Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 03-31-2019, 19:31   #1 (permalink)
Member: 1436243
Thanks Meter: 81
Thumbs up Oppo a3s (cph1803) FRP & passcode go away
DETECT
---------- eMMC Device Information ----------
eMMC CID : 90014A484147346132A533FA149785ED
eMMC CSD : D02701328F5903FFFFFFFFE78A400017
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 08/2018  Rev.0xA5
eMMC NAME: HAG4a2 , S/N:  872027287
eMMC NAME (HEX): 484147346132
EMMC ROM1 (Main User Data)   Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
  Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit  , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
 Device support partitioning feature
 Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: HAG4a2_ 872027287_20190331_2354.extcsd
Partition info successfully found
Found Data areas (firmware parts) count is: 65
P0 (OPPODYCNVBK) [0x5000 0xa00000] Size: 10.0MB
P1 (OPPOSTANVBK) [0xa05000 0xa00000] Size: 10.0MB
P2 (MODEMST1) [0x1405000 0x180000] Size: 1.500MB
P3 (MODEMST2) [0x1585000 0x180000] Size: 1.500MB
P4 (PERSIST) [0x1705000 0x2000000] Size: 32.0MB
P5 (OPPORESERVE1) [0x3705000 0x800000] Size: 8.0MB
P6 (OPPORESERVE2) [0x3f05000 0x4000000] Size: 64.0MB
P7 (RESERVE_EXP1) [0x7f05000 0x200000] Size: 2.0MB
P8 (RESERVE_EXP2) [0x8105000 0x200000] Size: 2.0MB
P9 (FSC) [0x8305000 0x400] Size: 1.0KB
P10 (SSD) [0x8306000 0x2000] Size: 8.0KB
P11 (SBL1) [0x8308000 0x80000] Size: 512.0KB
P12 (RPM) [0x8388000 0x80000] Size: 512.0KB
P13 (TZ) [0x8408000 0x200000] Size: 2.0MB
P14 (DEVCFG) [0x8608000 0x40000] Size: 256.0KB
P15 (SBL1BAK) [0x8648000 0x80000] Size: 512.0KB
P16 (RPMBAK) [0x86c8000 0x80000] Size: 512.0KB
P17 (TZBAK) [0x8748000 0x200000] Size: 2.0MB
P18 (DEVCFGBAK) [0x8948000 0x40000] Size: 256.0KB
P19 (DSP) [0x8988000 0x1000000] Size: 16.0MB
P20 (DDR) [0xa000000 0x8000] Size: 32.0KB
P21 (FSG) [0xa008000 0x180000] Size: 1.500MB
P22 (SEC) [0xa188000 0x4000] Size: 16.0KB
P23 (ABOOT) [0xa18c000 0x100000] Size: 1.0MB
P24 (ABOOTBAK) [0xa28c000 0x100000] Size: 1.0MB
P25 (MODEM) [0xa38c000 0x8000000] Size: 128.0MB
P26 (DTBO) [0x1238c000 0x800000] Size: 8.0MB
P27 (VBMETA) [0x12b8c000 0x10000] Size: 64.0KB
P28 (BOOT) [0x12b9c000 0x4000000] Size: 64.0MB
P29 (RECOVERY) [0x16b9c000 0x4000000] Size: 64.0MB
P30 (DEVINFO) [0x1ab9c000 0x100000] Size: 1.0MB
P31 (SPLASH) [0x1b000000 0xb00000] Size: 11.0MB
P32 (LOGO) [0x1bb00000 0x2000000] Size: 32.0MB
P33 (DRIVER) [0x1db00000 0x2000000] Size: 32.0MB
P34 (CACHE) [0x1fb00000 0x10000000] Size: 256.0MB
P35 (MISC) [0x2fb00000 0x100000] Size: 1.0MB
P36 (KEYSTORE) [0x2fc00000 0x80000] Size: 512.0KB
P37 (CONFIG) [0x2fc80000 0x8000] Size: 32.0KB
P38 (OEM) [0x2fc88000 0x100000] Size: 1.0MB
P39 (LIMITS) [0x30000000 0x8000] Size: 32.0KB
P40 (MOTA) [0x30800000 0x80000] Size: 512.0KB
P41 (DIP) [0x30880000 0x100000] Size: 1.0MB
P42 (MDTP) [0x30980000 0x2000000] Size: 32.0MB
P43 (SYSCFG) [0x32980000 0x80000] Size: 512.0KB
P44 (MCFG) [0x32a00000 0x400000] Size: 4.0MB
P45 (LKSECAPP) [0x33000000 0x20000] Size: 128.0KB
P46 (CMNLIB) [0x33020000 0x100000] Size: 1.0MB
P47 (CMNLIB64) [0x33120000 0x100000] Size: 1.0MB
P48 (KEYMASTER) [0x33220000 0x100000] Size: 1.0MB
P49 (LKSECAPPBAK) [0x33320000 0x20000] Size: 128.0KB
P50 (CMNLIBBAK) [0x33340000 0x100000] Size: 1.0MB
P51 (CMNLIB64BAK) [0x33440000 0x100000] Size: 1.0MB
P52 (KEYMASTERBAK) [0x33540000 0x100000] Size: 1.0MB
P53 (APDP) [0x33800000 0x40000] Size: 256.0KB
P54 (MSADP) [0x33840000 0x40000] Size: 256.0KB
P55 (DPO) [0x33880000 0x2000] Size: 8.0KB
P56 (LOGDUMP) [0x33882000 0x4000000] Size: 64.0MB
P57 (VM-KYSTORE) [0x37882000 0x100000] Size: 1.0MB
P58 (VM-DATA) [0x37982000 0xa00000] Size: 10.0MB
P59 (HYP) [0x38800000 0x800000] Size: 8.0MB
P60 (VM-SYSTEM) [0x39000000 0x4000000] Size: 64.0MB
P61 (VM-LINUX) [0x3d000000 0x2000000] Size: 32.0MB
P62 (SYSTEM) [0x3f000000 0xd6900000] Size: 3.352GB
P63 (VENDOR) [0x115900000 0x41f60000] Size: 1.30GB
P64 (USERDATA) [0x158000000 0x2533fbe00] Size: 9.299GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB)
Build ID:  OPM1.171019.026
Release Base ID:  8.1.0
Architecture ABI:  arm64-v8a
Device manufacturer:  OPPO
Build Description:  msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20181103.202305 release-keys
Done.
Android FRP Clear
EMMC ROM1 (Main User Data)   Capacity: 15028 MB , 0x1D5A000 pages , 0x3AB400000 bytes
Formatting FRP...
Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) , formatting...
Detected LINUX(Android) CONFIG : 0x002FC80000 (32.0KB) formatting...
Detected LINUX(Android) USERDATA : 0x0158000000 (9.299GB) , formatting...
Done.
Done.
FORMAT USER DATA
Read EXT fs info
Read EXT fs info
Created filesystem with parameters:
Block size: 4096
Blocks per group: 32768
Inodes per group: 8192
Inode size: 256
Inodes: 16384
Label:
Format EXT fs...
Returned 28...
Read EXT fs info
NEW Created filesystem with parameters:
Block size: 1024
Inodes per group: 2048
Inode size: 256
Inodes: 16384
Label:
Read EXT fs info
Read EXT fs info
Block size: 1024
Inode size: 256
Inodes: 16384
Label:
Format EXT fs...
Returned 28...
Read EXT fs info
Block size: 1024
Inode size: 256
Inodes: 16384
Label:
Done.
Old 04-02-2019, 00:26   #2 (permalink)
CELLMANIAC's Avatar
Member: 410843
Thanks Meter: 21
you done it? mine was stuck hang logo
Old 04-03-2019, 12:55   #3 (permalink)
Member: 2677842
Thanks Meter: 30
yes after format stuck in recovery
Old 04-04-2019, 06:32   #4 (permalink)
royalnasim's Avatar
Member: 1037372
Thanks Meter: 405
Oppp a3s easy way to remove lock and frp
1st. Format userdata in classic suite
2nd. Remove android frp in classic suite
3rd. Go to write by vendor selact firmware and write only userdata file in easy jtag plus suite
💯 success
The Following 2 Users Say Thank You to royalnasim For This Useful Post:
Old 04-06-2019, 15:29   #5 (permalink)
Member: 2255218
Sonork: 100.1680200
💯 success
Screenshots you have?
Old 04-09-2019, 09:24   #6 (permalink)
Member: 450051
Thanks Meter: 45
with usb or with isp pinout?????
Old 04-13-2019, 14:00   #7 (permalink)
Member: 2677842
Thanks Meter: 30
💯 success
3rd. Go to write by vendor selact firmware and write only userdata file in easy jtag plus suite .... where firmware?
Old 04-15-2019, 15:35   #8 (permalink)
Bond.Flasher's Avatar
Member: 2464063
Thanks Meter: 58
Oppo A3s Remove User Lock and Google Account via direct eMMc : https://www.youtube.com/watch?v=FiGmsqgfKkA
Old 04-15-2019, 17:15   #9 (permalink)
Member: 2550445
Thanks Meter: 11
good . thanks
Originally Posted by icloudboss2016 View Post
3rd. Go to write by vendor select firmware and write the only userdata file in easy jtag plus suite... where firmware?
good. thanks... when I format is hang, only restart,,
after I pay, and flash,
Old Yesterday, 15:51   #10 (permalink)
Member: 2066396
Thanks Meter: 2
Just use the same firmware that u read in info
Page generated in 0.15938 seconds with 7 queries
