01-10-2018, 08:45 | #2 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Compression is ON Z3X EasyJtag Software ver. 2.9.0.0 Loading eMMC GEN1 Firmware... IO: 1850 mV Box S/N: 0500D01E3BC5A469, ,FW Ver.: 01.62 CMD Pullup Level:897 mV CMD Active Level:11830 mV Box IO Level:1850 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. |
01-10-2018, 13:52 | #3 (permalink) | |
Freak Poster Join Date: Jul 2011 Location: Dhaka,Uttara.Bangaladash
Member: 1625192 Status: Offline Sonork: 100.1657037 Thanks Meter: 256 | Quote:
(Last EMMC DEAD) | |
01-13-2018, 07:19 | #5 (permalink) |
Member: 2556542 Status: Offline Thanks Meter: 1,790 | after install old version show this Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 1850 mV Box S/N: xxxxxxxxx, ,FW Ver.: 01.62 CMD Pullup Level:1742 mV CMD Active Level:1815 mV Box IO Level:1850 mV CLK Rate:14000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. |
01-13-2018, 07:23 | #6 (permalink) |
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0500D01E3BC5A469, ,FW Ver.: 01.62 CMD Pullup Level:2072 mV CMD Active Level:2433 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 45010053454D3034472808888BCA90A4 EMMC CSD : D00F00320F5903FFFFFFFDFF8A4040A6 EMMC Manufacturer ID: 0045 , OEM ID: 0100 EMMC Date: 09/2013 Rev.0x28 EMMC NAME: SEM04G , S/N: 143166410 EMMC NAME (HEX): 53454D30344700 EMMC ROM1 (Main User Data) Capacity: 3776 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x01 Device support partitioning feature Device cannot have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: SEM04G_ 143166410_20180112_2222.extcsd Done. |
01-13-2018, 07:35 | #7 (permalink) |
Member: 2556542 Status: Offline Thanks Meter: 1,790 | 3X EasyJtag Software ver. 2.6.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:2041 mV CMD Active Level:2423 mV Length limit is enabled! Input file : C:\Users\ktha\Desktop\Sony_C1904_emmc_direct_dump\ EMMC_ROM1_00000000_08000000.bin Writing 0000000200 bytes to 0000000000... ROM1 (USER ROM) Done. Write Speed: 3 kB/s Z3X EasyJtag Software ver. 2.6.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:2041 mV CMD Active Level:2423 mV Input file : C:\Users\ktha\Desktop\Sony_C1904_emmc_direct_dump\ EMMC_ROM2_00000000_00200000.bin Writing 0000200000 bytes to 0000000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 1600 kB/s Z3X EasyJtag Software ver. 2.6.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:2041 mV CMD Active Level:2423 mV Input file : C:\Users\ktha\Desktop\Sony_C1904_emmc_direct_dump\ EMMC_ROM3_00000000_00200000.bin Writing 0000200000 bytes to 0000000000 ...ROM3 (BOOT2 ROM) Done. Write Speed: 1600 kB/s |
08-16-2019, 06:41 | #9 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2683704 Status: Offline Thanks Meter: 0 | moto XT1643 Z3X EasyJtag Software ver. 3.6.1.2 Skip loading eMMC Addon Firmware CMD Pullup Level:2650 mV CMD Active Level:2753 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR Can't init device, Reason: CMD Timeout Error Done. |
