02-17-2020, 12:36 | #2 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Algeria Age: 45
Member: 444025 Status: Offline Thanks Meter: 25 | Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: 9F3F7852C594F4C4, ,FW Ver.: 02.50 CMD Pullup Level:1823 mV CMD Active Level:1859 mV Box IO Level:1800 mV CLK Rate:12000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100444836444D42052BC7DC8FB411 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2017 Rev.0x5 eMMC NAME: DH6DMB , S/N: 734518415 eMMC NAME (HEX): 444836444D42 EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 90 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: DH6DMB_ 734518415_20200217_1234.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x008D800000 (4.203GB) Short EXT fs info: Size: 4.203GB Block size: 4.0KB Inode size: 256 Inodes: 275808 Short Android info: Build ID: O11019 Release Base ID: 8.1.0 Security Path: 2019-11-05 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: full_oppo6771_17331-user 8.1.0 O11019 1572232253 release-keys Backup saved: BuildProp_20200217_1234.txt --------------------------------------------- Detected USERDATA USERDATA : 0x01B5800000 (51.347GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 8B122750 2DD09B94 1E3D9648 755484D9 BA7CB8E8 D0A94C6D 327C9C2D 889BF93D ‹.'P-Л”.=–HuT„Ùº|¸èЩLm2|œ-.›ù=; 87AEEC98 FBB5A632 CFDB19E0 C25EEB63 40C73586 E16472E1 5869670D A3C46793 ‡®ì.ûµ¦2ÏÛ.àÂ^ëc@Ç5†ádráXig.£Äg“; 8B984A71 BFDCEEC6 84920D55 F87D6285 253BE7A5 73F8B09C 2872E488 85323C2B ‹.Jq¿ÜîÆ„’.Uø}b…%;ç¥sø°œ(rä.…2<+; 7B49AAFE 8341EEA4 8816ADC0 CA367A17 1F7B469B 300A3B77 247F5EC2 325825EF {IªþƒAî¤..*ÀÊ6z..{F›0.;w$.^Â2X%ï; CD58B831 734B0CAB D66CA58E FEFEA0C0 A97A72C8 9ECD1A03 7DF76BD0 76D36F6E ÍX¸1sK.«Öl¥Žþþ*À©zrÈžÍ..}÷kÐvÓon; 004846F9 8F432E21 064FC00B 54F739CC 66403F86 F3487CFA 63E42FB2 B5F905BC .HFù.C.!.OÀ.T÷9Ìf@?†óH|úcä/²µù.¼; 68A38488 184D5DEB E622596E B0B49BE7 059085CD 18050A5D 22F2BE2D 6765C82D h£„..M]ëæ"Yn°´›ç..…Í...]"ò¾-geÈ-; BBA23EC0 15E0BB5F 7F8666B4 E41DC3E8 0630E98C D40B1674 FC68289E 7E726CFB »¢>À.à»_.†f´ä.Ãè.0éŒÔ..tüh(ž~rlû; Done. Checking security ... Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: 9F3F7852C594F4C4, ,FW Ver.: 02.50 CMD Pullup Level:1826 mV CMD Active Level:1859 mV Box IO Level:1800 mV CLK Rate:12000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100444836444D42052BC7DC8FB411 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2017 Rev.0x5 eMMC NAME: DH6DMB , S/N: 734518415 eMMC NAME (HEX): 444836444D42 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 90 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found ------ Android information ------ Detected (Android Userdata) USERDATA : 0x01B5800000 (51.347GB) Erasing... Done. Detected (Android Cache)) CACHE : 0x019A800000 (432.0MB) Erasing... Done. --------------------------------------------- Done. Checking security ... Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: 9F3F7852C594F4C4, ,FW Ver.: 02.50 CMD Pullup Level:1823 mV CMD Active Level:1859 mV Box IO Level:1800 mV CLK Rate:12000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100444836444D42052BC7DC8FB411 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2017 Rev.0x5 eMMC NAME: DH6DMB , S/N: 734518415 eMMC NAME (HEX): 444836444D42 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 90 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found Formatting FRP... Detected LINUX(Android) FRP : 0x0007C88000 (1.0MB) formatting... Done. Detected LINUX(Android) CACHE : 0x019A800000 (432.0MB) , formatting... Done. Detected LINUX(Android) USERDATA : 0x01B5800000 (51.347GB) , formatting... Done. Done. |
The Following User Says Thank You to LePilami For This Useful Post: |
