09-14-2019, 11:18 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: colombo
Member: 399781 Status: Offline Thanks Meter: 94 | cph1911 password 2019-09-14 12:47:40 PM> Looking for EasyJTAG box... 2019-09-14 12:47:40 PM> EasyJTAG API ver. 3307 2019-09-14 12:47:40 PM> Setting IO Levels to 1.8V 2019-09-14 12:47:40 PM> Setting frequence to 14 MHz 2019-09-14 12:47:41 PM> EasyJTAG Box Serial = 1414110FBFBA99FD 2019-09-14 12:47:41 PM> EasyJTAG Box Firmware = 1.63 2019-09-14 12:47:44 PM> Setting frequence to 14 MHz 2019-09-14 12:47:44 PM> CMD Pullup Level: 1949 mV 2019-09-14 12:47:44 PM> CMD Active Level: 2093 mV 2019-09-14 12:47:44 PM> eMMC Init returned = 0 2019-09-14 12:47:44 PM> EMMC Device Information : 2019-09-14 12:47:44 PM> EMMC CID: 13014E53304A394B39100E647EDE3678 2019-09-14 12:47:44 PM> EMMC CSD: D05F01328F5913FFFFFFFFEF964000A8 2019-09-14 12:47:44 PM> EMMC Manufacture : MICRON , EMMC NAME: S0J9K9 , HEX: 53304A394B39 , S/N: 0E647EDE , rev. 0x10 2019-09-14 12:47:44 PM> EMMC Manufacture ID: 0x13 , OEM ID: 0x4E , Device Type: BGA (Discrete embedded) , Date: 3/2019 2019-09-14 12:47:44 PM> EMMC ROM 1 (Main User Data) Capacity: 119280 MB (001D1F000000) 2019-09-14 12:47:44 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 2019-09-14 12:47:44 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 439 , Response: Not Clean 2019-09-14 12:47:44 PM> EMMC Permanent Write Protection: No 2019-09-14 12:47:44 PM> EMMC Temporary Write Protection: No 2019-09-14 12:47:44 PM> Extended CSD Information : 2019-09-14 12:47:44 PM> Extended CSD rev: 1.8 (MMC 5.1) 2019-09-14 12:47:44 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 2019-09-14 12:47:44 PM> Boot Bus Config: 0x02 , width 8bit 2019-09-14 12:47:44 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 2019-09-14 12:47:44 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 2019-09-14 12:47:44 PM> Device supports partitioning features 2019-09-14 12:47:44 PM> Device can have enhanced technological features in partitions and user data area 2019-09-14 12:47:44 PM> Device can have extended partitions attribute 2019-09-14 12:47:44 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 2019-09-14 12:47:44 PM> Backup saved: S0J9K9_0E647EDE_20190914_124744.extcsd 2019-09-14 12:47:44 PM> EMMC Init completed. 2019-09-14 12:47:44 PM> 2019-09-14 12:47:44 PM> Get firmware version 2019-09-14 12:47:44 PM> 2019-09-14 12:47:46 PM> Error: Mount [data] failed PartType: LINUX 2019-09-14 12:47:46 PM> 2019-09-14 12:47:48 PM> Error: Except: Unmount [data/] failed 2019-09-14 12:47:48 PM> Firmware info not found |
