Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 07-03-2019, 11:20   #16 (permalink)
Member: 13148
Thanks Meter: 1,588
remove phone from client and retunt to he brick - good idea
remove resistor and make jumper.....
remove USB block charger from AC power and make jumper .....
Do you understand what you doing?
The Following User Says Thank You to layder For This Useful Post:
Old 07-03-2019, 14:38   #17 (permalink)
reaz.com's Avatar
Member: 310155
Thanks Meter: 1,305
connect gnd line direct to mother board, not any screw hole................
Old 07-03-2019, 22:54   #18 (permalink)
Member: 591084
Thanks Meter: 35
oppo a3s error identify
Z3X EasyJtag Software ver. 3.6.1.9
Loading eMMC GEN1 Firmware... IO: 3300 mV
Box S/N: 0D01300C9DDE17D1, ,FW Ver.: 01.63
CMD Pullup Level:2093 mV
CMD Active Level:2557 mV
Box IO Level:3300 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 90014A68423861503E03169A992975FE
eMMC CSD : D02700328F5903FFFFFFFFEF8E400042
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 07/2018 Rev.0x3
eMMC NAME: hB8aP> , S/N: 379230505
eMMC NAME (HEX): 68423861503E
EMMC ROM1 (Main User Data) Capacity: 29820 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
RPMB Info mmc_switch_part Error, Reason: CARD Ready Timeout Error
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: hB8aP>_ 379230505_20190703_2351.extcsd
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326
Partition info successfully found
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB)
Build ID: OPM1.171019.026
Release Base ID: 8.1.0
Architecture ABI: arm64-v8a
Device manufacturer: OPPO
Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20190323.213841 release-keys
Detected USERDATA USERDATA : 0x0158000000 (23.745GB)
Unable to mount USERDATA , code : 95
Done.
what is that error
Old 07-04-2019, 05:01   #19 (permalink)
gayansuranga's Avatar
Member: 230004
Thanks Meter: 155
disconnect the jtag connections and turn on the phone wait till it starts then turn it off and start over again the jtag process . I it must be user data partitions not initialized properly due to abnormal shut downs.
The Following User Says Thank You to gayansuranga For This Useful Post:
Old 07-05-2019, 11:56   #20 (permalink)
Member: 1409573
Sonork: 100.1615416
Thanks Meter: 60
oppo a3s not conect
oppo a3s not conect
MMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019)
7/5/2019 12:56:52 PM> Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385)
7/5/2019 12:56:52 PM> Looking for EasyJTAG box...
7/5/2019 12:56:52 PM> EasyJTAG API ver. 3307
7/5/2019 12:56:55 PM> OpenUSB returned = 0
7/5/2019 12:56:56 PM> EasyJTAG Box Serial = 07FFA00BB62EEC02
7/5/2019 12:56:57 PM> Card Serial = AA3D83FD
7/5/2019 12:56:57 PM> EasyJTAG Box Firmware = 1.63
7/5/2019 12:57:15 PM> Looking for EasyJTAG box...
7/5/2019 12:57:15 PM> EasyJTAG API ver. 3307
7/5/2019 12:57:15 PM> Setting IO Levels to 1.8V
7/5/2019 12:57:15 PM> Setting frequence to 21 MHz
7/5/2019 12:57:16 PM> EasyJTAG Box Serial = 07FFA00BB62EEC02
7/5/2019 12:57:16 PM> EasyJTAG Box Firmware = 1.63
7/5/2019 12:57:19 PM> HiPower mode is ON
7/5/2019 12:57:19 PM> Setting frequence to 21 MHz
7/5/2019 12:57:19 PM> CMD Pullup Level: 247 mV
7/5/2019 12:57:19 PM> CMD Active Level: 2000 mV
7/5/2019 12:57:19 PM> eMMC Init returned = -1
7/5/2019 12:57:19 PM> Can't init device. Reason: CMD Timeout Error
Old 07-05-2019, 12:29   #21 (permalink)
Member: 1409573
Sonork: 100.1615416
Thanks Meter: 60
now clk resister missing by my mistake now stuck on quellcomm port only phone not power on
is compatible MOORCK emmc adapter for emmc repair ? I have not good skill to emmc repair
but I am trying to with easy jtag experts so please help me as a newcomer
Old 07-05-2019, 13:41   #22 (permalink)
ChandruChiyyan's Avatar
Member: 660093
Sonork: 100.1602344
Thanks Meter: 271
Just make short clk lines your phone should on After clk lines short
The Following User Says Thank You to ChandruChiyyan For This Useful Post:
Old 07-05-2019, 13:48   #23 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 454
do we need to remove CLK resistor to connect via direct emmc?
i have 2 unit A3s 1803 model
16gb samsung emmc done via oppo reset but the unit with 32gb hynix emmc cannot connect, always say "Can't init device, Reason: CARD Ready Timeout Error "..
Old 07-05-2019, 13:52   #24 (permalink)
Member: 660093
Sonork: 100.1602344
Thanks Meter: 271
16gb samsung emmc done via oppo reset but the unit with 32gb hynix emmc cannot connect, always say "cmd error: Card not ready"..
No need to remove clk resistor for direct connect Emmc...Maybe your connection not well in cmd line please check ..
Old 07-05-2019, 13:57   #25 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 454
same problem here, A3s (1803) 32Gb Hynix eMMC
always "Can't init device, Reason: CARD Ready Timeout Error"
The Following User Says Thank You to rico_deep For This Useful Post:
Old 07-05-2019, 14:07   #26 (permalink)
Member: 1018623
coba pakai adapter ufi
Old 07-05-2019, 14:14   #27 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 454
my adaptor is working on A3s(1803) and A3s(1853) with 16gb samsung eMMC
Old 07-05-2019, 14:22   #28 (permalink)
Member: 13148
Thanks Meter: 1,588
http://forum.gsmhosting.com/vbb/f672...-jtag-2636216/
Old 07-05-2019, 14:27   #29 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 454
Originally Posted by layder View Post
no problem with A3s with samsung emmc, hynix emmc how ever give us error
Old 07-05-2019, 17:52   #30 (permalink)
Member: 1409573
Sonork: 100.1615416
Thanks Meter: 60
after short clk line pone switch on yhanks to ChandruChiyyan;13723164
why cannot read Hynix eMMC by easy jtag? any solution?
Page generated in 0.35422 seconds with 8 queries
