02-06-2020, 12:41 | #1 (permalink) |
No Life Poster Join Date: Apr 2012
Member: 1743727 Status: Offline Thanks Meter: 76 | oppo a3s hang on logo Error: Mount [log] failed PartType: FAT32 eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 10 (64 bit) build 17763 (10.0.17763.771) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = xxxxxxxxxxxxxx Card Serial = xxxxxxxxxxxxxxx EasyJTAG Box Firmware = 1.63 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 2000 mV CMD Active Level: 2609 mV EMMC Device Information : EMMC CID: 90014A484147346132A5C6A6DE34C52E EMMC CSD: D02701328F5903FFFFFFFFE78A400016 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: C6A6DE34 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 12/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 77914 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HAG4a2_C6A6DE34_20200206_165941.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: oppodycnvbk, [000000005000 - 000000A05000], size: 000000A00000 (10.0 MB) Partition: oppostanvbk, [000000A05000 - 000001405000], size: 000000A00000 (10.0 MB) Partition: modemst1, [000001405000 - 000001585000], size: 000000180000 (1.50 MB) Partition: modemst2, [000001585000 - 000001705000], size: 000000180000 (1.50 MB) Partition: persist, [000001705000 - 000003705000], size: 000002000000 (32.0 MB) Partition: opporeserve1, [000003705000 - 000003F05000], size: 000000800000 (8.00 MB) Partition: opporeserve2, [000003F05000 - 000007F05000], size: 000004000000 (64.0 MB) Partition: fsc, [000007F05000 - 000007F05400], size: 000000000400 (1.00 KB) Partition: ssd, [000007F06000 - 000007F08000], size: 000000002000 (8.00 KB) Partition: sbl1, [000007F08000 - 000007F88000], size: 000000080000 (512. KB) Partition: rpm, [000007F88000 - 000008008000], size: 000000080000 (512. KB) Partition: tz, [000008008000 - 000008208000], size: 000000200000 (2.00 MB) Partition: devcfg, [000008208000 - 000008248000], size: 000000040000 (256. KB) Partition: sbl1bak, [000008248000 - 0000082C8000], size: 000000080000 (512. KB) Partition: rpmbak, [0000082C8000 - 000008348000], size: 000000080000 (512. KB) Partition: tzbak, [000008348000 - 000008548000], size: 000000200000 (2.00 MB) Partition: devcfgbak, [000008548000 - 000008588000], size: 000000040000 (256. KB) Partition: dsp, [000008588000 - 000009588000], size: 000001000000 (16.0 MB) Partition: DDR, [000009800000 - 000009808000], size: 000000008000 (32.0 KB) Partition: fsg, [000009808000 - 000009C08000], size: 000000400000 (4.00 MB) Partition: sec, [000009C08000 - 000009C0C000], size: 000000004000 (16.0 KB) Partition: aboot, [000009C0C000 - 000009D0C000], size: 000000100000 (1.00 MB) Partition: abootbak, [000009D0C000 - 000009E0C000], size: 000000100000 (1.00 MB) Partition: modem, [000009E0C000 - 000011E0C000], size: 000008000000 (128. MB) Partition: dtbo, [000011E0C000 - 00001260C000], size: 000000800000 (8.00 MB) Partition: vbmeta, [00001260C000 - 00001261C000], size: 000000010000 (64.0 KB) Partition: boot, [00001261C000 - 00001661C000], size: 000004000000 (64.0 MB) Partition: recovery, [00001661C000 - 00001A61C000], size: 000004000000 (64.0 MB) Partition: devinfo, [00001A61C000 - 00001A71C000], size: 000000100000 (1.00 MB) Partition: splash, [00001A800000 - 00001B300000], size: 000000B00000 (11.0 MB) Partition: LOGO, [00001B300000 - 00001D300000], size: 000002000000 (32.0 MB) Partition: DRIVER, [00001D300000 - 00001F300000], size: 000002000000 (32.0 MB) Partition: cache, [00001F300000 - 00002F300000], size: 000010000000 (256. MB) Partition: misc, [00002F300000 - 00002F400000], size: 000000100000 (1.00 MB) Partition: keystore, [00002F400000 - 00002F480000], size: 000000080000 (512. KB) Partition: config, [00002F480000 - 00002F488000], size: 000000008000 (32.0 KB) Partition: log, [00002F488000 - 000033488000], size: 000004000000 (64.0 MB) Partition: oem, [000033488000 - 000033588000], size: 000000100000 (1.00 MB) Partition: limits, [000033800000 - 000033808000], size: 000000008000 (32.0 KB) Partition: mota, [000034000000 - 000034080000], size: 000000080000 (512. KB) Partition: dip, [000034080000 - 000034180000], size: 000000100000 (1.00 MB) Partition: mdtp, [000034180000 - 000036180000], size: 000002000000 (32.0 MB) Partition: syscfg, [000036180000 - 000036200000], size: 000000080000 (512. KB) Partition: mcfg, [000036200000 - 000036600000], size: 000000400000 (4.00 MB) Partition: lksecapp, [000036800000 - 000036820000], size: 000000020000 (128. KB) Partition: cmnlib, [000036820000 - 000036920000], size: 000000100000 (1.00 MB) Partition: cmnlib64, [000036920000 - 000036A20000], size: 000000100000 (1.00 MB) Partition: keymaster, [000036A20000 - 000036B20000], size: 000000100000 (1.00 MB) Partition: lksecappbak, [000036B20000 - 000036B40000], size: 000000020000 (128. KB) Partition: cmnlibbak, [000036B40000 - 000036C40000], size: 000000100000 (1.00 MB) Partition: cmnlib64bak, [000036C40000 - 000036D40000], size: 000000100000 (1.00 MB) Partition: keymasterbak, [000036D40000 - 000036E40000], size: 000000100000 (1.00 MB) Partition: apdp, [000037000000 - 000037040000], size: 000000040000 (256. KB) Partition: msadp, [000037040000 - 000037080000], size: 000000040000 (256. KB) Partition: dpo, [000037080000 - 000037082000], size: 000000002000 (8.00 KB) Partition: logdump, [000037082000 - 00003B082000], size: 000004000000 (64.0 MB) Partition: vm-kystore, [00003B082000 - 00003B182000], size: 000000100000 (1.00 MB) Partition: vm-data, [00003B182000 - 00003BB82000], size: 000000A00000 (10.0 MB) Partition: hyp, [00003C000000 - 00003C800000], size: 000000800000 (8.00 MB) Partition: vm-system, [00003C800000 - 000040800000], size: 000004000000 (64.0 MB) Partition: vm-linux, [000040800000 - 000042800000], size: 000002000000 (32.0 MB) Partition: system, [000042800000 - 000119100000], size: 0000D6900000 (3.35 GB) Partition: vendor, [000119100000 - 00015B060000], size: 000041F60000 (1.03 GB) Partition: userdata, [00015B800000 - 0003AB3FBC00], size: 00024FBFBC00 (9.25 GB) GPT header successfully parsed Get firmware version Error: Mount [log] failed PartType: FAT32 Error: Mount [log] failed PartType: FAT32 Firmware info not found |
02-06-2020, 12:43 | #2 (permalink) |
Member: 1743727 Status: Offline Thanks Meter: 76 | EasyJTAG Tool logs Z3X EasyJtag Software ver. 3.6.1.15 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: xxxxxxxxxxx, ,FW Ver.: 01.63 CMD Pullup Level:1918 mV CMD Active Level:2093 mV Box IO Level:1800 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 90014A484147346132A5C6A6DE34C52E eMMC CSD : D02701328F5903FFFFFFFFE78A400016 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 12/2018 Rev.0xA5 eMMC NAME: HAG4a2 , S/N: 3332824628 eMMC NAME (HEX): 484147346132 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 77914 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01 --------------------------------------------- Backup saved: HAG4a2_3332824628_20200206_1712.extcsd Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ! Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB Soft (Partitioned) Disk/Image size: 1D59FBB sectors 14.7 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30777309 Partition info successfully found ------ Detected 64 partitions ------ P0 (OPPODYCNVBK) [0x5000 0xa00000] Size: 10.0MB P1 (OPPOSTANVBK) [0xa05000 0xa00000] Size: 10.0MB P2 (MODEMST1) [0x1405000 0x180000] Size: 1.500MB P3 (MODEMST2) [0x1585000 0x180000] Size: 1.500MB P4 (PERSIST) [0x1705000 0x2000000] Size: 32.0MB P5 (OPPORESERVE1) [0x3705000 0x800000] Size: 8.0MB P6 (OPPORESERVE2) [0x3f05000 0x4000000] Size: 64.0MB P7 (FSC) [0x7f05000 0x400] Size: 1.0KB P8 (SSD) [0x7f06000 0x2000] Size: 8.0KB P9 (SBL1) [0x7f08000 0x80000] Size: 512.0KB P10 (RPM) [0x7f88000 0x80000] Size: 512.0KB P11 (TZ) [0x8008000 0x200000] Size: 2.0MB P12 (DEVCFG) [0x8208000 0x40000] Size: 256.0KB P13 (SBL1BAK) [0x8248000 0x80000] Size: 512.0KB P14 (RPMBAK) [0x82c8000 0x80000] Size: 512.0KB P15 (TZBAK) [0x8348000 0x200000] Size: 2.0MB P16 (DEVCFGBAK) [0x8548000 0x40000] Size: 256.0KB P17 (DSP) [0x8588000 0x1000000] Size: 16.0MB P18 (DDR) [0x9800000 0x8000] Size: 32.0KB P19 (FSG) [0x9808000 0x400000] Size: 4.0MB P20 (SEC) [0x9c08000 0x4000] Size: 16.0KB P21 (ABOOT) [0x9c0c000 0x100000] Size: 1.0MB P22 (ABOOTBAK) [0x9d0c000 0x100000] Size: 1.0MB P23 (MODEM) [0x9e0c000 0x8000000] Size: 128.0MB P24 (DTBO) [0x11e0c000 0x800000] Size: 8.0MB P25 (VBMETA) [0x1260c000 0x10000] Size: 64.0KB P26 (BOOT) [0x1261c000 0x4000000] Size: 64.0MB P27 (RECOVERY) [0x1661c000 0x4000000] Size: 64.0MB P28 (DEVINFO) [0x1a61c000 0x100000] Size: 1.0MB P29 (SPLASH) [0x1a800000 0xb00000] Size: 11.0MB P30 (LOGO) [0x1b300000 0x2000000] Size: 32.0MB P31 (DRIVER) [0x1d300000 0x2000000] Size: 32.0MB P32 (CACHE) [0x1f300000 0x10000000] Size: 256.0MB P33 (MISC) [0x2f300000 0x100000] Size: 1.0MB P34 (KEYSTORE) [0x2f400000 0x80000] Size: 512.0KB P35 (CONFIG) [0x2f480000 0x8000] Size: 32.0KB P36 (LOG) [0x2f488000 0x4000000] Size: 64.0MB P37 (OEM) [0x33488000 0x100000] Size: 1.0MB P38 (LIMITS) [0x33800000 0x8000] Size: 32.0KB P39 (MOTA) [0x34000000 0x80000] Size: 512.0KB P40 (DIP) [0x34080000 0x100000] Size: 1.0MB P41 (MDTP) [0x34180000 0x2000000] Size: 32.0MB P42 (SYSCFG) [0x36180000 0x80000] Size: 512.0KB P43 (MCFG) [0x36200000 0x400000] Size: 4.0MB P44 (LKSECAPP) [0x36800000 0x20000] Size: 128.0KB P45 (CMNLIB) [0x36820000 0x100000] Size: 1.0MB P46 (CMNLIB64) [0x36920000 0x100000] Size: 1.0MB P47 (KEYMASTER) [0x36a20000 0x100000] Size: 1.0MB P48 (LKSECAPPBAK) [0x36b20000 0x20000] Size: 128.0KB P49 (CMNLIBBAK) [0x36b40000 0x100000] Size: 1.0MB P50 (CMNLIB64BAK) [0x36c40000 0x100000] Size: 1.0MB P51 (KEYMASTERBAK) [0x36d40000 0x100000] Size: 1.0MB P52 (APDP) [0x37000000 0x40000] Size: 256.0KB P53 (MSADP) [0x37040000 0x40000] Size: 256.0KB P54 (DPO) [0x37080000 0x2000] Size: 8.0KB P55 (LOGDUMP) [0x37082000 0x4000000] Size: 64.0MB P56 (VM-KYSTORE) [0x3b082000 0x100000] Size: 1.0MB P57 (VM-DATA) [0x3b182000 0xa00000] Size: 10.0MB P58 (HYP) [0x3c000000 0x800000] Size: 8.0MB P59 (VM-SYSTEM) [0x3c800000 0x4000000] Size: 64.0MB P60 (VM-LINUX) [0x40800000 0x2000000] Size: 32.0MB P61 (SYSTEM) [0x42800000 0xd6900000] Size: 3.352GB P62 (VENDOR) [0x119100000 0x41f60000] Size: 1.30GB P63 (USERDATA) [0x15b800000 0x24fbfbc00] Size: 9.245GB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB) Unable to read prop.plist , code : 2 --------------------------------------------- Detected USERDATA USERDATA : 0x015B800000 (9.245GB) Unable to mount USERDATA , code : 95 Done. Selected eMMC Interface |
07-24-2020, 09:14 | #8 (permalink) |
Freak Poster Join Date: Jun 2012 Location: uttara dhaka bangladesh Age: 35
Member: 1778788 Status: Offline Thanks Meter: 119 | Setting interface to EasyJtag2/E-Socket Setting bus width to 1 Bit Setting frequence to 42 MHz EMMC Device Information : EMMC CID: 150100474436424D4201BDFD908CB5E5 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: GD6BMB , HEX: 474436424D42 , S/N: BDFD908C , rev. 0x01 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: GD6BMB_BDFD908C_20200724_140056.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: oppodycnvbk, [000000005000 - 000000A05000], size: 000000A00000 (10.0 MB) Partition: oppostanvbk, [000000A05000 - 000001405000], size: 000000A00000 (10.0 MB) Partition: modemst1, [000001405000 - 000001585000], size: 000000180000 (1.50 MB) Partition: modemst2, [000001585000 - 000001705000], size: 000000180000 (1.50 MB) Partition: persist, [000001705000 - 000003705000], size: 000002000000 (32.0 MB) Partition: opporeserve1, [000003705000 - 000003F05000], size: 000000800000 (8.00 MB) Partition: opporeserve2, [000003F05000 - 000007F05000], size: 000004000000 (64.0 MB) Partition: fsc, [000007F05000 - 000007F05400], size: 000000000400 (1.00 KB) Partition: ssd, [000007F06000 - 000007F08000], size: 000000002000 (8.00 KB) Partition: sbl1, [000007F08000 - 000007F88000], size: 000000080000 (512. KB) Partition: rpm, [000007F88000 - 000008008000], size: 000000080000 (512. KB) Partition: tz, [000008008000 - 000008208000], size: 000000200000 (2.00 MB) Partition: devcfg, [000008208000 - 000008248000], size: 000000040000 (256. KB) Partition: sbl1bak, [000008248000 - 0000082C8000], size: 000000080000 (512. KB) Partition: rpmbak, [0000082C8000 - 000008348000], size: 000000080000 (512. KB) Partition: tzbak, [000008348000 - 000008548000], size: 000000200000 (2.00 MB) Partition: devcfgbak, [000008548000 - 000008588000], size: 000000040000 (256. KB) Partition: dsp, [000008588000 - 000009588000], size: 000001000000 (16.0 MB) Partition: DDR, [000009800000 - 000009808000], size: 000000008000 (32.0 KB) Partition: fsg, [000009808000 - 000009C08000], size: 000000400000 (4.00 MB) Partition: sec, [000009C08000 - 000009C0C000], size: 000000004000 (16.0 KB) Partition: aboot, [000009C0C000 - 000009D0C000], size: 000000100000 (1.00 MB) Partition: abootbak, [000009D0C000 - 000009E0C000], size: 000000100000 (1.00 MB) Partition: modem, [000009E0C000 - 000011E0C000], size: 000008000000 (128. MB) Partition: dtbo, [000011E0C000 - 00001260C000], size: 000000800000 (8.00 MB) Partition: vbmeta, [00001260C000 - 00001261C000], size: 000000010000 (64.0 KB) Partition: boot, [00001261C000 - 00001661C000], size: 000004000000 (64.0 MB) Partition: recovery, [00001661C000 - 00001A61C000], size: 000004000000 (64.0 MB) Partition: devinfo, [00001A61C000 - 00001A71C000], size: 000000100000 (1.00 MB) Partition: splash, [00001A800000 - 00001B300000], size: 000000B00000 (11.0 MB) Partition: LOGO, [00001B300000 - 00001D300000], size: 000002000000 (32.0 MB) Partition: DRIVER, [00001D300000 - 00001F300000], size: 000002000000 (32.0 MB) Partition: cache, [00001F300000 - 00002F300000], size: 000010000000 (256. MB) Partition: misc, [00002F300000 - 00002F400000], size: 000000100000 (1.00 MB) Partition: keystore, [00002F400000 - 00002F480000], size: 000000080000 (512. KB) Partition: config, [00002F480000 - 00002F488000], size: 000000008000 (32.0 KB) Partition: log, [00002F488000 - 000033488000], size: 000004000000 (64.0 MB) Partition: oem, [000033488000 - 000033588000], size: 000000100000 (1.00 MB) Partition: limits, [000033800000 - 000033808000], size: 000000008000 (32.0 KB) Partition: mota, [000034000000 - 000034080000], size: 000000080000 (512. KB) Partition: dip, [000034080000 - 000034180000], size: 000000100000 (1.00 MB) Partition: mdtp, [000034180000 - 000036180000], size: 000002000000 (32.0 MB) Partition: syscfg, [000036180000 - 000036200000], size: 000000080000 (512. KB) Partition: mcfg, [000036200000 - 000036600000], size: 000000400000 (4.00 MB) Partition: lksecapp, [000036800000 - 000036820000], size: 000000020000 (128. KB) Partition: cmnlib, [000036820000 - 000036920000], size: 000000100000 (1.00 MB) Partition: cmnlib64, [000036920000 - 000036A20000], size: 000000100000 (1.00 MB) Partition: keymaster, [000036A20000 - 000036B20000], size: 000000100000 (1.00 MB) Partition: lksecappbak, [000036B20000 - 000036B40000], size: 000000020000 (128. KB) Partition: cmnlibbak, [000036B40000 - 000036C40000], size: 000000100000 (1.00 MB) Partition: cmnlib64bak, [000036C40000 - 000036D40000], size: 000000100000 (1.00 MB) Partition: keymasterbak, [000036D40000 - 000036E40000], size: 000000100000 (1.00 MB) Partition: apdp, [000037000000 - 000037040000], size: 000000040000 (256. KB) Partition: msadp, [000037040000 - 000037080000], size: 000000040000 (256. KB) Partition: dpo, [000037080000 - 000037082000], size: 000000002000 (8.00 KB) Partition: logdump, [000037082000 - 00003B082000], size: 000004000000 (64.0 MB) Partition: vm-kystore, [00003B082000 - 00003B182000], size: 000000100000 (1.00 MB) Partition: vm-data, [00003B182000 - 00003BB82000], size: 000000A00000 (10.0 MB) Partition: hyp, [00003C000000 - 00003C800000], size: 000000800000 (8.00 MB) Partition: vm-system, [00003C800000 - 000040800000], size: 000004000000 (64.0 MB) Partition: vm-linux, [000040800000 - 000042800000], size: 000002000000 (32.0 MB) Partition: system, [000042800000 - 000119100000], size: 0000D6900000 (3.35 GB) Partition: vendor, [000119100000 - 00015B060000], size: 000041F60000 (1.03 GB) Partition: userdata, [00015B800000 - 0003A3DFBE00], size: 0002485FBE00 (9.13 GB) GPT header successfully parsed Get firmware version Error: Mount [log] failed PartType: FAT32 Error: Mount [log] failed PartType: FAT32 Manufacturer = OPPO CPU Abi = arm64-v8a Android release = 8.1.0 Security Patch = 2019-05-05 Brand = OPPO Device = CPH1829 Model = CPH1829 Firmware version = CPH1829EX_11_A.22 Firmware date = Thu May 9 09:54:57 CST 2019 |
09-07-2020, 15:00 | #9 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2641734 Status: Offline Thanks Meter: 1 | Scanning soft partitions GPT header is found and is valid Partition: oppodycnvbk, [000000005000 - 000000A05000], size: 000000A00000 (10.0 MB) Partition: oppostanvbk, [000000A05000 - 000001405000], size: 000000A00000 (10.0 MB) Partition: modemst1, [000001405000 - 000001585000], size: 000000180000 (1.50 MB) Partition: modemst2, [000001585000 - 000001705000], size: 000000180000 (1.50 MB) Partition: persist, [000001705000 - 000003705000], size: 000002000000 (32.0 MB) Partition: opporeserve1, [000003705000 - 000003F05000], size: 000000800000 (8.00 MB) Partition: opporeserve2, [000003F05000 - 000007F05000], size: 000004000000 (64.0 MB) Partition: fsc, [000007F05000 - 000007F05400], size: 000000000400 (1.00 KB) Partition: ssd, [000007F06000 - 000007F08000], size: 000000002000 (8.00 KB) Partition: sbl1, [000007F08000 - 000007F88000], size: 000000080000 (512. KB) Partition: rpm, [000007F88000 - 000008008000], size: 000000080000 (512. KB) Partition: tz, [000008008000 - 000008208000], size: 000000200000 (2.00 MB) Partition: devcfg, [000008208000 - 000008248000], size: 000000040000 (256. KB) Partition: sbl1bak, [000008248000 - 0000082C8000], size: 000000080000 (512. KB) Partition: rpmbak, [0000082C8000 - 000008348000], size: 000000080000 (512. KB) Partition: tzbak, [000008348000 - 000008548000], size: 000000200000 (2.00 MB) Partition: devcfgbak, [000008548000 - 000008588000], size: 000000040000 (256. KB) Partition: dsp, [000008588000 - 000009588000], size: 000001000000 (16.0 MB) Partition: DDR, [000009800000 - 000009808000], size: 000000008000 (32.0 KB) Partition: fsg, [000009808000 - 000009C08000], size: 000000400000 (4.00 MB) Partition: sec, [000009C08000 - 000009C0C000], size: 000000004000 (16.0 KB) Partition: aboot, [000009C0C000 - 000009D0C000], size: 000000100000 (1.00 MB) Partition: abootbak, [000009D0C000 - 000009E0C000], size: 000000100000 (1.00 MB) Partition: modem, [000009E0C000 - 000011E0C000], size: 000008000000 (128. MB) Partition: dtbo, [000011E0C000 - 00001260C000], size: 000000800000 (8.00 MB) Partition: vbmeta, [00001260C000 - 00001261C000], size: 000000010000 (64.0 KB) Partition: boot, [00001261C000 - 00001661C000], size: 000004000000 (64.0 MB) Partition: recovery, [00001661C000 - 00001A61C000], size: 000004000000 (64.0 MB) Partition: devinfo, [00001A61C000 - 00001A71C000], size: 000000100000 (1.00 MB) Partition: splash, [00001A800000 - 00001B300000], size: 000000B00000 (11.0 MB) Partition: LOGO, [00001B300000 - 00001D300000], size: 000002000000 (32.0 MB) Partition: DRIVER, [00001D300000 - 00001F300000], size: 000002000000 (32.0 MB) Partition: cache, [00001F300000 - 00002F300000], size: 000010000000 (256. MB) Partition: misc, [00002F300000 - 00002F400000], size: 000000100000 (1.00 MB) Partition: keystore, [00002F400000 - 00002F480000], size: 000000080000 (512. KB) Partition: config, [00002F480000 - 00002F488000], size: 000000008000 (32.0 KB) Partition: log, [00002F488000 - 000033488000], size: 000004000000 (64.0 MB) Partition: oem, [000033488000 - 000033588000], size: 000000100000 (1.00 MB) Partition: limits, [000033800000 - 000033808000], size: 000000008000 (32.0 KB) Partition: mota, [000034000000 - 000034080000], size: 000000080000 (512. KB) Partition: dip, [000034080000 - 000034180000], size: 000000100000 (1.00 MB) Partition: mdtp, [000034180000 - 000036180000], size: 000002000000 (32.0 MB) Partition: syscfg, [000036180000 - 000036200000], size: 000000080000 (512. KB) Partition: mcfg, [000036200000 - 000036600000], size: 000000400000 (4.00 MB) Partition: lksecapp, [000036800000 - 000036820000], size: 000000020000 (128. KB) Partition: cmnlib, [000036820000 - 000036920000], size: 000000100000 (1.00 MB) Partition: cmnlib64, [000036920000 - 000036A20000], size: 000000100000 (1.00 MB) Partition: keymaster, [000036A20000 - 000036B20000], size: 000000100000 (1.00 MB) Partition: lksecappbak, [000036B20000 - 000036B40000], size: 000000020000 (128. KB) Partition: cmnlibbak, [000036B40000 - 000036C40000], size: 000000100000 (1.00 MB) Partition: cmnlib64bak, [000036C40000 - 000036D40000], size: 000000100000 (1.00 MB) Partition: keymasterbak, [000036D40000 - 000036E40000], size: 000000100000 (1.00 MB) Partition: apdp, [000037000000 - 000037040000], size: 000000040000 (256. KB) Partition: msadp, [000037040000 - 000037080000], size: 000000040000 (256. KB) Partition: dpo, [000037080000 - 000037082000], size: 000000002000 (8.00 KB) Partition: logdump, [000037082000 - 00003B082000], size: 000004000000 (64.0 MB) Partition: vm-kystore, [00003B082000 - 00003B182000], size: 000000100000 (1.00 MB) Partition: vm-data, [00003B182000 - 00003BB82000], size: 000000A00000 (10.0 MB) Partition: hyp, [00003C000000 - 00003C800000], size: 000000800000 (8.00 MB) Partition: vm-system, [00003C800000 - 000040800000], size: 000004000000 (64.0 MB) Partition: vm-linux, [000040800000 - 000042800000], size: 000002000000 (32.0 MB) Partition: system, [000042800000 - 000119100000], size: 0000D6900000 (3.35 GB) Partition: vendor, [000119100000 - 00015B060000], size: 000041F60000 (1.03 GB) Partition: userdata, [00015B800000 - 000747BFBE00], size: 0005EC3FBE00 (23.6 GB) GPT header successfully parsed Get firmware version Error: Mount [log] failed PartType: FAT32 Error: Mount [log] failed PartType: FAT32 Manufacturer = OPPO CPU Abi = arm64-v8a Android release = 8.1.0 Security Patch = 2019-05-05 Brand = OPPO Device = RMX1805 Model = RMX1805 Firmware version = RMX1805EX_11_A.26 Firmware date = Thu May 16 09:45:04 CST 2019 Realme C1 Emmc Info |
