07-04-2019, 14:47 | #31 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | don't do any wipe or format operation just do as below Clear PIN/GST/PASS Android FRp Clear Or Reset OPPO These options are enough for Pin Pattern frp |
The Following 4 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
07-04-2019, 14:53 | #32 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | 1853 or 1803 ??? i have a a3s phone but pinout not match ?? i need oppo a3s cph1853 pinout . Last edited by pintu_das; 07-04-2019 at 15:00. |
07-05-2019, 05:14 | #35 (permalink) |
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | DONE WITH THIS PINOUT EasyJtag Suite Classic ver.: 3.6.1.9 / wxWidgets 3.1.2-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights OK Android Explorer ver:1.0.0.13 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.0.6 QUALCOMM Direct ver:1.0.6671.7138 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : AAAA-6B50 , ver: 22 Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 2 serial devices COM1 ACPI\PNP0501 Communications Port (COM1) COM39 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Control Port (COM39) Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0900301095CE53A5, ,FW Ver.: 01.63 CMD Pullup Level:2031 mV CMD Active Level:2495 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4204EF97E48026A0 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 02/2019 Rev.0x4 eMMC NAME: QE63MB , S/N: 4019709056 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 7045 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_4019709056_20190705_0953.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB) Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20190315.232714 release-keys --------------------------------------------- Detected USERDATA USERDATA : 0x015B800000 (9.129GB) Unable to mount USERDATA , code : 95 Done. Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0900301095CE53A5, ,FW Ver.: 01.63 CMD Pullup Level:2041 mV CMD Active Level:2629 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4204EF97E48026A0 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 02/2019 Rev.0x4 eMMC NAME: QE63MB , S/N: 4019709056 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 7045 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (33) Done. THANKS EASY Jtag team |
The Following 5 Users Say Thank You to pintu_das For This Useful Post: |
07-05-2019, 05:33 | #36 (permalink) |
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | OPPO A3s (CPH1853) PATTERN REMOVE DONE WITH GREAT EASY JTAG BOX OPPO A3s (CPH1853) PATTERN REMOVE DONE WITH GREAT EASY JTAG BOX EasyJtag Suite Classic ver.: 3.6.1.9 / wxWidgets 3.1.2-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights OK Android Explorer ver:1.0.0.13 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.0.6 QUALCOMM Direct ver:1.0.6671.7138 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : AAAA-6B50 , ver: 22 Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 2 serial devices COM1 ACPI\PNP0501 Communications Port (COM1) COM39 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Control Port (COM39) Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0900301095CE53A5, ,FW Ver.: 01.63 CMD Pullup Level:2031 mV CMD Active Level:2495 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4204EF97E48026A0 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 02/2019 Rev.0x4 eMMC NAME: QE63MB , S/N: 4019709056 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 7045 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_4019709056_20190705_0953.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB) Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20190315.232714 release-keys --------------------------------------------- Detected USERDATA USERDATA : 0x015B800000 (9.129GB) Unable to mount USERDATA , code : 95 Done. Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0900301095CE53A5, ,FW Ver.: 01.63 CMD Pullup Level:2041 mV CMD Active Level:2629 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4204EF97E48026A0 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 02/2019 Rev.0x4 eMMC NAME: QE63MB , S/N: 4019709056 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 7045 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (33) Done. Thanks Easy Jtag team |
The Following 2 Users Say Thank You to pintu_das For This Useful Post: |
07-05-2019, 12:51 | #41 (permalink) |
Freak Poster Join Date: Jun 2011 Location: kolkata Age: 39
Member: 1596162 Status: Offline Sonork: 100.1616391 Thanks Meter: 146 | |
07-06-2019, 14:06 | #43 (permalink) |
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | now one more unlock done model A3s (CPH1803) WITH THIS ISP Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0900301095CE53A5, ,FW Ver.: 01.63 CMD Pullup Level:2887 mV CMD Active Level:3124 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4203ADA4E08085A2 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 08/2018 Rev.0x3 eMMC NAME: QE63MB , S/N: 2913263744 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 72558 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_2913263744_20190706_1829.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB) Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20190323.213841 release-keys --------------------------------------------- Detected USERDATA USERDATA : 0x0158000000 (9.184GB) Unable to mount USERDATA , code : 95 Done. Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0900301095CE53A5, ,FW Ver.: 01.63 CMD Pullup Level:2959 mV CMD Active Level:3165 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4203ADA4E08085A2 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 08/2018 Rev.0x3 eMMC NAME: QE63MB , S/N: 2913263744 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 72558 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (35) Done. |
The Following 4 Users Say Thank You to pintu_das For This Useful Post: |
07-07-2019, 16:45 | #44 (permalink) |
Product Supporter Join Date: Feb 2010 Location: .::INDIA::.
Member: 1236722 Status: Offline Sonork: 100.1601546 Thanks Meter: 4,180 | Oppo A1k CPH1923 UNlock Done By Easy Jtag Wipe FRP Regard VC_INDIA |
The Following 5 Users Say Thank You to VC_INDIA For This Useful Post: |
07-08-2019, 05:53 | #45 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | OPPO A3S CPH1853 One Click Reset Done Code: Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 1818041DBF5EF1D5, ,FW Ver.: 01.63 CMD Pullup Level:2000 mV CMD Active Level:2609 mV Box IO Level:2800 mV CLK Rate:7000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D42069AF3682CC538 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 12/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 2599643180 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 1453 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_2599643180_20190708_0940.extcsd ============================================= Extended CSD rev 1.8 (MMC 5.1) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x3f] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x02] Tag Resources Size [TAG_RES_SIZE: 0x00] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 65536 KiB ------------------------- eMMC v5+ ------------------------- Supported modes [SUPPORTED_MODES: 0x03] FFU features [FFU_FEATURES: 0x00] Operation codes timeout [OPERATION_CODE_TIMEOUT: 0x00] FFU Argument [FFU_ARG: 0xc7810000] Number of FW sectors correctly programmed[NUM_OF_FW_SECT_CORR_PROG: 0] Vendor proprietary health report: [VENDOR_PROPRIETARY_HEALTH_REPORT[301]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[300]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[299]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[298]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[297]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[296]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[295]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[294]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[293]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[292]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[291]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[290]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[289]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[288]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[287]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[286]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[285]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[284]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[283]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[282]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[281]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[280]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[279]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[278]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[277]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[276]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[275]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[274]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[273]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[272]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[271]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[270]]:0x00 _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_B: 0x01] i.e. 0% - 10% device life time used _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_A: 0x01] i.e. 0% - 10% device life time used Pre EOL information [PRE_EOL_INFO: 0x01] i.e. Normal Optimal read size [OPTIMAL_READ_SIZE: 0x00] Optimal write size [OPTIMAL_WRITE_SIZE: 0x08] Optimal trim unit size [OPTIMAL_TRIM_UNIT_SIZE: 0x01] Device version [DEVICE_VERSION: 0x00 - 0x00] Firmware version: [FIRMWARE_VERSION[261]]: 0x00 [FIRMWARE_VERSION[260]]: 0x00 [FIRMWARE_VERSION[259]]: 0x00 [FIRMWARE_VERSION[258]]: 0x00 [FIRMWARE_VERSION[257]]: 0x00 [FIRMWARE_VERSION[256]]: 0x00 [FIRMWARE_VERSION[255]]: 0x00 [FIRMWARE_VERSION[254]]: 0x06 Power class for 200MHz, DDR at VCC= 3.6V [PWR_CL_DDR_200_360: 0x00] ------------------------------------------------------------- Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 65536 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x1e] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x07] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x01d1f000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x00] [MIN_PERF_R_8_52: 0x00] [MIN_PERF_W_8_26_4_52: 0x00] [MIN_PERF_R_8_26_4_52: 0x00] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x00] [MIN_PERF_R_4_26: 0x00] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x02] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x0a] I/O Driver Strength [DRIVER_STRENGTH: 0x1f] Card Type [CARD_TYPE: 0x57] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x38] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x14 Enable background operations handshake [BKOPS_EN]: 0x02 H/W reset function [RST_N_FUNCTION]: 0x01 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0003a3 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00 Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646 Partition info successfully found ------ Detected 64 partitions ------ P0 (OPPODYCNVBK) [0x5000 0xa00000] Size: 10.0MB P1 (OPPOSTANVBK) [0xa05000 0xa00000] Size: 10.0MB P2 (MODEMST1) [0x1405000 0x180000] Size: 1.500MB P3 (MODEMST2) [0x1585000 0x180000] Size: 1.500MB P4 (PERSIST) [0x1705000 0x2000000] Size: 32.0MB P5 (OPPORESERVE1) [0x3705000 0x800000] Size: 8.0MB P6 (OPPORESERVE2) [0x3f05000 0x4000000] Size: 64.0MB P7 (FSC) [0x7f05000 0x400] Size: 1.0KB P8 (SSD) [0x7f06000 0x2000] Size: 8.0KB P9 (SBL1) [0x7f08000 0x80000] Size: 512.0KB P10 (RPM) [0x7f88000 0x80000] Size: 512.0KB P11 (TZ) [0x8008000 0x200000] Size: 2.0MB P12 (DEVCFG) [0x8208000 0x40000] Size: 256.0KB P13 (SBL1BAK) [0x8248000 0x80000] Size: 512.0KB P14 (RPMBAK) [0x82c8000 0x80000] Size: 512.0KB P15 (TZBAK) [0x8348000 0x200000] Size: 2.0MB P16 (DEVCFGBAK) [0x8548000 0x40000] Size: 256.0KB P17 (DSP) [0x8588000 0x1000000] Size: 16.0MB P18 (DDR) [0x9800000 0x8000] Size: 32.0KB P19 (FSG) [0x9808000 0x400000] Size: 4.0MB P20 (SEC) [0x9c08000 0x4000] Size: 16.0KB P21 (ABOOT) [0x9c0c000 0x100000] Size: 1.0MB P22 (ABOOTBAK) [0x9d0c000 0x100000] Size: 1.0MB P23 (MODEM) [0x9e0c000 0x8000000] Size: 128.0MB P24 (DTBO) [0x11e0c000 0x800000] Size: 8.0MB P25 (VBMETA) [0x1260c000 0x10000] Size: 64.0KB P26 (BOOT) [0x1261c000 0x4000000] Size: 64.0MB P27 (RECOVERY) [0x1661c000 0x4000000] Size: 64.0MB P28 (DEVINFO) [0x1a61c000 0x100000] Size: 1.0MB P29 (SPLASH) [0x1a800000 0xb00000] Size: 11.0MB P30 (LOGO) [0x1b300000 0x2000000] Size: 32.0MB P31 (DRIVER) [0x1d300000 0x2000000] Size: 32.0MB P32 (CACHE) [0x1f300000 0x10000000] Size: 256.0MB P33 (MISC) [0x2f300000 0x100000] Size: 1.0MB P34 (KEYSTORE) [0x2f400000 0x80000] Size: 512.0KB P35 (CONFIG) [0x2f480000 0x8000] Size: 32.0KB P36 (LOG) [0x2f488000 0x4000000] Size: 64.0MB P37 (OEM) [0x33488000 0x100000] Size: 1.0MB P38 (LIMITS) [0x33800000 0x8000] Size: 32.0KB P39 (MOTA) [0x34000000 0x80000] Size: 512.0KB P40 (DIP) [0x34080000 0x100000] Size: 1.0MB P41 (MDTP) [0x34180000 0x2000000] Size: 32.0MB P42 (SYSCFG) [0x36180000 0x80000] Size: 512.0KB P43 (MCFG) [0x36200000 0x400000] Size: 4.0MB P44 (LKSECAPP) [0x36800000 0x20000] Size: 128.0KB P45 (CMNLIB) [0x36820000 0x100000] Size: 1.0MB P46 (CMNLIB64) [0x36920000 0x100000] Size: 1.0MB P47 (KEYMASTER) [0x36a20000 0x100000] Size: 1.0MB P48 (LKSECAPPBAK) [0x36b20000 0x20000] Size: 128.0KB P49 (CMNLIBBAK) [0x36b40000 0x100000] Size: 1.0MB P50 (CMNLIB64BAK) [0x36c40000 0x100000] Size: 1.0MB P51 (KEYMASTERBAK) [0x36d40000 0x100000] Size: 1.0MB P52 (APDP) [0x37000000 0x40000] Size: 256.0KB P53 (MSADP) [0x37040000 0x40000] Size: 256.0KB P54 (DPO) [0x37080000 0x2000] Size: 8.0KB P55 (LOGDUMP) [0x37082000 0x4000000] Size: 64.0MB P56 (VM-KYSTORE) [0x3b082000 0x100000] Size: 1.0MB P57 (VM-DATA) [0x3b182000 0xa00000] Size: 10.0MB P58 (HYP) [0x3c000000 0x800000] Size: 8.0MB P59 (VM-SYSTEM) [0x3c800000 0x4000000] Size: 64.0MB P60 (VM-LINUX) [0x40800000 0x2000000] Size: 32.0MB P61 (SYSTEM) [0x42800000 0xd6900000] Size: 3.352GB P62 (VENDOR) [0x119100000 0x41f60000] Size: 1.30GB P63 (USERDATA) [0x15b800000 0x2485fbe00] Size: 9.129GB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB) Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20190509.095130 release-keys --------------------------------------------- Detected USERDATA USERDATA : 0x015B800000 (9.129GB) Unable to mount USERDATA , code : 95 Done. Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 1818041DBF5EF1D5, ,FW Ver.: 01.63 CMD Pullup Level:1990 mV CMD Active Level:2609 mV Box IO Level:2800 mV CLK Rate:7000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D42069AF3682CC538 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 12/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 2599643180 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 1453 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (33) Done. |
The Following 6 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
