Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 03-03-2020, 15:07   #1 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 10,125
Oppo A3s [CPH1803][EDL MODE][DEAD RECOVERED][DONE] by Easy JTAG_Palash Ahammad
@ All
Please don't remove CLK / CMD Resistance,
Before remove components, Just do you complete the procedure are below.
Step 1:-
Unfortunately when you got your Phone ''EDL'' Mode Problem.
(A) What can you do ?
1) Connect the I.S.P carefully accurate flow by the Pin out.
2) Immediately create your security area / partitions backup read by vendor.
(B) How to backup security area / partitions. Read by vendor ?
Answer:-
Run ''EasyJTAG Plus'' set voltage manually which voltage sweet-able for your eMMC detected also set the frequency 1 mhz + Bus 1 bit.
Go to Read soft partitions then Check ''eMMC / UFS'' if you get all partitions is okay only your phone dose not run or EDL mode detected by 'PC" device manager.
No problem ! don't be upset !
Go to Read by vendor operation ''TAB" there are already all partitions are visible.
(C) Pay attention, You have need to be create Below the partitions backup very carefully.
*) config
*) fsg
*) sec
*) modem
*) modemst1
*) modemst2
*) oppodycnvbk
*) opporeserve2
*) oppostanvbk
*) Persist
Unfortunately if your phone already has been full erase by mistake so you can restore only your B.B below the data write by vendor throw the Partitions.
OPPO A3S CPH1803EX_11_A.17_Samsung eMMC_oppodycnvbk + oppostanvbk + modemst1 + modemst2 + fsg + sec + modem.7z
Very important instruction, when you write the security area for restore your B.B must UN-trick reparation option as per below the image.
(D) Go to eMMC General / Image ''TAB'' select Dump_OPPO A3S CPH1803EX_11_A.17_Samsung eMMC_ QE63MB_06_03_2020_16_08_12.bin
Mega Mirror ## Dump_OPPO A3S CPH1803EX_11_A.17_Samsung eMMC_ QE63MB
3/11/2020 1:17:49 AM> Operation: Writing eMMC...
3/11/2020 1:17:49 AM> Writing to: ROM1 , start: 0x000000000000 , size: 0x00000FA00000
3/11/2020 1:17:50 AM> Input file: C:\Users\Dream\Downloads\OPPO A3S CPH1803EX_11_A.17_Samsung eMMC_ QE63MB_06_03_2020_16_08_12.bin
3/11/2020 1:17:50 AM> eMMC switching to ROM1
3/11/2020 1:17:50 AM> Writing partition...
3/11/2020 1:27:06 AM> Done writing partition. Write speed: 460.08 KB/s
3/11/2020 1:27:06 AM> All done   time: [00:09:16:631]
Go To Scanning soft partitions
3/11/2020 1:27:47 AM> Scanning soft partitions
3/11/2020 1:27:47 AM> GPT header is found and is valid
3/11/2020 1:27:47 AM> Partition: oppodycnvbk, [000000005000 - 000000A05000], size: 000000A00000 (10.0 MB)
3/11/2020 1:27:47 AM> Partition: oppostanvbk, [000000A05000 - 000001405000], size: 000000A00000 (10.0 MB)
3/11/2020 1:27:47 AM> Partition: modemst1, [000001405000 - 000001585000], size: 000000180000 (1.50 MB)
3/11/2020 1:27:47 AM> Partition: modemst2, [000001585000 - 000001705000], size: 000000180000 (1.50 MB)
3/11/2020 1:27:47 AM> Partition: persist, [000001705000 - 000003705000], size: 000002000000 (32.0 MB)
3/11/2020 1:27:47 AM> Partition: opporeserve1, [000003705000 - 000003F05000], size: 000000800000 (8.00 MB)
3/11/2020 1:27:47 AM> Partition: opporeserve2, [000003F05000 - 000007F05000], size: 000004000000 (64.0 MB)
3/11/2020 1:27:47 AM> Partition: reserve_exp1, [000007F05000 - 000008105000], size: 000000200000 (2.00 MB)
3/11/2020 1:27:47 AM> Partition: reserve_exp2, [000008105000 - 000008305000], size: 000000200000 (2.00 MB)
3/11/2020 1:27:47 AM> Partition: fsc, [000008305000 - 000008305400], size: 000000000400 (1.00 KB)
3/11/2020 1:27:47 AM> Partition: ssd, [000008306000 - 000008308000], size: 000000002000 (8.00 KB)
3/11/2020 1:27:47 AM> Partition: sbl1, [000008308000 - 000008388000], size: 000000080000 (512. KB)
3/11/2020 1:27:47 AM> Partition: rpm, [000008388000 - 000008408000], size: 000000080000 (512. KB)
3/11/2020 1:27:47 AM> Partition: tz, [000008408000 - 000008608000], size: 000000200000 (2.00 MB)
3/11/2020 1:27:47 AM> Partition: devcfg, [000008608000 - 000008648000], size: 000000040000 (256. KB)
3/11/2020 1:27:47 AM> Partition: sbl1bak, [000008648000 - 0000086C8000], size: 000000080000 (512. KB)
3/11/2020 1:27:47 AM> Partition: rpmbak, [0000086C8000 - 000008748000], size: 000000080000 (512. KB)
3/11/2020 1:27:47 AM> Partition: tzbak, [000008748000 - 000008948000], size: 000000200000 (2.00 MB)
3/11/2020 1:27:47 AM> Partition: devcfgbak, [000008948000 - 000008988000], size: 000000040000 (256. KB)
3/11/2020 1:27:47 AM> Partition: dsp, [000008988000 - 000009988000], size: 000001000000 (16.0 MB)
3/11/2020 1:27:47 AM> Partition: DDR, [00000A000000 - 00000A008000], size: 000000008000 (32.0 KB)
3/11/2020 1:27:47 AM> Partition: fsg, [00000A008000 - 00000A188000], size: 000000180000 (1.50 MB)
3/11/2020 1:27:47 AM> Partition: sec, [00000A188000 - 00000A18C000], size: 000000004000 (16.0 KB)
3/11/2020 1:27:47 AM> Partition: aboot, [00000A18C000 - 00000A28C000], size: 000000100000 (1.00 MB)
3/11/2020 1:27:47 AM> Partition: abootbak, [00000A28C000 - 00000A38C000], size: 000000100000 (1.00 MB)
3/11/2020 1:27:47 AM> Partition: modem, [00000A38C000 - 00001238C000], size: 000008000000 (128. MB)
3/11/2020 1:27:47 AM> Partition: dtbo, [00001238C000 - 000012B8C000], size: 000000800000 (8.00 MB)
3/11/2020 1:27:47 AM> Partition: vbmeta, [000012B8C000 - 000012B9C000], size: 000000010000 (64.0 KB)
3/11/2020 1:27:47 AM> Partition: boot, [000012B9C000 - 000016B9C000], size: 000004000000 (64.0 MB)
3/11/2020 1:27:47 AM> Partition: recovery, [000016B9C000 - 00001AB9C000], size: 000004000000 (64.0 MB)
3/11/2020 1:27:47 AM> Partition: devinfo, [00001AB9C000 - 00001AC9C000], size: 000000100000 (1.00 MB)
3/11/2020 1:27:47 AM> Partition: splash, [00001B000000 - 00001BB00000], size: 000000B00000 (11.0 MB)
3/11/2020 1:27:47 AM> Partition: LOGO, [00001BB00000 - 00001DB00000], size: 000002000000 (32.0 MB)
3/11/2020 1:27:47 AM> Partition: DRIVER, [00001DB00000 - 00001FB00000], size: 000002000000 (32.0 MB)
3/11/2020 1:27:47 AM> Partition: cache, [00001FB00000 - 00002FB00000], size: 000010000000 (256. MB)
3/11/2020 1:27:47 AM> Partition: misc, [00002FB00000 - 00002FC00000], size: 000000100000 (1.00 MB)
3/11/2020 1:27:47 AM> Partition: keystore, [00002FC00000 - 00002FC80000], size: 000000080000 (512. KB)
3/11/2020 1:27:47 AM> Partition: config, [00002FC80000 - 00002FC88000], size: 000000008000 (32.0 KB)
3/11/2020 1:27:47 AM> Partition: oem, [00002FC88000 - 00002FD88000], size: 000000100000 (1.00 MB)
3/11/2020 1:27:47 AM> Partition: limits, [000030000000 - 000030008000], size: 000000008000 (32.0 KB)
3/11/2020 1:27:47 AM> Partition: mota, [000030800000 - 000030880000], size: 000000080000 (512. KB)
3/11/2020 1:27:47 AM> Partition: dip, [000030880000 - 000030980000], size: 000000100000 (1.00 MB)
3/11/2020 1:27:47 AM> Partition: mdtp, [000030980000 - 000032980000], size: 000002000000 (32.0 MB)
3/11/2020 1:27:47 AM> Partition: syscfg, [000032980000 - 000032A00000], size: 000000080000 (512. KB)
3/11/2020 1:27:47 AM> Partition: mcfg, [000032A00000 - 000032E00000], size: 000000400000 (4.00 MB)
3/11/2020 1:27:47 AM> Partition: lksecapp, [000033000000 - 000033020000], size: 000000020000 (128. KB)
3/11/2020 1:27:47 AM> Partition: cmnlib, [000033020000 - 000033120000], size: 000000100000 (1.00 MB)
3/11/2020 1:27:47 AM> Partition: cmnlib64, [000033120000 - 000033220000], size: 000000100000 (1.00 MB)
3/11/2020 1:27:47 AM> Partition: keymaster, [000033220000 - 000033320000], size: 000000100000 (1.00 MB)
3/11/2020 1:27:47 AM> Partition: lksecappbak, [000033320000 - 000033340000], size: 000000020000 (128. KB)
3/11/2020 1:27:47 AM> Partition: cmnlibbak, [000033340000 - 000033440000], size: 000000100000 (1.00 MB)
3/11/2020 1:27:47 AM> Partition: cmnlib64bak, [000033440000 - 000033540000], size: 000000100000 (1.00 MB)
3/11/2020 1:27:47 AM> Partition: keymasterbak, [000033540000 - 000033640000], size: 000000100000 (1.00 MB)
3/11/2020 1:27:47 AM> Partition: apdp, [000033800000 - 000033840000], size: 000000040000 (256. KB)
3/11/2020 1:27:47 AM> Partition: msadp, [000033840000 - 000033880000], size: 000000040000 (256. KB)
3/11/2020 1:27:47 AM> Partition: dpo, [000033880000 - 000033882000], size: 000000002000 (8.00 KB)
3/11/2020 1:27:47 AM> Partition: logdump, [000033882000 - 000037882000], size: 000004000000 (64.0 MB)
3/11/2020 1:27:47 AM> Partition: vm-kystore, [000037882000 - 000037982000], size: 000000100000 (1.00 MB)
3/11/2020 1:27:47 AM> Partition: vm-data, [000037982000 - 000038382000], size: 000000A00000 (10.0 MB)
3/11/2020 1:27:47 AM> Partition: hyp, [000038800000 - 000039000000], size: 000000800000 (8.00 MB)
3/11/2020 1:27:47 AM> Partition: vm-system, [000039000000 - 00003D000000], size: 000004000000 (64.0 MB)
3/11/2020 1:27:47 AM> Partition: vm-linux, [00003D000000 - 00003F000000], size: 000002000000 (32.0 MB)
3/11/2020 1:27:47 AM> Partition: system, [00003F000000 - 000115900000], size: 0000D6900000 (3.35 GB)
3/11/2020 1:27:47 AM> Partition: vendor, [000115900000 - 000157860000], size: 000041F60000 (1.03 GB)
3/11/2020 1:27:47 AM> Partition: userdata, [000158000000 - 0003A3DFBE00], size: 00024BDFBE00 (9.19 GB)
3/11/2020 1:27:47 AM> GPT header successfully parsed
(E) Now You need to flash this version of firmware, CPH1803EX_11_A.17_190323_102b469c
Go To Unpack OFP File........
(F) Go To Operation: Write by vendor (Qualcomm/HiSilicon/Omap)
Creating GPT-partitioninig
Writing PrimaryGPT at address: 000000000000
Writing BackupGPT at address: 0003A3DFBE00
GPT-partitioning done
Partition name: oppodycnvbk
Filename: dynamic_nvbk.bin , Offset: 000000005000 , filesize: 10485760 bytes
Erasing partition...
Done writing partition. Write speed: 958.73 KB/s
Partition name: oppostanvbk
Filename: static_nvbk.bin , Offset: 000000A05000 , filesize: 10485760 bytes
Done writing partition. Write speed: 1045.91 KB/s
Partition name: persist
Filename: persist.img , Offset: 000001705000 , filesize: 5132700 bytes
Sparse image found v.1.0  Total chunks: 32
Done writing partition. Write speed: 999.65 KB/s
Partition name: opporeserve1
Filename: emmc_fw.bin , Offset: 000003705000 , filesize: 4194304 bytes
Done writing partition. Write speed: 1020.78 KB/s
Partition name: opporeserve2
Filename: opporeserve2.img , Offset: 000003F05000 , filesize: 5300372 bytes
Sparse image found v.1.0  Total chunks: 10
Done writing partition. Write speed: 1029.77 KB/s
Partition name: sbl1
Filename: sbl1.mbn , Offset: 000008308000 , filesize: 452656 bytes
Done writing partition. Write speed: 786.53 KB/s
Partition name: rpm
Filename: rpm.mbn , Offset: 000008388000 , filesize: 174884 bytes
Done writing partition. Write speed: 906.38 KB/s
Partition name: tz
Filename: tz.mbn , Offset: 000008408000 , filesize: 1535872 bytes
Done writing partition. Write speed: 1033.56 KB/s
Partition name: devcfg
Filename: devcfg.mbn , Offset: 000008608000 , filesize: 40220 bytes
Done writing partition. Write speed: 647.89 KB/s
Partition name: sbl1bak
Filename: sbl1.mbn , Offset: 000008648000 , filesize: 452656 bytes
Done writing partition. Write speed: 1009.25 KB/s
Partition name: rpmbak
Filename: rpm.mbn , Offset: 0000086C8000 , filesize: 174884 bytes
Done writing partition. Write speed: 916.57 KB/s
Partition name: tzbak
Filename: tz.mbn , Offset: 000008748000 , filesize: 1535872 bytes
Done writing partition. Write speed: 1034.03 KB/s
Partition name: devcfgbak
Filename: devcfg.mbn , Offset: 000008948000 , filesize: 40220 bytes
Done writing partition. Write speed: 704.44 KB/s
Partition name: dsp
Filename: adspso.bin , Offset: 000008988000 , filesize: 16777216 bytes
Done writing partition. Write speed: 1030.94 KB/s
Partition name: aboot
Filename: emmc_appsboot.mbn , Offset: 00000A18C000 , filesize: 738876 bytes
Done writing partition. Write speed: 1008.16 KB/s
Partition name: abootbak
Filename: emmc_appsboot.mbn , Offset: 00000A28C000 , filesize: 738876 bytes
Done writing partition. Write speed: 1030.65 KB/s
Partition name: modem
Filename: NON-HLOS.bin , Offset: 00000A38C000 , filesize: 134217728 bytes
Done writing partition. Write speed: 1043.81 KB/s
Partition name: dtbo
Filename: dtbo.img , Offset: 00001238C000 , filesize: 8388608 bytes
Done writing partition. Write speed: 1036.50 KB/s
Partition name: vbmeta
Filename: vbmeta.img , Offset: 000012B8C000 , filesize: 4096 bytes
Done writing partition. Write speed: 540.85 KB/s
Partition name: boot
Filename: boot.img , Offset: 000012B9C000 , filesize: 67108864 bytes
Done writing partition. Write speed: 1041.21 KB/s
Partition name: recovery
Filename: recovery.img , Offset: 000016B9C000 , filesize: 67108864 bytes
Partition name: LOGO
Filename: logo.bin , Offset: 00001BB00000 , filesize: 878080 bytes
Done writing partition. Write speed: 969.18 KB/s
Partition name: DRIVER
Filename: DRIVER.ISO , Offset: 00001DB00000 , filesize: 23795712 bytes
Done writing partition. Write speed: 1053.62 KB/s
Partition name: cache
Filename: cache.img , Offset: 00001FB00000 , filesize: 6398160 bytes
Sparse image found v.1.0  Total chunks: 15
Done writing partition. Write speed: 1011.17 KB/s
Partition name: mdtp
Filename: mdtp.img , Offset: 000030980000 , filesize: 17808306 bytes
Done writing partition. Write speed: 1033.31 KB/s
Partition name: lksecapp
Filename: lksecapp.mbn , Offset: 000033000000 , filesize: 57352 bytes
Done writing partition. Write speed: 324.95 KB/s
Partition name: cmnlib
Filename: cmnlib_30.mbn , Offset: 000033020000 , filesize: 213856 bytes
Done writing partition. Write speed: 835.81 KB/s
Partition name: cmnlib64
Filename: cmnlib64_30.mbn , Offset: 000033120000 , filesize: 269088 bytes
Done writing partition. Write speed: 862.58 KB/s
Partition name: keymaster
Filename: keymaster64.mbn , Offset: 000033220000 , filesize: 271480 bytes
Done writing partition. Write speed: 869.37 KB/s
Partition name: lksecappbak
Filename: lksecapp.mbn , Offset: 000033320000 , filesize: 57352 bytes
Done writing partition. Write speed: 921.66 KB/s
Partition name: cmnlibbak
Filename: cmnlib_30.mbn , Offset: 000033340000 , filesize: 213856 bytes
Done writing partition. Write speed: 964.23 KB/s
Partition name: cmnlib64bak
Filename: cmnlib64_30.mbn , Offset: 000033440000 , filesize: 269088 bytes
Done writing partition. Write speed: 934.60 KB/s
Partition name: keymasterbak
Filename: keymaster64.mbn , Offset: 000033540000 , filesize: 271480 bytes
Done writing partition. Write speed: 917.39 KB/s
Partition name: apdp
Filename: dpAP.mbn , Offset: 000033800000 , filesize: 13248 bytes
Done writing partition. Write speed: 104.98 KB/s
Partition name: system
Filename: system.img , Offset: 00003F000000 , filesize: 3208174868 bytes
Sparse image found v.1.0  Total chunks: 4714
Done writing partition. Write speed: 1021.47 KB/s
Partition name: vendor
Filename: vendor.img , Offset: 000115900000 , filesize: 978552928 bytes
Sparse image found v.1.0  Total chunks: 2907
Done writing partition. Write speed: 1022.84 KB/s
Partition name: userdata
Filename: userdata.img , Offset: 000158000000 , filesize: 3422620248 bytes
Sparse image found v.1.0  Total chunks: 901
Done writing partition. Write speed: 1041.68 KB/s
Operation: Writing BootConfig ...
Reg: 179  Value: 0x08
Reg: 177  Value: 0x00
Reg: 162  Value: 0x01
Done
All done   time: [02:21:48:720]
Setting interface to EasyJtag2/ISP_HiPower
Setting bus width to 1 Bit
HiPower mode is ON
Setting frequence to 9 MHz
CMD Pullup Level: 2106 mV
CMD Active Level: 2749 mV
EMMC Device Information :
EMMC CID: 150100514536334D4203ADCF07F035FB
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: ADCF07F0 , rev. 0x03
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2018
   EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000)
   EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
   EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 69475 , Response: Not Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QE63MB_ADCF07F0_20200312_001643.extcsd
EMMC Init completed.
Get firmware version
Manufacturer = OPPO
CPU Abi = arm64-v8a
Android release = 8.1.0
Brand = OPPO
Device = CPH1803
Model = CPH1803
Firmware version = CPH1803EX_11_A.17
Firmware date = Sat Mar 23 21:42:03 CST 2019
Step 1 Has been Successfully Completed
Step 2 :-
(E) Unfortunately if You cannot successfully revive your phone. if you have already backup your security area / partitions data.
(F) Go to eMMC General / Erase eMMC Wait until Finis.......
(G) Just you complete the Step (1) section (D) all job complete.
(H) Go to eMMC config / Boot_Partition_EN 0x7 : User area enabled for boot / set partitions config 0x38
(H) Do you complete from the (Step 1) section (C) backup data write by vendor.
Hopefully your problem willbe solved.
Full_Dump_With User Area_OPPO A3S CPH1803EX_11_A.17_Samsung eMMC _06_03_2020_16_08_12_QE63MB_fsg_part
Oppo A3s Repair Tools & QCN
Only For JTAG expert users if you want you can flash the User area full Dump throw partitions by partitions.
The greatest mind contributing to all the Dump File all the credit goes to him solusi hp
Really This job was my long-range work.
Best regard for all of Oppo Technician
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
The Following 8 Users Say Thank You to ...:::::NP™:::::... For This Useful Post:
Old 03-04-2020, 07:52   #2 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,025
great work brother best of luck.
Old 03-04-2020, 08:06   #3 (permalink)
.::THE ROCK::.'s Avatar
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 1,969
NICE SHER BRO,
BUT CONFUSED.....
JTAG PLUS NOT ACTIVATED,
EasyJtag Suite Classic ver.: 3.6.2.0 / wxWidgets 3.1.3-W-U started.
OS ver.: Windows 7 (build 7600). Admin rights OK
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
EasyJTAG SPI Plugin ver:1.1.1.11
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 3.0.1.0, are OK
Z3X Card Serial : AA27-78BA , ver: 22
Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
JTAG PLUS WORKED
eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019)
Microsoft Windows 7 (32 bit) build 7600 (6.1.7600.16385)
Looking for EasyJTAG box...
EasyJTAG API ver. 3307
EasyJTAG Box Serial = 1717020DE19BFA4A
Card Serial = AA2778BA
EasyJTAG Box Firmware = 1.63
GOOD SIR
Old 03-04-2020, 08:23   #4 (permalink)
Moderator
Member: 1162626
No need JTAG Plus for this category of hard work.
Just you need perseverance [03+ Hour] time: [03:17:30:071] my PC Config is Core i5 with 4GB RAM.
Amazing thing it's Fast Easy JTAG Z3X team 1'st Generation JTAG when it was released by GPG hardware.
But it's reality z3x team is perfectly, acculturating, combined for old & new hardware coding .
http://easy-jtag.com/easyjtag-in-plastic-case/
__________________
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post:
Old 03-04-2020, 08:24   #5 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,025
Originally Posted by .::THE ROCK::. View Post
NICE SHER BRO,
BUT CONFUSED.....
JTAG PLUS WORKED
GOOD SIR
only jtag is working very fine to unlock and dead recover.
little slow to writing speed.
The Following User Says Thank You to kothamamun For This Useful Post:
Old 04-03-2020, 10:27   #6 (permalink)
Member: 1596349
Thanks Meter: 7
Great bro....Thanks
Page generated in 0.17319 seconds with 7 queries
