oppo a3s cant detect i got 1pcs cph1803 and 1pcs cph1853 with this emmc h9tq27adftmcur-kum same error like this Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 01FF801925CE6B82, ,FW Ver.: 01.63 CMD Pullup Level:2052 mV CMD Active Level:2392 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CARD Ready Timeout Error how to solve this problem |
oppo A3S not detected Found 3 serial devices COM6 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Control Port (COM6) COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1) COM5 USB\VID_05C6&PID_9008&REV_0000 Qualcomm HS-USB QDLoader 9008 (COM5) Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.1.4 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0F01300C22E581EB, ,FW Ver.: 01.63 CMD Pullup Level:1990 mV CMD Active Level:2557 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.6.1.4 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0F01300C22E581EB, ,FW Ver.: 01.63 CMD Pullup Level:1980 mV CMD Active Level:2547 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. http://i64.tinypic.com/1zykgug.png |
just check cmd donly and use usb to power handset sold only cmd clk d0 |
check cmd do clk. use usb cable dont use battery. |
sold wire is good..yes i just sold cmd-clk and do. |
and now..device stuck on qualcomm 8009. |
any solution a3s stuck on 9008??? |
check clk,cmd resistor, maybe damage |
i have same problem . |
on CLK rATE select ---1mhz OI voltage select isp |
if damage..what should i do..? |
problem solved after make jumper.. |
remove register & make jumper i have same problem help me thanks |
