Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 06-26-2019, 09:01   #1 (permalink)
Yashbanswara's Avatar
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 528
OPPO's FRP reset, Pattern reset thread. Post succcesfully operations at this thread
Hello Everyone Today In My Shop Come Oppo Realme 2 ( RMX1805 ) With Pattern Lock Than I Do This & Remove Pattern Lock Successfully Via Easy JTAG
[CENTER]
Before & After Images
Read Info & All LOG:
LOG:
Z3X EasyJtag Software ver. 3.6.0.0
Loading eMMC GEN1 Firmware... IO: 3300 mV
Box S/N: XXXXXXXXX, ,FW Ver.: 01.63
CMD Pullup Level:1773 mV
CMD Active Level:2495 mV
Box IO Level:3300 mV
CLK Rate:7000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Can't init device, Reason: CMD Timeout Error
Done.
Box S/N: 0XXXXXXXXXXXXXX, ,FW Ver.: 01.63
CMD Pullup Level:2041 mV
CMD Active Level:3011 mV
CLK Rate:7000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 150100474436424D42014105077155EE
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 05/2018  Rev.0x1
eMMC NAME: GD6BMB , S/N: XXXXXXXXXXXXXX
eMMC NAME (HEX): 474436424D42
EMMC ROM1 (Main User Data)   Capacity: 29820 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 27928 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
  Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit  , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
 Device support partitioning feature
 Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: GD6BMB_XXXXXXXXXXXXXX_20190626_1145.extcsd
Partition table scan:
 GPT: present
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Logical sector size: 0x200  bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
First usable sector: 34
Last usable sector: 61071326
Partition info successfully found
Found Data areas (firmware parts) count is: 64
P0 (OPPODYCNVBK) [0x5000 0xa00000] Size: 10.0MB
P1 (OPPOSTANVBK) [0xa05000 0xa00000] Size: 10.0MB
P2 (MODEMST1) [0x1405000 0x180000] Size: 1.500MB
P3 (MODEMST2) [0x1585000 0x180000] Size: 1.500MB
P4 (PERSIST) [0x1705000 0x2000000] Size: 32.0MB
P5 (OPPORESERVE1) [0x3705000 0x800000] Size: 8.0MB
P6 (OPPORESERVE2) [0x3f05000 0x4000000] Size: 64.0MB
P7 (FSC) [0x7f05000 0x400] Size: 1.0KB
P8 (SSD) [0x7f06000 0x2000] Size: 8.0KB
P9 (SBL1) [0x7f08000 0x80000] Size: 512.0KB
P10 (RPM) [0x7f88000 0x80000] Size: 512.0KB
P11 (TZ) [0x8008000 0x200000] Size: 2.0MB
P12 (DEVCFG) [0x8208000 0x40000] Size: 256.0KB
P13 (SBL1BAK) [0x8248000 0x80000] Size: 512.0KB
P14 (RPMBAK) [0x82c8000 0x80000] Size: 512.0KB
P15 (TZBAK) [0x8348000 0x200000] Size: 2.0MB
P16 (DEVCFGBAK) [0x8548000 0x40000] Size: 256.0KB
P17 (DSP) [0x8588000 0x1000000] Size: 16.0MB
P18 (DDR) [0x9800000 0x8000] Size: 32.0KB
P19 (FSG) [0x9808000 0x400000] Size: 4.0MB
P20 (SEC) [0x9c08000 0x4000] Size: 16.0KB
P21 (ABOOT) [0x9c0c000 0x100000] Size: 1.0MB
P22 (ABOOTBAK) [0x9d0c000 0x100000] Size: 1.0MB
P23 (MODEM) [0x9e0c000 0x8000000] Size: 128.0MB
P24 (DTBO) [0x11e0c000 0x800000] Size: 8.0MB
P25 (VBMETA) [0x1260c000 0x10000] Size: 64.0KB
P26 (BOOT) [0x1261c000 0x4000000] Size: 64.0MB
P27 (RECOVERY) [0x1661c000 0x4000000] Size: 64.0MB
P28 (DEVINFO) [0x1a61c000 0x100000] Size: 1.0MB
P29 (SPLASH) [0x1a800000 0xb00000] Size: 11.0MB
P30 (LOGO) [0x1b300000 0x2000000] Size: 32.0MB
P31 (DRIVER) [0x1d300000 0x2000000] Size: 32.0MB
P32 (CACHE) [0x1f300000 0x10000000] Size: 256.0MB
P33 (MISC) [0x2f300000 0x100000] Size: 1.0MB
P34 (KEYSTORE) [0x2f400000 0x80000] Size: 512.0KB
P35 (CONFIG) [0x2f480000 0x8000] Size: 32.0KB
P36 (LOG) [0x2f488000 0x4000000] Size: 64.0MB
P37 (OEM) [0x33488000 0x100000] Size: 1.0MB
P38 (LIMITS) [0x33800000 0x8000] Size: 32.0KB
P39 (MOTA) [0x34000000 0x80000] Size: 512.0KB
P40 (DIP) [0x34080000 0x100000] Size: 1.0MB
P41 (MDTP) [0x34180000 0x2000000] Size: 32.0MB
P42 (SYSCFG) [0x36180000 0x80000] Size: 512.0KB
P43 (MCFG) [0x36200000 0x400000] Size: 4.0MB
P44 (LKSECAPP) [0x36800000 0x20000] Size: 128.0KB
P45 (CMNLIB) [0x36820000 0x100000] Size: 1.0MB
P46 (CMNLIB64) [0x36920000 0x100000] Size: 1.0MB
P47 (KEYMASTER) [0x36a20000 0x100000] Size: 1.0MB
P48 (LKSECAPPBAK) [0x36b20000 0x20000] Size: 128.0KB
P49 (CMNLIBBAK) [0x36b40000 0x100000] Size: 1.0MB
P50 (CMNLIB64BAK) [0x36c40000 0x100000] Size: 1.0MB
P51 (KEYMASTERBAK) [0x36d40000 0x100000] Size: 1.0MB
P52 (APDP) [0x37000000 0x40000] Size: 256.0KB
P53 (MSADP) [0x37040000 0x40000] Size: 256.0KB
P54 (DPO) [0x37080000 0x2000] Size: 8.0KB
P55 (LOGDUMP) [0x37082000 0x4000000] Size: 64.0MB
P56 (VM-KYSTORE) [0x3b082000 0x100000] Size: 1.0MB
P57 (VM-DATA) [0x3b182000 0xa00000] Size: 10.0MB
P58 (HYP) [0x3c000000 0x800000] Size: 8.0MB
P59 (VM-SYSTEM) [0x3c800000 0x4000000] Size: 64.0MB
P60 (VM-LINUX) [0x40800000 0x2000000] Size: 32.0MB
P61 (SYSTEM) [0x42800000 0xd6900000] Size: 3.352GB
P62 (VENDOR) [0x119100000 0x41f60000] Size: 1.30GB
P63 (USERDATA) [0x15b800000 0x5ec3fbe00] Size: 23.690GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB)
Build ID:  OPM1.171019.026
Release Base ID:  8.1.0
Architecture ABI:  arm64-v8a
Device manufacturer:  OPPO
Build Description:  S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20190516.094149 release-keys
Detected USERDATA USERDATA : 0x015B800000 (23.690GB)
Unable to mount USERDATA , code : 95
Done.
Selected eMMC Interface
Remove Pattern Lock
[CENTER]
Remove FRP Lock
[/CENTER
Thanks & Regards By:All TECH 4 You
The Following 9 Users Say Thank You to Yashbanswara For This Useful Post:
Old 06-26-2019, 11:58   #2 (permalink)
faizafirdous's Avatar
Member: 1281866
Thanks Meter: 283
Good job with procedure to all how to remove
Old 06-27-2019, 05:27   #3 (permalink)
Member: 1588653
Sonork: akash48
Thanks Meter: 33
Oppo Realme 2 ( RMX1805 ) Pattern Lock & FRP Remove
sir pleas share isp pinout
Old 06-27-2019, 05:37   #4 (permalink)
ghr
Member: 1282787
Sonork: 100.1673491
Thanks Meter: 200
just dial *#812# frp gone loolllllllllllllllllllll
Old 06-27-2019, 05:41   #5 (permalink)
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 528
Ask Before Better Search On Google:https://www.google.com/search?q=real...=1360&bih=654#
Old 06-28-2019, 10:20   #6 (permalink)
Member: 2554807
Thanks Meter: 395
Thumbs up Oppo a5 cph1809 hardreset | pattern | pin lock remove | unbrick with easy jtag
OPPO A5 CPH1809 HARDRESET | PATTERN | PIN LOCK REMOVE | UNBRICK WITH EASY JTAG
unpack Ofp to XML
http://www.youtube.com/watch?v=3wjqBRBqvLY
Write XML
http://www.youtube.com/watch?v=7C-pirdlYpw&t=491s
Br_Nishan_Raja
The Following 2 Users Say Thank You to Nishan_Raja For This Useful Post:
Old 07-02-2019, 09:19   #7 (permalink)
buffer2k11's Avatar
Member: 2604648
Thanks Meter: 285
Oppo A3S 1853 no data loss
br,
The Following 9 Users Say Thank You to buffer2k11 For This Useful Post:
Old 07-03-2019, 05:23   #8 (permalink)
4star's Avatar
Member: 1596162
Sonork: 100.1616391
Thanks Meter: 78
Realme rmx1811 user lock done without data lose
REALME RMX1811 USER LOCK DONE WITHOUT DATA LOSE
Old 07-03-2019, 05:27   #9 (permalink)
4star's Avatar
Member: 1596162
Sonork: 100.1616391
Thanks Meter: 78
Oppo and realme user lock done without data lose
Post here succesfull JTAG and eMMC operations with Easy-Jtag:
Old 07-03-2019, 07:52   #10 (permalink)
Member: 1588653
Sonork: akash48
Thanks Meter: 33
sir where is setup link
The Following User Says Thank You to akash48 For This Useful Post:
Old 07-03-2019, 11:16   #11 (permalink)
Member: 13148
Thanks Meter: 1,103
You need read stiked topics
EasyJTAG 3.6 UFS UPDATES
The Following User Says Thank You to layder For This Useful Post:
Old 07-03-2019, 14:31   #12 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 853
As I see from log this is a Qualcomm based device. Does this function work with MTK based devices too?
Old 07-04-2019, 06:13   #13 (permalink)
Member: 1100311
Sonork: 100.1624110
Thanks Meter: 29
only media recoverd. massages and contact not recovered.
The Following User Says Thank You to sackam2010 For This Useful Post:
Old 07-04-2019, 09:04   #14 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,437
Smile OPPO A3s F.R.p & Pattern Done Stuck In Qlcm Mode Done
Special Thanks To My bro Mukesh Jha Jadeja ..::CHAIN::.. Who had helped me To Recover from Qlcm Mode Love You Bro You Are Great
Running:Reset PIN/PASS/GESTURE Locks
Z3X EasyJtag Software ver. 3.6.1.4
Loading eMMC GEN1 Firmware... IO: 1800 mV
Box S/N: 1818041DBF5EF1D5, ,FW Ver.: 01.63
CMD Pullup Level:1722 mV
CMD Active Level:1825 mV
Box IO Level:1800 mV
CLK Rate:14000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
eMMC CID : 90014A68423861503E03C7D06AB2C5CC
eMMC CSD : D02700328F5903FFFFFFFFEF8E400042
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 12/2018 Rev.0x3
eMMC NAME: hB8aP> , S/N: 3352324786
eMMC NAME (HEX): 68423861503E
EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 31274 times
Detected LINUX(Android) USERDATA : 0x0158000000 (23.745GB)
Mount EXT4 fs...
Unable to mount USER , code : 95
Done.
Running:Format FRP Partition...
CMD Pullup Level:1732 mV
CMD Active Level:1835 mV
CLK Rate:14000 kHz
Bus Width:1bit,SDR
Formatting FRP...
Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) CONFIG : 0x002FC80000 (32.0KB) formatting...
Done.
Detected LINUX(Android) USERDATA : 0x0158000000 (23.745GB) , formatting...
Done.
Done.
Done.
The Following 4 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 07-04-2019, 09:37   #15 (permalink)
Member: 230504
Thanks Meter: 57
help request
Please can you give more details about repair procedure ??
thanks in advance
Page generated in 0.23000 seconds with 7 queries
