12-02-2019, 14:53
#1 (permalink)
Member: 2556542
Thanks Meter: 1,790 | Oppo a3s cph1803 dead recover done unknown baseband fix done Quote:
Setting frequence to 21 MHz
CMD Pullup Level: 1701 mV
CMD Active Level: 1773 mV
EMMC Device Information :
EMMC CID: 150100514536334D420692B49678A52A
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: 92B49678 , rev. 0x06
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 10/2018
EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 17326 , Response: Not Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QE63MB_92B49678_20191202_194617.extcsd
EMMC Init completed.
Opening file: EMMC_hB8aP_ROM1_000000000000_000747C00000.bin
Analyzing Image: EMMC_hB8aP_ROM1_000000000000_000747C00000.bin
Vendor: Qualcomm
Searching GPT ...
GPT header is found and is valid
GPT header successfully parsed
Error: eMMC has a small size
CMD Active Level: 1742 mV
Backup saved: QE63MB_92B49678_20191202_194719.extcsd
Operation: Write by vendor (Qualcomm/HiSilicon/Omap)
Partition name: oppodycnvbk
Filename: EMMC_hB8aP_ROM1_000000000000_000747C00000.bin , Offset: 000000005000 , filesize: 10485760 bytes
eMMC switching to ROM1
Erasing partition...
Writing partition...
Done writing partition. Write speed: 481.45 KB/s
Partition name: oppostanvbk
Filename: EMMC_hB8aP_ROM1_000000000000_000747C00000.bin , Offset: 000000A05000 , filesize: 10485760 bytes
Done writing partition. Write speed: 514.45 KB/s
Partition name: modemst1
Filename: EMMC_hB8aP_ROM1_000000000000_000747C00000.bin , Offset: 000001405000 , filesize: 1572864 bytes
Done writing partition. Write speed: 508.45 KB/s
Partition name: modemst2
Filename: EMMC_hB8aP_ROM1_000000000000_000747C00000.bin , Offset: 000001585000 , filesize: 1572864 bytes
Done writing partition. Write speed: 508.74 KB/s
Partition name: fsg
Filename: EMMC_hB8aP_ROM1_000000000000_000747C00000.bin , Offset: 00000A008000 , filesize: 1572864 bytes
Done writing partition. Write speed: 520.73 KB/s
Partition name: sec
Filename: EMMC_hB8aP_ROM1_000000000000_000747C00000.bin , Offset: 00000A188000 , filesize: 16384 bytes
Done writing partition. Write speed: 362.81 KB/s
Filename: EMMC_hB8aP_ROM1_000000000000_000747C00000.bin , Offset: 00000A38C000 , filesize: 134217728 bytes
Done writing partition. Write speed: 509.59 KB/s
All done time: [00:05:33:276] | ---------------------------- |
