01-05-2019, 11:35 | #33 (permalink) | |
No Life Poster Join Date: Aug 2011
Member: 1630066 Status: Offline Sonork: 520074 Thanks Meter: 215 | Quote:
and for read by vender visit this https://www.youtube.com/watch?v=JvwD6kC0VdI for making dump file visit this https://www.youtube.com/watch?v=tdTgsKDF8dY for full easy jtag training visit this youtube channel https://www.youtube.com/channel/UCPR..._as=subscriber | |
The Following 5 Users Say Thank You to ilyasrao For This Useful Post: |
01-07-2019, 12:30 | #36 (permalink) |
No Life Poster Join Date: Nov 2005 Location: morrocco
Member: 201359 Status: Offline Sonork: 100.1607870 Thanks Meter: 128 | the second one not done also stuck at oppo logo 2 phone bricked with easy jtag ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4203A3A7E4CE75EC eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2018 Rev.0x3 eMMC NAME: QE63MB , S/N: 2745689294 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 30535646 Partition info successfully found ------ Android information ------ Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) Read EXT fs info Read EXT fs info Created filesystem with parameters: Size: 268435456 Block size: 1024 Blocks per group: 32768 Inodes per group: 2048 Inode size: 256 Inodes: 16384 Label: Format EXT fs... Returned 28... Read EXT fs info NEW Created filesystem with parameters: Size: 268435456 Block size: 1024 Blocks per group: 32768 Inodes per group: 2048 Inode size: 256 Inodes: 16384 Label: Detected LINUX(Android) USERDATA : 0x0158000000 (9.184GB) Read EXT fs info Read EXT fs info Created filesystem with parameters: Size: 268435456 Block size: 1024 Blocks per group: 32768 Inodes per group: 2048 Inode size: 256 Inodes: 16384 Label: Format EXT fs... Returned 28... Read EXT fs info NEW Created filesystem with parameters: Size: 268435456 Block size: 1024 Blocks per group: 32768 Inodes per group: 2048 Inode size: 256 Inodes: 16384 Label: --------------------------------------------- Done. Z3X EasyJtag Software ver. 3.4.0.2 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0F00E00C0D23EDA9, ,FW Ver.: 01.63 CMD Pullup Level:1722 mV CMD Active Level:2609 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4203A3A7E4CE75EC eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2018 Rev.0x3 eMMC NAME: QE63MB , S/N: 2745689294 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 30535646 Partition info successfully found ------ Android information ------ Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) Read EXT fs info Read EXT fs info Created filesystem with parameters: Size: 268435456 Block size: 1024 Blocks per group: 32768 Inodes per group: 2048 Inode size: 256 Inodes: 16384 Label: Format EXT fs... Returned 28... Read EXT fs info NEW Created filesystem with parameters: Size: 268435456 Block size: 1024 Blocks per group: 32768 Inodes per group: 2048 Inode size: 256 Inodes: 16384 Label: Detected LINUX(Android) USERDATA : 0x0158000000 (9.184GB) Read EXT fs info Read EXT fs info Created filesystem with parameters: Size: 268435456 Block size: 1024 Blocks per group: 32768 Inodes per group: 2048 Inode size: 256 Inodes: 16384 Label: Format EXT fs... Returned 28... Read EXT fs info NEW Created filesystem with parameters: Size: 268435456 Block size: 1024 Blocks per group: 32768 Inodes per group: 2048 Inode size: 256 Inodes: 16384 Label: --------------------------------------------- Done. |
The Following User Says Thank You to ALLNEWGSM For This Useful Post: |
01-22-2019, 21:12 | #38 (permalink) |
Insane Poster Join Date: Feb 2017 Location: India
Member: 2683601 Status: Offline Thanks Meter: 46 | Oppo A3s unlock Done!!! Oppo A3s unlock with east jtag just click format userdata and done! Sent from my Mi A1 using Tapatalk |
The Following User Says Thank You to Dev bhalla For This Useful Post: |
02-15-2019, 14:38 | #41 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Sydney
Member: 153695 Status: Offline Sonork: srkhan Thanks Meter: 788 | Quote: "QE63MB_2946621656_20190213_2100.extcsd" eay-jtag cant save any log! just auto backup excsd | |
02-15-2019, 14:48 | #42 (permalink) | |
Freak Poster Join Date: Apr 2010 Location: lucknow u.p.india Age: 35
Member: 1284209 Status: Offline Sonork: 100.1614938 Thanks Meter: 137 | Quote:
02-17-2019, 00:08 | #44 (permalink) |
No Life Poster Join Date: Nov 2006 Location: GOOD
Member: 388862 Status: Offline Thanks Meter: 107 | z3x not done after format and reset frp phone stuck in oppo logo!!!!!!!!!!!!!!!!!!! A3s A5 is dead !!!! ufi is ok!!!!!!! waiting Z3X update!!!!!!!!!!!!!!!!!!!!! |
02-17-2019, 06:55 | #45 (permalink) | |
Freak Poster Join Date: Jul 2008
Member: 818380 Status: Offline Thanks Meter: 56 | Quote:
The Following 2 Users Say Thank You to duythangvn For This Useful Post: |
