Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 07-09-2019, 09:05   #136 (permalink)
Member: 230504
Thanks Meter: 57
Originally Posted by rico_deep View Post
CPH1803EX_11_A.13_181103_2bc89894
same thing here only logo after flash wiyh mentioned version
Old 07-10-2019, 14:02   #137 (permalink)
Member: 334106
Thanks Meter: 52
i just revive my A3s that has been break by early version of easy jtag
extract latest a3s ofp firmware and flash via easy jtag on vendor tab
unit now alive and kicking
how to extract ofp fw ?
Old 07-10-2019, 16:15   #138 (permalink)
royalnasim's Avatar
Member: 1037372
Thanks Meter: 458
Use easy jtag plus 1.6.0.0
The Following User Says Thank You to royalnasim For This Useful Post:
Old 07-10-2019, 16:51   #139 (permalink)
Member: 230504
Thanks Meter: 57
problem solved thanks to royalnasim help.
Old 07-11-2019, 16:37   #140 (permalink)
sr8787's Avatar
Member: 788946
Sonork: 100.1682685
Thanks Meter: 410
after wipe data a3s not power on show only Qualcomm port
need help
Old 07-11-2019, 21:02   #141 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,007
write data ,read previous posts
Old 07-12-2019, 11:01   #142 (permalink)
srkhan's Avatar
Member: 153695
Sonork: srkhan
Thanks Meter: 766
Oppo A3s Reset error
Z3X EasyJtag Software ver. 3.6.1.9
Loading eMMC GEN1 Firmware... IO: 3300 mV
Box S/N: 060xxxxxxxxxx, ,FW Ver.: 01.63
CMD Pullup Level:1969 mV
CMD Active Level:3093 mV
Box IO Level:3300 mV
CLK Rate:14000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 150100514536334D4206B2B996E7B57A
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 11/2018 Rev.0x6
eMMC NAME: QE63MB , S/N: 2998507239
eMMC NAME (HEX): 514536334D42
IC Name: Samsung , KMQE60013M-B318/16GB @BGA221
EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is not yet programmed (clear) or RPMB Authentication key not yet programmed
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Writing Recovery Command to MISC (35)
mmc_write_blocks(0x2FB00000 , 1000 ), Failed: CMD Timeout Error
Done.
Old 07-12-2019, 21:51   #143 (permalink)
Member: 13148
Thanks Meter: 1,103
If you use ISP, you need set lower IO
Old 07-13-2019, 02:40   #144 (permalink)
boy_muslim's Avatar
Member: 452214
Sonork: No warranty
Thanks Meter: 382
OPPO A3s & A7 PASSWORD & FRP done EASY
OPPO MODELS
A3s CPH1803
A3s CPH1853
A7 CPH1903
https://a.imge.to/2019/07/13/qYYir.jpg
https://a.imge.to/2019/07/13/qYOMt.jpg
https://a.imge.to/2019/07/13/qYCG0.jpg
https://a.imge.to/2019/07/13/qYxlx.jpg
https://a.imge.to/2019/07/13/qYb2Z.jpg
https://a.imge.to/2019/07/13/qY7t1.jpg
https://a.imge.to/2019/07/13/qYoUG.jpg
https://a.imge.to/2019/07/13/qY9mq.jpg
The Following 3 Users Say Thank You to boy_muslim For This Useful Post:
Old 07-13-2019, 03:23   #145 (permalink)
Member: 1099075
Thanks Meter: 131
jtag bro? congrats! bangis
The Following User Says Thank You to harry0909 For This Useful Post:
Old 07-13-2019, 04:31   #146 (permalink)
boy_muslim's Avatar
Member: 452214
Sonork: No warranty
Thanks Meter: 382
Old 07-13-2019, 08:16   #147 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 780
without any log so easy how crazypost here details
Old 07-13-2019, 09:35   #148 (permalink)
Member: 1246696
Sonork: 000000000
Thanks Meter: 16
oppo a3s oppo reset done
Found 2 serial devices
COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1)
COM5 USB\VID_0325&PID_0032&REV_0100&MI_00 USB Serial Device (COM5)
Selected pinout: EasyJTAG GEN1 ISP Pinout
Change EasyJTAG Pinout OK
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 16160C0455030F93, ,FW Ver.: 01.63
CMD Pullup Level:1980 mV
CMD Active Level:2330 mV
Box IO Level:2800 mV
CLK Rate:14000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
eMMC CID : 150100514536334D42035C28D80845CC
eMMC Date: 04/2018 Rev.0x3
eMMC NAME: QE63MB , S/N: 1546180616
EMMC RPMB is programmed and written 65702 times
Backup saved: QE63MB_1546180616_20190713_1358.extcsd
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB
Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646
Partition info successfully found
------ Detected 65 partitions ------
P0 (OPPODYCNVBK) [0x5000 0xa00000] Size: 10.0MB
P1 (OPPOSTANVBK) [0xa05000 0xa00000] Size: 10.0MB
P2 (MODEMST1) [0x1405000 0x180000] Size: 1.500MB
P3 (MODEMST2) [0x1585000 0x180000] Size: 1.500MB
P4 (PERSIST) [0x1705000 0x2000000] Size: 32.0MB
P5 (OPPORESERVE1) [0x3705000 0x800000] Size: 8.0MB
P6 (OPPORESERVE2) [0x3f05000 0x4000000] Size: 64.0MB
P7 (RESERVE_EXP1) [0x7f05000 0x200000] Size: 2.0MB
P8 (RESERVE_EXP2) [0x8105000 0x200000] Size: 2.0MB
P9 (FSC) [0x8305000 0x400] Size: 1.0KB
P10 (SSD) [0x8306000 0x2000] Size: 8.0KB
P11 (SBL1) [0x8308000 0x80000] Size: 512.0KB
P12 (RPM) [0x8388000 0x80000] Size: 512.0KB
P13 (TZ) [0x8408000 0x200000] Size: 2.0MB
P14 (DEVCFG) [0x8608000 0x40000] Size: 256.0KB
P15 (SBL1BAK) [0x8648000 0x80000] Size: 512.0KB
P16 (RPMBAK) [0x86c8000 0x80000] Size: 512.0KB
P17 (TZBAK) [0x8748000 0x200000] Size: 2.0MB
P18 (DEVCFGBAK) [0x8948000 0x40000] Size: 256.0KB
P19 (DSP) [0x8988000 0x1000000] Size: 16.0MB
P20 (DDR) [0xa000000 0x8000] Size: 32.0KB
P21 (FSG) [0xa008000 0x180000] Size: 1.500MB
P22 (SEC) [0xa188000 0x4000] Size: 16.0KB
P23 (ABOOT) [0xa18c000 0x100000] Size: 1.0MB
P24 (ABOOTBAK) [0xa28c000 0x100000] Size: 1.0MB
P25 (MODEM) [0xa38c000 0x8000000] Size: 128.0MB
P26 (DTBO) [0x1238c000 0x800000] Size: 8.0MB
P27 (VBMETA) [0x12b8c000 0x10000] Size: 64.0KB
P28 (BOOT) [0x12b9c000 0x4000000] Size: 64.0MB
P29 (RECOVERY) [0x16b9c000 0x4000000] Size: 64.0MB
P30 (DEVINFO) [0x1ab9c000 0x100000] Size: 1.0MB
P31 (SPLASH) [0x1b000000 0xb00000] Size: 11.0MB
P32 (LOGO) [0x1bb00000 0x2000000] Size: 32.0MB
P33 (DRIVER) [0x1db00000 0x2000000] Size: 32.0MB
P34 (CACHE) [0x1fb00000 0x10000000] Size: 256.0MB
P35 (MISC) [0x2fb00000 0x100000] Size: 1.0MB
P36 (KEYSTORE) [0x2fc00000 0x80000] Size: 512.0KB
P37 (CONFIG) [0x2fc80000 0x8000] Size: 32.0KB
P38 (OEM) [0x2fc88000 0x100000] Size: 1.0MB
P39 (LIMITS) [0x30000000 0x8000] Size: 32.0KB
P40 (MOTA) [0x30800000 0x80000] Size: 512.0KB
P41 (DIP) [0x30880000 0x100000] Size: 1.0MB
P42 (MDTP) [0x30980000 0x2000000] Size: 32.0MB
P43 (SYSCFG) [0x32980000 0x80000] Size: 512.0KB
P44 (MCFG) [0x32a00000 0x400000] Size: 4.0MB
P45 (LKSECAPP) [0x33000000 0x20000] Size: 128.0KB
P46 (CMNLIB) [0x33020000 0x100000] Size: 1.0MB
P47 (CMNLIB64) [0x33120000 0x100000] Size: 1.0MB
P48 (KEYMASTER) [0x33220000 0x100000] Size: 1.0MB
P49 (LKSECAPPBAK) [0x33320000 0x20000] Size: 128.0KB
P50 (CMNLIBBAK) [0x33340000 0x100000] Size: 1.0MB
P51 (CMNLIB64BAK) [0x33440000 0x100000] Size: 1.0MB
P52 (KEYMASTERBAK) [0x33540000 0x100000] Size: 1.0MB
P53 (APDP) [0x33800000 0x40000] Size: 256.0KB
P54 (MSADP) [0x33840000 0x40000] Size: 256.0KB
P55 (DPO) [0x33880000 0x2000] Size: 8.0KB
P56 (LOGDUMP) [0x33882000 0x4000000] Size: 64.0MB
P57 (VM-KYSTORE) [0x37882000 0x100000] Size: 1.0MB
P58 (VM-DATA) [0x37982000 0xa00000] Size: 10.0MB
P59 (HYP) [0x38800000 0x800000] Size: 8.0MB
P60 (VM-SYSTEM) [0x39000000 0x4000000] Size: 64.0MB
P61 (VM-LINUX) [0x3d000000 0x2000000] Size: 32.0MB
P62 (SYSTEM) [0x3f000000 0xd6900000] Size: 3.352GB
P63 (VENDOR) [0x115900000 0x41f60000] Size: 1.30GB
P64 (USERDATA) [0x158000000 0x24bdfbe00] Size: 9.184GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB)
Build ID: OPM1.171019.026
Release Base ID: 8.1.0
Architecture ABI: arm64-v8a
Device manufacturer: OPPO
Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20190323.213841 release-keys
Detected USERDATA USERDATA : 0x0158000000 (9.184GB)
Unable to mount USERDATA , code : 95
Done.
Selected eMMC Interface
CMD Pullup Level:1990 mV
CMD Active Level:2588 mV
CLK Rate:14000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
Old 07-13-2019, 09:46   #149 (permalink)
Member: 1246696
Sonork: 000000000
Thanks Meter: 16
oppo a3s unlock done
Old 07-13-2019, 09:50   #150 (permalink)
Member: 1246696
Sonork: 000000000
Thanks Meter: 16
[IMG][/IMG]
Page generated in 0.22863 seconds with 8 queries
