07-23-2019, 11:44 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: India
Member: 1095362 Status: Offline Thanks Meter: 70 | Oppo A3s (Cph1803) Dead Microsoft Windows 7 (64 bit) build 7601 (6.1.7601.18015) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = 06009012EE2027F8 Card Serial = AACBB1DC EasyJTAG Box Firmware = 1.63 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting frequence to 21 MHz CMD Pullup Level: 1670 mV CMD Active Level: 1722 mV EMMC Device Information : EMMC CID: 150100514536334D420607E00685A5BC EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: 07E00685 , rev. 0x06 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 26109 , Response: Not Clean Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x38 / 0x00 / 0x01 Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: QE63MB_07E00685_20190723_160255.extcsd EMMC Init completed. Get firmware version Firmware info not found Hello Team, any Help. Phone was pattern lock After reset only qualcomm mode showing. I Tried to flash userdata and cache but same problem.. Made clk jumper any other ideas?? |
07-23-2019, 11:46 | #2 (permalink) | |
No Life Poster Join Date: Aug 2012 Location: Bali-Indonesia
Member: 1800628 Status: Offline Thanks Meter: 940 | Quote:
i have success with remove clk and make jumper. | |
The Following User Says Thank You to Deni's For This Useful Post: |
07-23-2019, 14:02 | #4 (permalink) |
Member: 1095362 Status: Offline Thanks Meter: 70 | After Writing userdata and Cache ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D420607E00685A5BC eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 10/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 132122245 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 26109 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_ 132122245_20190723_1829.extcsd Warning! Disk size is smaller than the main header indicates! Warning! Main and backup partition tables differ! Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB) Unable to read prop.plist , code : 2 --------------------------------------------- Detected USERDATA USERDATA : 0x0158000000 (23.745GB) Unable to read gesture.key , code 2 Done. |
07-24-2019, 03:27 | #5 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: philippine
Member: 159757 Status: Offline Thanks Meter: 461 | Quote:
11-23-2019, 01:54 | #12 (permalink) |
No Life Poster Join Date: Oct 2007 Location: EGYPT
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | download this https://www.4shared.com/rar/uXG1T1jB...cham-gsm.html? passowrd : hicham-gsm write by vendor oppodycnvbk + oppostanvbk + modemst1 + modemst2 + fsg + sec + modem you will restor original imei tested by me |
The Following 2 Users Say Thank You to elpring For This Useful Post: |
