Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 06-09-2019, 15:33   #1 (permalink)
Member: 2554807
Thanks Meter: 386
Oppo a3s hang to logo after format with easyjtag
Oppo a3s hang to logo after format with easy jtag
Unable to format encrypted FS and i wipe data now hang to logo hlp me
Z3X EasyJtag Software ver. 3.6.0.0
Loading eMMC GEN2 Firmware... IO: 1800 mV
Box S/N: 9F43C4B6F8154346, ,FW Ver.: 02.40
CMD Pullup Level:1809 mV
CMD Active Level:1866 mV
Box IO Level:1800 mV
CLK Rate:36000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 150100524436344D4201C8F4D0EE1513
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 01/2018 Rev.0x1
eMMC NAME: RD64MB , S/N: 3371487470
eMMC NAME (HEX): 524436344D42
EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 44157 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Partition info successfully found
------ Android information ------
Detected LINUX(Android) CACHE : 0x001F300000 (256.0MB)
Read EXT fs info
Read EXT fs info
Created filesystem with parameters:
Block size: 888542576498442241
Blocks per group: 0
Inodes per group: 37
Inode size: 0
Inodes: 4294967295
Label:
Unable to format encrypted FS , try to Wipe it
Detected LINUX(Android) USERDATA : 0x015B800000 (23.690GB)
Read EXT fs info
Read EXT fs info
Blocks per group: 0
Inode size: 0
Inodes: 4294967295
Label:
Done.
Old 06-09-2019, 15:56   #2 (permalink)
Member: 2453200
Thanks Meter: 73
Always Use Letest Version EasyJtag_Release_v3.6.1.2.exe
try With New Version
or Do Feature Wipe userdata Without Risk
Old 06-10-2019, 15:20   #3 (permalink)
Member: 2554807
Thanks Meter: 386
yes i try still hang to logo
[QUOTE=Resident_Evil;13687448]Always Use Letest Version EasyJtag_Release_v3.6.1.2.exe
or Do Feature Wipe userdata Without Risk[/QUOTE
yes bro i try still hang to logo
Old 06-10-2019, 16:28   #4 (permalink)
meeza_84's Avatar
Member: 279362
Sonork: 100.1594141
Thanks Meter: 437
bro if you have backup by vendor just write your problem will be solved
The Following User Says Thank You to meeza_84 For This Useful Post:
Old 06-12-2019, 13:40   #5 (permalink)
Member: 1588653
Sonork: akash48
Thanks Meter: 27
write user data file only by easy jtag plus exe & again wipe user data phone 100% ok
The Following User Says Thank You to akash48 For This Useful Post:
Old 06-14-2019, 05:07   #6 (permalink)
Member: 575576
Thanks Meter: 20
same here...
Read EXT fs info
Blocks Reading Error (0x15B800400 , 2 , Reason: CMD Timeout Error )
Read EXT fs info
Block size: 1108347309489929940
Blocks per group: 7
Inodes per group: 0
Inode size: 0
Inodes: 0
Label: (null)
Done.
even i try to wipe...still hang in logo..
Old 06-14-2019, 07:12   #7 (permalink)
Member: 2130616
Thanks Meter: 5
try to wipe data from recovery 2-3 times your problem solved 100%...........
Old 06-14-2019, 07:22   #8 (permalink)
Member: 2554807
Thanks Meter: 386
yes broo i try, not gone to recovery after format
Old 06-14-2019, 16:41   #9 (permalink)
arneja's Avatar
Member: 2401275
Thanks Meter: 78
same problem here how to solve.........its urgent
Old 06-16-2019, 10:30   #10 (permalink)
Member: 2554807
Thanks Meter: 386
i think now start to buy ufi
Old 06-16-2019, 11:09   #11 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 239
try flashing. i think phone got system damaged. so it needs new fimrware
Old 06-17-2019, 17:19   #12 (permalink)
Member: 1246696
Sonork: 000000000
Thanks Meter: 4
ufi box is right for oppo and real me is good not easy tag
Old 06-17-2019, 18:09   #13 (permalink)
Member: 2288140
Thanks Meter: 41
doing wrong step done 50 plus set with eeasy jtag no problem.show info in easy jtag plus see gpt damage aur anything else so i can help you
Old 06-18-2019, 08:28   #14 (permalink)
jamohaki's Avatar
Member: 83397
Thanks Meter: 125
please can you give step by step guide?
Old 06-18-2019, 16:55   #15 (permalink)
Member: 1246696
Sonork: 000000000
Thanks Meter: 4
i do only a3s and set hang in logo after hard reset set ok but ufi box set ok no almost norisk
Page generated in 0.23168 seconds with 7 queries
