Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 10-13-2018, 18:39   #16 (permalink)
Member: 919695
Sonork: 111
Thanks Meter: 44
Ya I know that but jtag team giving source or only tool other team give successful report but jtag team not helpful post user dead boot repair i think I am in dead boot REPAIR via z3x jtag team that cannot do z3 x box
Now need to buy other bla bla bla tools
I have one more phone you give me Unlock and FRP solution I following you're instructions give me successful reports after I read back 10 hours and uploaded file to others used
Z3x jtag dead boot team go to FRP UNLOCK team now
Sent from my Lenovo A6020a46 using Tapatalk
Old 10-14-2018, 01:07   #17 (permalink)
Member: 13148
Thanks Meter: 1,120
If you not sure, what you doing, you must create backup of ROM's and return it, if anything work wrong
The Following 2 Users Say Thank You to layder For This Useful Post:
Old 10-14-2018, 01:41   #18 (permalink)
Member: 919695
Sonork: 111
Thanks Meter: 44
I try to back up first it ask more then 10 hours after I will stop .... OK bro any way now I have another one mobile how to back up first and how to remove screen lock and frp unlock without dead risk give me clear producer
Old 10-14-2018, 09:42   #19 (permalink)
Member: 13148
Thanks Meter: 1,120
To remove frp press button "Remove FRP"
To remove pattern or password lock - "Remove Androids locks" (if userdata not encrypted)
The Following User Says Thank You to layder For This Useful Post:
Old 10-14-2018, 09:57   #20 (permalink)
Member: 919695
Sonork: 111
Thanks Meter: 44
This modle user data encrypt. Mobile on screen lock how to Unlock
Old 10-14-2018, 10:03   #21 (permalink)
Member: 13148
Thanks Meter: 1,120
No way to work with crypted userdata at now
Old 10-14-2018, 14:41   #22 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 436
can we write userdata partition only?
Old 10-18-2018, 07:19   #23 (permalink)
Pratheesh T K's Avatar
Member: 866865
Sonork: 1645198
Thanks Meter: 179
Nice Trend And it is help us to study
but for to remove frp from oppo phones try to dial *#812# or *812#
it will exit from frp menu
Old 10-19-2018, 04:23   #24 (permalink)
Member: 1847344
Thanks Meter: 289
a3s oppo dead after reset pin lock
same problem please help
Looking for EasyJTAG box...
17/10/2018 11:12:25 AM> EasyJTAG API ver. 2100
17/10/2018 11:12:25 AM> Setting IO Levels to 1.8V
17/10/2018 11:12:25 AM> Setting frequence to 14 Mhz
17/10/2018 11:12:25 AM> EasyJTAG Box Serial = 0801200905155BD8
17/10/2018 11:12:25 AM> EasyJTAG Box Firmware = 1.63
17/10/2018 11:12:26 AM> Setting frequence to 14 Mhz
17/10/2018 11:12:26 AM> CMD Pullup Level: 1722 mV
17/10/2018 11:12:26 AM> CMD Active Level: 1773 mV
17/10/2018 11:12:26 AM> eMMC Init returned = 0
17/10/2018 11:12:26 AM> EMMC Device Information :
17/10/2018 11:12:26 AM> EMMC CID: 90014A68423861503E03662A01A7759C
17/10/2018 11:12:26 AM> EMMC CSD: D02700328F5903FFFFFFFFEF8E400042
17/10/2018 11:12:26 AM> EMMC Manufacture : SKHYNIX , EMMC NAME: hB8aP> , HEX: 68423861503E , S/N: 662A01A7 , rev. 0x03
17/10/2018 11:12:26 AM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 7/2018
17/10/2018 11:12:26 AM> EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000)
17/10/2018 11:12:26 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
17/10/2018 11:12:26 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000)
17/10/2018 11:12:26 AM> EMMC Permanent Write Protection: No
17/10/2018 11:12:26 AM> EMMC Temporary Write Protection: No
17/10/2018 11:12:26 AM> Extended CSD Information :
17/10/2018 11:12:26 AM> Extended CSD rev: 1.8 (MMC 5.1)
17/10/2018 11:12:26 AM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
17/10/2018 11:12:26 AM> Boot Bus Config: 0x00 , width 1bit
17/10/2018 11:12:26 AM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
17/10/2018 11:12:26 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
17/10/2018 11:12:26 AM> Device supports partitioning features
17/10/2018 11:12:27 AM> Device can have enhanced technological features in partitions and user data area
17/10/2018 11:12:27 AM> Device can have extended partitions attribute
17/10/2018 11:12:27 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
17/10/2018 11:12:27 AM> Backup saved: hB8aP__662A01A7_20181017_111227.extcsd
17/10/2018 11:12:27 AM> EMMC Init completed.
17/10/2018 11:12:33 AM> Mount [persist] successfully PartType: LINUX
17/10/2018 11:12:33 AM> Mount [opporeserve] successfully PartType: LINUX
17/10/2018 11:12:34 AM> Mount [dsp] successfully PartType: LINUX
17/10/2018 11:12:34 AM> Mount [modem] successfully PartType: FAT16
17/10/2018 11:12:34 AM> Mount [cache] successfully PartType: LINUX
17/10/2018 11:12:34 AM> Mount [system] successfully PartType: LINUX
17/10/2018 11:12:35 AM> Mount [vendor] successfully PartType: LINUX
17/10/2018 11:12:35 AM> Mount [userdata] SKIPPED PartType: Full Disk Encryption
17/10/2018 11:12:37 AM> Error: Journal_stop [system/] failed
17/10/2018 11:12:37 AM> Error: Journal_stop [vendor/] failed
17/10/2018 11:12:37 AM> All done
17/10/2018 11:14:59 AM> Looking for EasyJTAG box...
17/10/2018 11:14:59 AM> EasyJTAG API ver. 2100
17/10/2018 11:14:59 AM> Setting IO Levels to 2.8V
17/10/2018 11:14:59 AM> Setting frequence to 14 Mhz
17/10/2018 11:14:59 AM> EasyJTAG Box Serial = 0801200905155BD8
17/10/2018 11:14:59 AM> EasyJTAG Box Firmware = 1.63
17/10/2018 11:15:01 AM> Setting frequence to 14 Mhz
17/10/2018 11:15:01 AM> CMD Pullup Level: 2052 mV
17/10/2018 11:15:01 AM> CMD Active Level: 2413 mV
17/10/2018 11:15:13 AM> eMMC Init returned = -101
17/10/2018 11:15:13 AM> Can't init device. Reason: CARD Ready Timeout Error
17/10/2018 11:15:16 AM> Looking for EasyJTAG box...
17/10/2018 11:15:16 AM> EasyJTAG API ver. 2100
17/10/2018 11:15:16 AM> Setting IO Levels to 2.8V
17/10/2018 11:15:16 AM> Setting frequence to 14 Mhz
17/10/2018 11:15:16 AM> EasyJTAG Box Serial = 0801200905155BD8
17/10/2018 11:15:16 AM> EasyJTAG Box Firmware = 1.63
17/10/2018 11:15:18 AM> Setting frequence to 14 Mhz
17/10/2018 11:15:18 AM> CMD Pullup Level: 278 mV
17/10/2018 11:15:18 AM> CMD Active Level: 2248 mV
17/10/2018 11:15:18 AM> eMMC Init returned = -1
17/10/2018 11:15:18 AM> Can't init device. Reason: CMD Timeout Error
17/10/2018 11:15:20 AM> Looking for EasyJTAG box...
17/10/2018 11:15:20 AM> EasyJTAG API ver. 2100
17/10/2018 11:15:20 AM> Setting IO Levels to 2.8V
17/10/2018 11:15:20 AM> Setting frequence to 14 Mhz
17/10/2018 11:15:20 AM> EasyJTAG Box Serial = 0801200905155BD8
17/10/2018 11:15:20 AM> EasyJTAG Box Firmware = 1.63
17/10/2018 11:15:21 AM> Setting frequence to 14 Mhz
17/10/2018 11:15:21 AM> CMD Pullup Level: 2052 mV
17/10/2018 11:15:21 AM> CMD Active Level: 2413 mV
17/10/2018 11:15:33 AM> eMMC Init returned = -101
17/10/2018 11:15:33 AM> Can't init device. Reason: CARD Ready Timeout Error
17/10/2018 11:15:37 AM> Looking for EasyJTAG box...
17/10/2018 11:15:37 AM> EasyJTAG API ver. 2100
17/10/2018 11:15:37 AM> Setting IO Levels to 1.8V (ISP)
17/10/2018 11:15:37 AM> Setting frequence to 14 Mhz
17/10/2018 11:15:37 AM> EasyJTAG Box Serial = 0801200905155BD8
17/10/2018 11:15:37 AM> EasyJTAG Box Firmware = 1.63
17/10/2018 11:15:39 AM> Setting frequence to 14 Mhz
17/10/2018 11:15:39 AM> CMD Pullup Level: 1753 mV
17/10/2018 11:15:39 AM> CMD Active Level: 1825 mV
17/10/2018 11:15:39 AM> eMMC Init returned = 0
17/10/2018 11:15:39 AM> EMMC Device Information :
17/10/2018 11:15:39 AM> EMMC CID: 90014A68423861503E03662A01A7759C
17/10/2018 11:15:39 AM> EMMC CSD: D02700328F5903FFFFFFFFEF8E400042
17/10/2018 11:15:39 AM> EMMC Manufacture : SKHYNIX , EMMC NAME: hB8aP> , HEX: 68423861503E , S/N: 662A01A7 , rev. 0x03
17/10/2018 11:15:39 AM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 7/2018
17/10/2018 11:15:39 AM> EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000)
17/10/2018 11:15:39 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
17/10/2018 11:15:39 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000)
17/10/2018 11:15:39 AM> EMMC Permanent Write Protection: No
17/10/2018 11:15:39 AM> EMMC Temporary Write Protection: No
17/10/2018 11:15:39 AM> Extended CSD Information :
17/10/2018 11:15:40 AM> Extended CSD rev: 1.8 (MMC 5.1)
17/10/2018 11:15:40 AM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
17/10/2018 11:15:40 AM> Boot Bus Config: 0x00 , width 1bit
17/10/2018 11:15:40 AM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
17/10/2018 11:15:40 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
17/10/2018 11:15:40 AM> Device supports partitioning features
17/10/2018 11:15:40 AM> Device can have enhanced technological features in partitions and user data area
17/10/2018 11:15:40 AM> Device can have extended partitions attribute
17/10/2018 11:15:40 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
17/10/2018 11:15:40 AM> Backup saved: hB8aP__662A01A7_20181017_111540.extcsd
17/10/2018 11:15:40 AM> EMMC Init completed.
17/10/2018 11:15:40 AM> Scanning soft partitions
17/10/2018 11:15:40 AM> GPT header is found and is valid
17/10/2018 11:15:40 AM> Partition: oppodycnvbk, [000000005000 - 000000A05000], size: 000000A00000 (10.0 MB)
17/10/2018 11:15:40 AM> Partition: oppostanvbk, [000000A05000 - 000001405000], size: 000000A00000 (10.0 MB)
17/10/2018 11:15:40 AM> Partition: modemst1, [000001405000 - 000001585000], size: 000000180000 (1.50 MB)
17/10/2018 11:15:40 AM> Partition: modemst2, [000001585000 - 000001705000], size: 000000180000 (1.50 MB)
17/10/2018 11:15:40 AM> Partition: persist, [000001705000 - 000003705000], size: 000002000000 (32.0 MB)
17/10/2018 11:15:40 AM> Partition: opporeserve1, [000003705000 - 000003F05000], size: 000000800000 (8.00 MB)
17/10/2018 11:15:40 AM> Partition: opporeserve2, [000003F05000 - 000007F05000], size: 000004000000 (64.0 MB)
17/10/2018 11:15:40 AM> Partition: reserve_exp1, [000007F05000 - 000008105000], size: 000000200000 (2.00 MB)
17/10/2018 11:15:40 AM> Partition: reserve_exp2, [000008105000 - 000008305000], size: 000000200000 (2.00 MB)
17/10/2018 11:15:40 AM> Partition: fsc, [000008305000 - 000008305400], size: 000000000400 (1.00 KB)
17/10/2018 11:15:40 AM> Partition: ssd, [000008306000 - 000008308000], size: 000000002000 (8.00 KB)
17/10/2018 11:15:40 AM> Partition: sbl1, [000008308000 - 000008388000], size: 000000080000 (512. KB)
17/10/2018 11:15:40 AM> Partition: rpm, [000008388000 - 000008408000], size: 000000080000 (512. KB)
17/10/2018 11:15:40 AM> Partition: tz, [000008408000 - 000008608000], size: 000000200000 (2.00 MB)
17/10/2018 11:15:40 AM> Partition: devcfg, [000008608000 - 000008648000], size: 000000040000 (256. KB)
17/10/2018 11:15:40 AM> Partition: sbl1bak, [000008648000 - 0000086C8000], size: 000000080000 (512. KB)
17/10/2018 11:15:40 AM> Partition: rpmbak, [0000086C8000 - 000008748000], size: 000000080000 (512. KB)
17/10/2018 11:15:40 AM> Partition: tzbak, [000008748000 - 000008948000], size: 000000200000 (2.00 MB)
17/10/2018 11:15:40 AM> Partition: devcfgbak, [000008948000 - 000008988000], size: 000000040000 (256. KB)
17/10/2018 11:15:40 AM> Partition: dsp, [000008988000 - 000009988000], size: 000001000000 (16.0 MB)
17/10/2018 11:15:40 AM> Partition: DDR, [00000A000000 - 00000A008000], size: 000000008000 (32.0 KB)
17/10/2018 11:15:40 AM> Partition: fsg, [00000A008000 - 00000A188000], size: 000000180000 (1.50 MB)
17/10/2018 11:15:40 AM> Partition: sec, [00000A188000 - 00000A18C000], size: 000000004000 (16.0 KB)
17/10/2018 11:15:40 AM> Partition: aboot, [00000A18C000 - 00000A28C000], size: 000000100000 (1.00 MB)
17/10/2018 11:15:40 AM> Partition: abootbak, [00000A28C000 - 00000A38C000], size: 000000100000 (1.00 MB)
17/10/2018 11:15:40 AM> Partition: modem, [00000A38C000 - 00001238C000], size: 000008000000 (128. MB)
17/10/2018 11:15:40 AM> Partition: dtbo, [00001238C000 - 000012B8C000], size: 000000800000 (8.00 MB)
17/10/2018 11:15:40 AM> Partition: vbmeta, [000012B8C000 - 000012B9C000], size: 000000010000 (64.0 KB)
17/10/2018 11:15:40 AM> Partition: boot, [000012B9C000 - 000016B9C000], size: 000004000000 (64.0 MB)
17/10/2018 11:15:40 AM> Partition: recovery, [000016B9C000 - 00001AB9C000], size: 000004000000 (64.0 MB)
17/10/2018 11:15:40 AM> Partition: devinfo, [00001AB9C000 - 00001AC9C000], size: 000000100000 (1.00 MB)
17/10/2018 11:15:40 AM> Partition: splash, [00001B000000 - 00001BB00000], size: 000000B00000 (11.0 MB)
17/10/2018 11:15:40 AM> Partition: LOGO, [00001BB00000 - 00001DB00000], size: 000002000000 (32.0 MB)
17/10/2018 11:15:40 AM> Partition: DRIVER, [00001DB00000 - 00001FB00000], size: 000002000000 (32.0 MB)
17/10/2018 11:15:40 AM> Partition: cache, [00001FB00000 - 00002FB00000], size: 000010000000 (256. MB)
17/10/2018 11:15:40 AM> Partition: misc, [00002FB00000 - 00002FC00000], size: 000000100000 (1.00 MB)
17/10/2018 11:15:40 AM> Partition: keystore, [00002FC00000 - 00002FC80000], size: 000000080000 (512. KB)
17/10/2018 11:15:40 AM> Partition: config, [00002FC80000 - 00002FC88000], size: 000000008000 (32.0 KB)
17/10/2018 11:15:40 AM> Partition: oem, [00002FC88000 - 00002FD88000], size: 000000100000 (1.00 MB)
17/10/2018 11:15:40 AM> Partition: limits, [000030000000 - 000030008000], size: 000000008000 (32.0 KB)
17/10/2018 11:15:40 AM> Partition: mota, [000030800000 - 000030880000], size: 000000080000 (512. KB)
17/10/2018 11:15:40 AM> Partition: dip, [000030880000 - 000030980000], size: 000000100000 (1.00 MB)
17/10/2018 11:15:40 AM> Partition: mdtp, [000030980000 - 000032980000], size: 000002000000 (32.0 MB)
17/10/2018 11:15:40 AM> Partition: syscfg, [000032980000 - 000032A00000], size: 000000080000 (512. KB)
17/10/2018 11:15:40 AM> Partition: mcfg, [000032A00000 - 000032E00000], size: 000000400000 (4.00 MB)
17/10/2018 11:15:40 AM> Partition: lksecapp, [000033000000 - 000033020000], size: 000000020000 (128. KB)
17/10/2018 11:15:40 AM> Partition: cmnlib, [000033020000 - 000033120000], size: 000000100000 (1.00 MB)
17/10/2018 11:15:40 AM> Partition: cmnlib64, [000033120000 - 000033220000], size: 000000100000 (1.00 MB)
17/10/2018 11:15:40 AM> Partition: keymaster, [000033220000 - 000033320000], size: 000000100000 (1.00 MB)
17/10/2018 11:15:40 AM> Partition: lksecappbak, [000033320000 - 000033340000], size: 000000020000 (128. KB)
17/10/2018 11:15:40 AM> Partition: cmnlibbak, [000033340000 - 000033440000], size: 000000100000 (1.00 MB)
17/10/2018 11:15:40 AM> Partition: cmnlib64bak, [000033440000 - 000033540000], size: 000000100000 (1.00 MB)
17/10/2018 11:15:40 AM> Partition: keymasterbak, [000033540000 - 000033640000], size: 000000100000 (1.00 MB)
17/10/2018 11:15:40 AM> Partition: apdp, [000033800000 - 000033840000], size: 000000040000 (256. KB)
17/10/2018 11:15:40 AM> Partition: msadp, [000033840000 - 000033880000], size: 000000040000 (256. KB)
17/10/2018 11:15:41 AM> Partition: dpo, [000033880000 - 000033882000], size: 000000002000 (8.00 KB)
17/10/2018 11:15:41 AM> Partition: logdump, [000033882000 - 000037882000], size: 000004000000 (64.0 MB)
17/10/2018 11:15:41 AM> Partition: vm-kystore, [000037882000 - 000037982000], size: 000000100000 (1.00 MB)
17/10/2018 11:15:41 AM> Partition: vm-data, [000037982000 - 000038382000], size: 000000A00000 (10.0 MB)
17/10/2018 11:15:41 AM> Partition: hyp, [000038800000 - 000039000000], size: 000000800000 (8.00 MB)
17/10/2018 11:15:41 AM> Partition: vm-system, [000039000000 - 00003D000000], size: 000004000000 (64.0 MB)
17/10/2018 11:15:41 AM> Partition: vm-linux, [00003D000000 - 00003F000000], size: 000002000000 (32.0 MB)
17/10/2018 11:15:41 AM> Partition: system, [00003F000000 - 000115900000], size: 0000D6900000 (3.35 GB)
17/10/2018 11:15:41 AM> Partition: vendor, [000115900000 - 000157860000], size: 000041F60000 (1.03 GB)
17/10/2018 11:15:41 AM> Partition: userdata, [000158000000 - 000747BFBE00], size: 0005EFBFBE00 (23.7 GB)
17/10/2018 11:15:41 AM> GPT header successfully parsed
17/10/2018 11:15:41 AM> Get firmware version
17/10/2018 11:15:48 AM> Error: Unmount [system/] failed
17/10/2018 11:15:48 AM> Error: Unmount [vendor/] failed
17/10/2018 11:15:48 AM> Manufacturer = OPPO
17/10/2018 11:15:48 AM> CPU Abi = arm64-v8a
17/10/2018 11:15:48 AM> Android release = 8.1.0
Old 12-31-2018, 15:36   #25 (permalink)
Member: 1916471
Sonork: 100.1637842
Thanks Meter: 62
OPPO A3s Unlock Done
OPPO A3s Unlock With Frp Done
The Following 20 Users Say Thank You to babamobilecares For This Useful Post:
Old 12-31-2018, 15:53   #26 (permalink)
Member: 1916471
Sonork: 100.1637842
Thanks Meter: 62
Oppo a3s lock and frp remove method 💯 success
The Following User Says Thank You to babamobilecares For This Useful Post:
Old 01-01-2019, 16:50   #27 (permalink)
bronce's Avatar
Member: 488875
Sonork: 100.1626294
Thanks Meter: 1,099
Pls..share the isp pinout.
Tia,
Old 01-03-2019, 04:26   #28 (permalink)
Member: 704044
Thanks Meter: 177
Originally Posted by babamobilecares View Post
oppo a3s unlock with frp done
pinout share here bro
The Following User Says Thank You to sekarrajan For This Useful Post:
Old 01-03-2019, 04:56   #29 (permalink)
Member: 969145
Thanks Meter: 19
https://drive.google.com/file/d/150U...w?usp=drivesdk
A3s emmc pinouts
The Following 5 Users Say Thank You to saurabh singh For This Useful Post:
Old 01-03-2019, 04:59   #30 (permalink)
Member: 704044
Thanks Meter: 177
Originally Posted by saurabh singh View Post
please check link not open bro
Page generated in 0.20816 seconds with 8 queries
