 KB/s Partition name: persist Filename: persist.img , Offset: 000001705000 , filesize: 5132700 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 32 Done writing partition. Write speed: 686.65 KB/s Partition name: opporeserve1 Filename: emmc_fw.bin , Offset: 000003705000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 525.04 KB/s Partition name: opporeserve2 Filename: opporeserve2.img , Offset: 000003F05000 , filesize: 5300372 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 10 Done writing partition. Write speed: 886.02 KB/s Partition name: sbl1 Filename: sbl1.mbn , Offset: 000008308000 , filesize: 452656 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 829.78 KB/s Partition name: rpm Filename: rpm.mbn , Offset: 000008388000 , filesize: 174884 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 818.11 KB/s Partition name: tz Filename: tz.mbn , Offset: 000008408000 , filesize: 1535872 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 863.15 KB/s Partition name: devcfg Filename: devcfg.mbn , Offset: 000008608000 , filesize: 40220 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 424.66 KB/s Partition name: sbl1bak Filename: sbl1.mbn , Offset: 000008648000 , filesize: 452656 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 804.02 KB/s Partition name: rpmbak Filename: rpm.mbn , Offset: 0000086C8000 , filesize: 174884 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 862.05 KB/s Partition name: tzbak Filename: tz.mbn , Offset: 000008748000 , filesize: 1535872 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 898.80 KB/s Partition name: devcfgbak Filename: devcfg.mbn , Offset: 000008948000 , filesize: 40220 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 765.97 KB/s Partition name: dsp Filename: adspso.bin , Offset: 000008988000 , filesize: 16777216 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 795.80 KB/s Partition name: aboot Filename: emmc_appsboot.mbn , Offset: 00000A18C000 , filesize: 741860 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 864.88 KB/s Partition name: abootbak Filename: emmc_appsboot.mbn , Offset: 00000A28C000 , filesize: 741860 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 892.28 KB/s Partition name: modem Filename: NON-HLOS.bin , Offset: 00000A38C000 , filesize: 134217728 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 893.36 KB/s Partition name: dtbo Filename: dtbo.img , Offset: 00001238C000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 890.90 KB/s Partition name: vbmeta Filename: vbmeta.img , Offset: 000012B8C000 , filesize: 4096 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 357.60 KB/s Partition name: boot Filename: boot.img , Offset: 000012B9C000 , filesize: 67108864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 893.90 KB/s Partition name: recovery Filename: recovery.img , Offset: 000016B9C000 , filesize: 67108864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 893.63 KB/s Partition name: LOGO Filename: logo.bin , Offset: 00001BB00000 , filesize: 878592 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 855.11 KB/s Partition name: DRIVER Filename: DRIVER.ISO , Offset: 00001DB00000 , filesize: 23795712 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 890.34 KB/s Partition name: cache Filename: cache.img , Offset: 00001FB00000 , filesize: 6398160 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 15 Done writing partition. Write speed: 884.11 KB/s Partition name: mdtp Filename: mdtp.img , Offset: 000030980000 , filesize: 17808306 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 888.85 KB/s Partition name: lksecapp Filename: lksecapp.mbn , Offset: 000033000000 , filesize: 57352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 721.41 KB/s Partition name: cmnlib Filename: cmnlib_30.mbn , Offset: 000033020000 , filesize: 213856 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 746.20 KB/s Partition name: cmnlib64 Filename: cmnlib64_30.mbn , Offset: 000033120000 , filesize: 269088 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 832.93 KB/s Partition name: keymaster Filename: keymaster64.mbn , Offset: 000033220000 , filesize: 271480 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 793.62 KB/s Partition name: lksecappbak Filename: lksecapp.mbn , Offset: 000033320000 , filesize: 57352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 769.74 KB/s Partition name: cmnlibbak Filename: cmnlib_30.mbn , Offset: 000033340000 , filesize: 213856 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 863.65 KB/s Partition name: cmnlib64bak Filename: cmnlib64_30.mbn , Offset: 000033440000 , filesize: 269088 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 858.43 KB/s Partition name: keymasterbak Filename: keymaster64.mbn , Offset: 000033540000 , filesize: 271480 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 869.10 KB/s Partition name: apdp Filename: dpAP.mbn , Offset: 000033800000 , filesize: 13248 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 378.02 KB/s Partition name: system Filename: system.img , Offset: 00003F000000 , filesize: 2966086816 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 3851 Done writing partition. Write speed: 877.74 KB/s Partition name: vendor Filename: vendor.img , Offset: 000115900000 , filesize: 984627188 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 2898 Done writing partition. Write speed: 877.11 KB/s Partition name: userdata Filename: userdata.img , Offset: 000158000000 , filesize: 2249422708 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 498 Done writing partition. Write speed: 884.54 KB/s All done time: [02:14:32:289] Setting frequence to 21 MHz CMD Pullup Level: 2021 mV CMD Active Level: 3083 mV EMMC Device Information : EMMC CID: 150100514536334D4206D2DDD2F8B5E8 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: D2DDD2F8 , rev. 0x06 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2018 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 121005 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_D2DDD2F8_20191212_184236.extcsd EMMC Init completed. Get firmware version Manufacturer = OPPO CPU Abi = arm64-v8a Android release = 8.1.0 Brand = OPPO Device = CPH1803 Model = CPH1803 Firmware version = CPH1803EX_11_A.20 Firmware date = Mon Sep 23 22:31:13 CST 2019 |
