03-03-2020, 16:07 | #1 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Oppo A3s [CPH1803][Screen Lock Remove] by Easy JTAG. Code: eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 7 (32 bit) build 7600 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = 1717020DE19BFA4A Card Serial = AA2778BA EasyJTAG Box Firmware = 1.63 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting frequence to 21 MHz CMD Pullup Level: 1969 mV CMD Active Level: 2619 mV EMMC Device Information : EMMC CID: 150100514536334D4203ADCF07F035FA EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: ADCF07F0 , rev. 0x03 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2018 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 69467 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_ADCF07F0_20200302_215851.extcsd EMMC Init completed. Get firmware version Firmware info not found Setting frequence to 21 MHz CMD Pullup Level: 2000 mV CMD Active Level: 3052 mV EMMC Device Information : EMMC CID: 150100514536334D4203ADCF07F035FA EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: ADCF07F0 , rev. 0x03 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2018 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 69467 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_ADCF07F0_20200302_220129.extcsd EMMC Init completed. Get firmware version Firmware info not found Code: EasyJtag Suite Classic ver.: 3.6.2.0 / wxWidgets 3.1.3-W-U started. OS ver.: Windows 7 (build 7600). Admin rights OK Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 EasyJTAG SPI Plugin ver:1.1.1.11 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : AA27-78BA , ver: 22 Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 2 serial devices COM15 USB\VID_05C6&PID_9008&REV_0000 Qualcomm HS-USB QDLoader 9008 (COM15) COM3 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Control Port (COM3) Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 1717020DE19BFA4A, ,FW Ver.: 01.63 CMD Pullup Level:1959 mV CMD Active Level:2547 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4203ADCF07F035FA eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 03/2018 Rev.0x3 eMMC NAME: QE63MB , S/N: 2916026352 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 69467 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_2916026352_20200302_2155.extcsd Caution: invalid main GPT header, but valid a backup header! Warning: Invalid CRC on main header data; loaded backup partition table. Warning! Main and backup partition tables differ! Warning! Main partition table CRC mismatch! Loaded backup Warning! One or more CRCs don't match. You should repair the disk! Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFDA sectors 14.6 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 19,30535661 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB) Unable to mount SYSTEM , code : 95 --------------------------------------------- Detected USERDATA USERDATA : 0x0158000000 (9.184GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 7440F1F6 04C6A0AA 060D71AE 4F096232 9DF3852F A983F2B5 6585A89C 0087BBBB t@ñö.Æ ª..q®O b2.ó…/©ƒòµe…¨œ.‡»»; 3710202A 539BE3EB A6620D28 1161E7E4 884AF1A3 EAF8B6EC A521527D 05C0044C 7. *S›ãë¦b.(.açä.Jñ£êø¶ì¥!R}.À.L; 3413B7DD 57D82A4B ABE84805 837E3572 CDA787B1 22DFE284 EC578186 1B2A9B95 4.·ÝWØ*K«èH.ƒ~5rͧ‡±"ßâ„ìW.†.*›•; 2048430A 4A5F9DD8 B1BF2A6A 885C6D71 1BE09BEA 67380B1C 4E8D822A D2DA4939 HC.J_.ر¿*j.\mq.à›êg8..N.‚*ÒÚI9; CBDFF9DD E128646D AAD6476B 1FA9175B 3A6408BD C60B6C33 49CC4068 FB32464B ËßùÝá(dmªÖGk.©.[:d.½Æ.l3IÌ@hû2FK; BBC60531 317CEEC0 446ACC96 343ADFFA C5FDA0D7 C9038035 B003EAA0 CD28A4D4 »Æ.11|îÀDjÌ–4:ßúÅý ×É..5°.ê Í(¤Ô; 5B7F801C C7C96428 F7C8E748 921F41F1 D8703C76 4AD894D6 02B8E236 082759F0 [...ÇÉd(÷ÈçH’.AñØp<vJØ”Ö.¸â6.'Yð; FC4DE9F4 C3177BEC 8ACDC848 19D00212 BF620C4B A509E3F1 F743BFA7 C84798BF üMéôÃ.{ìŠÍÈH.Ð..¿b.K¥ ãñ÷C¿§ÈG.¿; Done. Special Thanks To kothamamun
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. Last edited by ...:::::NP™:::::...; 03-14-2020 at 05:21. |
The Following 5 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
