Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 06-27-2019, 08:36   #1 (permalink)
Member: 2353294
Thanks Meter: 4
oppo a3s cant detect
i got 1pcs cph1803 and 1pcs cph1853 with this emmc h9tq27adftmcur-kum same error like this
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 01FF801925CE6B82, ,FW Ver.: 01.63
CMD Pullup Level:2052 mV
CMD Active Level:2392 mV
Box IO Level:2800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
Can't init device, Reason: CARD Ready Timeout Error
how to solve this problem
Old 07-01-2019, 09:30   #2 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 811
oppo A3S not detected
Found 3 serial devices
COM6 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Control Port (COM6)
COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1)
COM5 USB\VID_05C6&PID_9008&REV_0000 Qualcomm HS-USB QDLoader 9008 (COM5)
Selected pinout: EasyJTAG GEN1 ISP Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.6.1.4
Box S/N: 0F01300C22E581EB, ,FW Ver.: 01.63
CMD Pullup Level:1990 mV
CMD Active Level:2557 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Can't init device, Reason: CMD Timeout Error
Done.
CMD Pullup Level:1980 mV
CMD Active Level:2547 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
Old 07-01-2019, 09:53   #3 (permalink)
Member: 2288140
Thanks Meter: 44
just check cmd donly and use usb to power handset sold only cmd clk d0
Old 07-01-2019, 10:15   #4 (permalink)
Member: 1429499
Thanks Meter: 24
check cmd do clk. use usb cable dont use battery.
Old 07-01-2019, 10:17   #5 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 811
sold wire is good..yes i just sold cmd-clk and do.
Old 07-02-2019, 05:59   #6 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 811
and now..device stuck on qualcomm 8009.
Old 07-02-2019, 07:35   #7 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 811
any solution a3s stuck on 9008???
Old 07-02-2019, 08:13   #8 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 454
check clk,cmd resistor, maybe damage
Old 07-02-2019, 08:39   #9 (permalink)
Member: 2914785
i have same problem .
Old 07-02-2019, 08:45   #10 (permalink)
Crazy Poster
Member: 1316900
Sonork: none
Thanks Meter: 30
on CLK rATE select ---1mhz OI voltage select isp
The Following 2 Users Say Thank You to d'starter For This Useful Post:
Old 07-02-2019, 13:51   #11 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 811
if damage..what should i do..?
Old 07-02-2019, 16:45   #12 (permalink)
Member: 13148
Thanks Meter: 1,587
You need replace it to some.
The Following User Says Thank You to layder For This Useful Post:
Old 07-03-2019, 04:46   #13 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 811
problem solved after make jumper..
Old 07-03-2019, 04:52   #14 (permalink)
Member: 2746336
Sonork: NULL
Thanks Meter: 22
Please explain in details, where did you make jumper? And also tell if after jumper are you able to connect with easy jtag?
Old 07-03-2019, 06:30   #15 (permalink)
Member: 2471614
Thanks Meter: 2
remove register & make jumper i have same problem
help me thanks
Page generated in 0.34309 seconds with 8 queries
