oppo a83 (cph1729) emmc writing error phone received for phon lock and frp and usb not connecting so i decided to go for isp pinouts all went very well but after removing password and frp phon goes is recovery automatically and wiping phon data again and again i also try to write user data and catch file but facing errors please help me.i also try to adjust voltage and frequency but still same https://i.ibb.co/sFZVxRK/oppo-a83.jpg i m using battery and data cable with cmd clk and datao do i need to solder preloder tp to ground which we use for format etc. i m using these pinouts https://i.ibb.co/R2ww6xn/isp-oppo-a83.png |
At phone IO line is 1.8 You set 3,3 It's a normally? |
you have error at one address - it may be bad NAND sells |
MTK base, don't use usb for vcc and vccq if you are flashing, cpu reset after awhile then loose connection on vcc and vccq..check device manager |
Operation: Random verify eMMC ... If your restore data error occurs - the original data can be found in a folder: \Backups\RandomVerify\GD6BMB_B60AA813_20191010_135 250 eMMC switching to ROM1 Address: 000000D4C000, size: 000000004000 - FAIL Failed to restore the original data at the address: 000000D4C000 Address: 000000D50000, size: 000000004000 - FAIL Address: 000000D54000, size: 000000004000 - FAIL Address: 000001844000, size: 000000004000 - FAIL Address: 000001848000, size: 000000004000 - FAIL Address: 00000184C000, size: 000000004000 - FAIL Address: 000001850000, size: 000000004000 - FAIL Address: 000001854000, size: 000000004000 - FAIL Address: 000001858000, size: 000000004000 - FAIL |
10-10-2019 12:04:34> eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) 10-10-2019 12:04:41> Microsoft Windows 10 (64 bit) build 18362 (10.0.18362.329) 10-10-2019 12:04:41> 10-10-2019 12:04:41> Looking for EasyJTAG box... 10-10-2019 12:04:41> EasyJTAG API ver. 3307 10-10-2019 12:04:44> OpenUSB returned = 0 10-10-2019 12:04:45> EasyJTAG Box Serial = 0F0F1010BF8FEF3B 10-10-2019 12:04:50> Card Serial = AA24ACEA 10-10-2019 12:04:50> EasyJTAG Box Firmware = 1.63 10-10-2019 12:04:50> 10-10-2019 12:05:05> Looking for EasyJTAG box... 10-10-2019 12:05:05> EasyJTAG API ver. 3307 10-10-2019 12:05:05> Setting IO Levels to 3.3V 10-10-2019 12:05:05> Setting frequence to 21 MHz 10-10-2019 12:05:07> EasyJTAG Box Serial = 0F0F1010BF8FEF3B 10-10-2019 12:05:07> EasyJTAG Box Firmware = 1.63 10-10-2019 12:05:10> HiPower mode is ON 10-10-2019 12:05:10> Setting frequence to 21 MHz 10-10-2019 12:05:10> CMD Pullup Level: 1691 mV 10-10-2019 12:05:10> CMD Active Level: 2361 mV 10-10-2019 12:05:23> eMMC Init returned = -206 10-10-2019 12:05:23> Can't init device. Reason: PORT Read Error 10-10-2019 12:05:23> 10-10-2019 12:05:37> Looking for EasyJTAG box... 10-10-2019 12:05:37> EasyJTAG API ver. 3307 10-10-2019 12:05:37> Setting IO Levels to 1.8V (ISP) 10-10-2019 12:05:37> Setting frequence to 14 MHz 10-10-2019 12:05:39> EasyJTAG Box Serial = 0F0F1010BF8FEF3B 10-10-2019 12:05:39> EasyJTAG Box Firmware = 1.63 10-10-2019 12:05:43> HiPower mode is ON 10-10-2019 12:05:43> Setting frequence to 14 MHz 10-10-2019 12:05:43> CMD Pullup Level: 1660 mV 10-10-2019 12:05:43> CMD Active Level: 2000 mV 10-10-2019 12:05:43> eMMC Init returned = -1 10-10-2019 12:05:43> Can't init device. Reason: CMD Timeout Error 10-10-2019 12:05:43> 10-10-2019 12:06:24> Looking for EasyJTAG box... 10-10-2019 12:06:24> EasyJTAG API ver. 3307 10-10-2019 12:06:24> Setting IO Levels to 2.8V 10-10-2019 12:06:24> Setting frequence to 14 MHz 10-10-2019 12:06:25> EasyJTAG Box Serial = 0F0F1010BF8FEF3B 10-10-2019 12:06:25> EasyJTAG Box Firmware = 1.63 10-10-2019 12:06:28> HiPower mode is ON 10-10-2019 12:06:29> Setting frequence to 14 MHz 10-10-2019 12:06:29> CMD Pullup Level: 1680 mV 10-10-2019 12:06:29> CMD Active Level: 2227 mV 10-10-2019 12:06:41> eMMC Init returned = -206 10-10-2019 12:06:41> Can't init device. Reason: PORT Read Error 10-10-2019 12:06:41> 10-10-2019 12:06:44> Looking for EasyJTAG box... 10-10-2019 12:06:44> EasyJTAG API ver. 3307 10-10-2019 12:06:44> Setting IO Levels to 2.8V 10-10-2019 12:06:44> Setting frequence to 14 MHz 10-10-2019 12:06:45> EasyJTAG Box Serial = 0F0F1010BF8FEF3B 10-10-2019 12:06:45> EasyJTAG Box Firmware = 1.63 10-10-2019 12:06:48> 10-10-2019 12:06:56> Looking for EasyJTAG box... 10-10-2019 12:06:56> EasyJTAG API ver. 3307 10-10-2019 12:06:56> Setting IO Levels to 1.8V (ISP) 10-10-2019 12:06:56> Setting frequence to 14 MHz 10-10-2019 12:06:57> EasyJTAG Box Serial = 0F0F1010BF8FEF3B 10-10-2019 12:06:57> EasyJTAG Box Firmware = 1.63 10-10-2019 12:07:00> Setting frequence to 14 MHz 10-10-2019 12:07:00> CMD Pullup Level: 1660 mV 10-10-2019 12:07:00> CMD Active Level: 2000 mV 10-10-2019 12:07:00> eMMC Init returned = -1 10-10-2019 12:07:00> Can't init device. Reason: CMD Timeout Error 10-10-2019 12:07:00> 10-10-2019 12:07:07> Looking for EasyJTAG box... 10-10-2019 12:07:07> EasyJTAG API ver. 3307 10-10-2019 12:07:07> Setting IO Levels to 2.8V 10-10-2019 12:07:07> Setting frequence to 14 MHz 10-10-2019 12:07:08> EasyJTAG Box Serial = 0F0F1010BF8FEF3B 10-10-2019 12:07:08> EasyJTAG Box Firmware = 1.63 10-10-2019 12:07:12> Setting frequence to 14 MHz 10-10-2019 12:07:12> CMD Pullup Level: 1680 mV 10-10-2019 12:07:12> CMD Active Level: 2227 mV 10-10-2019 12:07:24> eMMC Init returned = -206 10-10-2019 12:07:24> Can't init device. Reason: PORT Read Error 10-10-2019 12:07:24> 10-10-2019 12:07:32> Looking for EasyJTAG box... 10-10-2019 12:07:32> EasyJTAG API ver. 3307 10-10-2019 12:07:32> Setting IO Levels to 3.3V 10-10-2019 12:07:32> Setting frequence to 7 MHz 10-10-2019 12:07:33> EasyJTAG Box Serial = 0F0F1010BF8FEF3B 10-10-2019 12:07:33> EasyJTAG Box Firmware = 1.63 10-10-2019 12:07:36> Setting frequence to 7 MHz 10-10-2019 12:07:36> CMD Pullup Level: 1691 mV 10-10-2019 12:07:36> CMD Active Level: 2361 mV 10-10-2019 12:07:49> eMMC Init returned = -206 10-10-2019 12:07:49> Can't init device. Reason: PORT Read Error 10-10-2019 12:07:49> 10-10-2019 12:08:12> Looking for EasyJTAG box... 10-10-2019 12:08:12> EasyJTAG API ver. 3307 10-10-2019 12:08:12> Setting IO Levels to 3.3V 10-10-2019 12:08:12> Setting frequence to 7 MHz 10-10-2019 12:08:13> EasyJTAG Box Serial = 0F0F1010BF8FEF3B 10-10-2019 12:08:13> EasyJTAG Box Firmware = 1.63 10-10-2019 12:08:17> Setting frequence to 7 MHz 10-10-2019 12:08:17> CMD Pullup Level: 1701 mV 10-10-2019 12:08:17> CMD Active Level: 2371 mV 10-10-2019 12:08:29> eMMC Init returned = -206 10-10-2019 12:08:29> Can't init device. Reason: PORT Read Error 10-10-2019 12:08:29> 10-10-2019 12:09:03> Looking for EasyJTAG box... 10-10-2019 12:09:03> EasyJTAG API ver. 3307 10-10-2019 12:09:03> Setting IO Levels to 3.3V 10-10-2019 12:09:03> Setting frequence to 14 MHz 10-10-2019 12:09:04> EasyJTAG Box Serial = 0F0F1010BF8FEF3B 10-10-2019 12:09:04> EasyJTAG Box Firmware = 1.63 10-10-2019 12:09:07> Setting frequence to 14 MHz 10-10-2019 12:09:08> CMD Pullup Level: 1701 mV 10-10-2019 12:09:08> CMD Active Level: 2371 mV 10-10-2019 12:09:20> eMMC Init returned = -206 10-10-2019 12:09:20> Can't init device. Reason: PORT Read Error 10-10-2019 12:09:20> 10-10-2019 12:10:17> Looking for EasyJTAG box... 10-10-2019 12:10:17> EasyJTAG API ver. 3307 10-10-2019 12:10:17> Setting IO Levels to 3.3V 10-10-2019 12:10:17> Setting frequence to 14 MHz 10-10-2019 12:10:19> EasyJTAG Box Serial = 0F0F1010BF8FEF3B 10-10-2019 12:10:19> EasyJTAG Box Firmware = 1.63 10-10-2019 12:10:22> Setting frequence to 14 MHz 10-10-2019 12:10:22> CMD Pullup Level: 371 mV 10-10-2019 12:10:22> CMD Active Level: 1897 mV 10-10-2019 12:10:22> eMMC Init returned = -1 10-10-2019 12:10:22> Can't init device. Reason: CMD Timeout Error |
also you can try backup important partition, Factory format + Reset (if eMMC <5.1) or Universal Format and check again - may be eMMC replade bad cells or marked it as bad |
may be nvram and some else |
