Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 10-07-2019, 14:46   #1 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 1,702
Talking Oppo F11 CPH1911 pattern/pin remove done
Oppo F11 CPH1911 pattern/pin remove DONE with great easy jtag box
---------- eMMC Device Information ----------
eMMC CID : 150100335636434D420224E5DACC46FE
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 04/2019 Rev.0x2
eMMC NAME: 3V6CMB , S/N: 619043532
eMMC NAME (HEX): 335636434D42
EMMC ROM1 (Main User Data) Capacity: 119276 MB , 0xE8F6000 pages , 0x1D1EC00000 bytes
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 171 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: E8F6000 sectors 116.5 GiB
Soft (Partitioned) Disk/Image size: E8F5FBC sectors 116.5 GiB
Disk identifier (GUID): 00000000-0000-0000-0000-000000000000
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,244277214
Partition info successfully found
------ Android information ------
Detected (Android Userdata) USERDATA : 0x01EB800000 (108.742GB)
Erasing...
Done.
Detected (Android Cache)) CACHE : 0x01D0800000 (432.0MB)
Erasing...
Done.
Done.
Running:Reset PIN/PASS/GESTURE Locks
Z3X EasyJtag Software ver. 3.6.1.9
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 0900301095CE53A5, ,FW Ver.: 01.63
CMD Pullup Level:2031 mV
CMD Active Level:2361 mV
Box IO Level:2800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
Detected LINUX(Android) USERDATA : 0x01EB800000 (108.742GB)
Mount EXT4 fs...
Unable to mount USER , code : 95
Done.
Running:Format FRP Partition...
CMD Active Level:2351 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Formatting FRP...
Detected LINUX(Android) FRP : 0x000DE88000 (1.0MB) formatting...
Done.
Detected LINUX(Android) CACHE : 0x01D0800000 (432.0MB) , formatting...
Done.
Detected LINUX(Android) USERDATA : 0x01EB800000 (108.742GB) , formatting...
Done.
Done.
Done.
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Done.
Thanks easy jtag team
The Following 2 Users Say Thank You to pintu_das For This Useful Post:
Old 10-08-2019, 12:49   #2 (permalink)
Member: 639314
Thanks
Thanks very much .....................
Old 10-08-2019, 13:39   #3 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 762
Erasing...
Done.
Erasing...
Done.
Done.
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Mount EXT4 fs...
Done.
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Formatting FRP...
Done.
Done.
Done.
Done.
Done.
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Done.
which option u used,wife data or reset oppo?
Old 10-08-2019, 18:54   #4 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 1,702
This phone MTK CPU
Just click Wipe user data
The Following User Says Thank You to pintu_das For This Useful Post:
Page generated in 0.28490 seconds with 7 queries
