Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 07-08-2019, 09:20   #46 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,466
Smile Realme C2 (RMX1941) F.R.p & PinCode Reset Done
Selected eMMC Interface
Running:Reset PIN/PASS/GESTURE Locks
Z3X EasyJtag Software ver. 3.6.1.9
Loading eMMC GEN1 Firmware... IO: 1800 mV
Box S/N: 1818041DBF5EF1D5, ,FW Ver.: 01.63
CMD Pullup Level:1742 mV
CMD Active Level:1825 mV
Box IO Level:1800 mV
CLK Rate:7000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 90014A68423861503E0307411C834624
eMMC CSD : D02700328F5903FFFFFFFFEF8E400042
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 04/2019 Rev.0x3
eMMC NAME: hB8aP> , S/N: 121707651
eMMC NAME (HEX): 68423861503E
EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
RPMB Info mmc_init Error, Reason: CMD CRC Error
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Disk identifier (GUID): 00000000-0000-0000-0000-000000000000
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326
Partition info successfully found
------ Android information ------
Detected LINUX(Android) USERDATA : 0x015B000000 (23.640GB)
Mount EXT4 fs...
Blocks Reading Error (0x15B000400 , 2 , Reason: CMD CRC Error )
Unable to mount USER , code : 5
Done.
Running:Format FRP Partition...
CMD Pullup Level:1732 mV
CLK Rate:7000 kHz
Bus Width:1bit,SDR
eMMC CID : 90014A68423861503E0307411CA34624
eMMC NAME: hB8aP> , S/N: 121707683
EMMC RPMB is programmed and written 577 times
Formatting FRP...
Detected LINUX(Android) FRP : 0x000BE88000 (1.0MB) formatting...
Done.
Detected LINUX(Android) CACHE : 0x0146800000 (328.0MB) , formatting...
Done.
Detected LINUX(Android) USERDATA : 0x015B000000 (23.640GB) , formatting...
Done.
Done.
Done.
The Following 6 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 07-08-2019, 12:10   #47 (permalink)
Member: 13148
Thanks Meter: 1,199
OPPO's FRP reset, Pattern reset thread. Post succcesfully operations at this thread
Post succsecfull operations at this thread
No need to fill the forum with the same threads
The Following 2 Users Say Thank You to layder For This Useful Post:
Old 07-09-2019, 01:55   #48 (permalink)
MOORC's Avatar
Member: 1737647
Sonork: 100.1645466
Thanks Meter: 257
Good job. Brother
从我的 iPhone 发送,使用 Tapatalk
Old 07-09-2019, 01:56   #49 (permalink)
MOORC's Avatar
Member: 1737647
Sonork: 100.1645466
Thanks Meter: 257
https://*********/vLmViAztwX8
Old 07-09-2019, 01:57   #50 (permalink)
MOORC's Avatar
Member: 1737647
Sonork: 100.1645466
Thanks Meter: 257
Old 07-09-2019, 02:32   #51 (permalink)
MOORC's Avatar
Member: 1737647
Sonork: 100.1645466
Thanks Meter: 257
Google have all you need
The Following User Says Thank You to MOORC For This Useful Post:
Old 07-14-2019, 09:25   #52 (permalink)
Member: 744438
Sonork: 100.1640287
Thanks Meter: 243
Oppo A3s Factory Reset, Pattern Lock, Passcode Remove With Easy JTAG
http://www.youtube.com/watch?v=LbqGCVBhCVc
The Following 2 Users Say Thank You to marhabamobiles For This Useful Post:
Old 07-14-2019, 13:50   #53 (permalink)
royalnasim's Avatar
Member: 1037372
Thanks Meter: 470
Thumbs up Today 4 oppo a3s unlock done easy jtag plus rocking always
TODAY 4 OPPO A3S UNLOCK DONE EASY JTAG PLUS ROCKING ALWAYS
The Following User Says Thank You to royalnasim For This Useful Post:
Old 07-14-2019, 17:51   #54 (permalink)
Member: 1409573
Sonork: 100.1615416
Thanks Meter: 57
is it cph1803 you have done? is hynix emmc support ?
Old 07-14-2019, 19:37   #55 (permalink)
Member: 1436243
Thanks Meter: 89
Oppo reno passcode done with ic friend
Just repost
take from moorc ic friend facebook page
Maybe First in the world by Hardware method
Ufs 254 by ic friend
VIDEO
https://www.youtube.com/watch?v=nsrKU3g0Fs0&t=12s
Old 07-15-2019, 09:01   #56 (permalink)
sktamrkar's Avatar
Member: 1810159
Thanks Meter: 239
Realme 2 and Oppo K1 remove locks successfully
Realme 2 logs
Selected pinout: GEN2 ISP Pinout
Change EasyJTAG Pinout OK
Loading eMMC GEN2 Firmware... IO: 3300 mV
Box S/N: 12588BC51D8A7419, ,FW Ver.: 02.44
CMD Pullup Level:2117 mV
CMD Active Level:3162 mV
Box IO Level:3300 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Can't init device, Reason: CMD Timeout Error
Done.
Loading eMMC GEN2 Firmware... IO: 2800 mV
CMD Pullup Level:2093 mV
CMD Active Level:2695 mV
Box IO Level:2800 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
eMMC CID : 150100474436424D42011EE9683B750F
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 07/2018 Rev.0x1
eMMC NAME: GD6BMB , S/N: 518613051
eMMC NAME (HEX): 474436424D42
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 19579 times
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
Backup saved: GD6BMB_ 518613051_20190714_1405.extcsd
------ Detected 64 partitions ------
P0 (OPPODYCNVBK) [0x5000 0xa00000] Size: 10.0MB
P1 (OPPOSTANVBK) [0xa05000 0xa00000] Size: 10.0MB
P2 (MODEMST1) [0x1405000 0x180000] Size: 1.500MB
P3 (MODEMST2) [0x1585000 0x180000] Size: 1.500MB
P4 (PERSIST) [0x1705000 0x2000000] Size: 32.0MB
P5 (OPPORESERVE1) [0x3705000 0x800000] Size: 8.0MB
P6 (OPPORESERVE2) [0x3f05000 0x4000000] Size: 64.0MB
P7 (FSC) [0x7f05000 0x400] Size: 1.0KB
P8 (SSD) [0x7f06000 0x2000] Size: 8.0KB
P9 (SBL1) [0x7f08000 0x80000] Size: 512.0KB
P10 (RPM) [0x7f88000 0x80000] Size: 512.0KB
P11 (TZ) [0x8008000 0x200000] Size: 2.0MB
P12 (DEVCFG) [0x8208000 0x40000] Size: 256.0KB
P13 (SBL1BAK) [0x8248000 0x80000] Size: 512.0KB
P14 (RPMBAK) [0x82c8000 0x80000] Size: 512.0KB
P15 (TZBAK) [0x8348000 0x200000] Size: 2.0MB
P16 (DEVCFGBAK) [0x8548000 0x40000] Size: 256.0KB
P17 (DSP) [0x8588000 0x1000000] Size: 16.0MB
P18 (DDR) [0x9800000 0x8000] Size: 32.0KB
P19 (FSG) [0x9808000 0x400000] Size: 4.0MB
P20 (SEC) [0x9c08000 0x4000] Size: 16.0KB
P21 (ABOOT) [0x9c0c000 0x100000] Size: 1.0MB
P22 (ABOOTBAK) [0x9d0c000 0x100000] Size: 1.0MB
P23 (MODEM) [0x9e0c000 0x8000000] Size: 128.0MB
P24 (DTBO) [0x11e0c000 0x800000] Size: 8.0MB
P25 (VBMETA) [0x1260c000 0x10000] Size: 64.0KB
P26 (BOOT) [0x1261c000 0x4000000] Size: 64.0MB
P27 (RECOVERY) [0x1661c000 0x4000000] Size: 64.0MB
P28 (DEVINFO) [0x1a61c000 0x100000] Size: 1.0MB
P29 (SPLASH) [0x1a800000 0xb00000] Size: 11.0MB
P30 (LOGO) [0x1b300000 0x2000000] Size: 32.0MB
P31 (DRIVER) [0x1d300000 0x2000000] Size: 32.0MB
P32 (CACHE) [0x1f300000 0x10000000] Size: 256.0MB
P33 (MISC) [0x2f300000 0x100000] Size: 1.0MB
P34 (KEYSTORE) [0x2f400000 0x80000] Size: 512.0KB
P35 (CONFIG) [0x2f480000 0x8000] Size: 32.0KB
P36 (LOG) [0x2f488000 0x4000000] Size: 64.0MB
P37 (OEM) [0x33488000 0x100000] Size: 1.0MB
P38 (LIMITS) [0x33800000 0x8000] Size: 32.0KB
P39 (MOTA) [0x34000000 0x80000] Size: 512.0KB
P40 (DIP) [0x34080000 0x100000] Size: 1.0MB
P41 (MDTP) [0x34180000 0x2000000] Size: 32.0MB
P42 (SYSCFG) [0x36180000 0x80000] Size: 512.0KB
P43 (MCFG) [0x36200000 0x400000] Size: 4.0MB
P44 (LKSECAPP) [0x36800000 0x20000] Size: 128.0KB
P45 (CMNLIB) [0x36820000 0x100000] Size: 1.0MB
P46 (CMNLIB64) [0x36920000 0x100000] Size: 1.0MB
P47 (KEYMASTER) [0x36a20000 0x100000] Size: 1.0MB
P48 (LKSECAPPBAK) [0x36b20000 0x20000] Size: 128.0KB
P49 (CMNLIBBAK) [0x36b40000 0x100000] Size: 1.0MB
P50 (CMNLIB64BAK) [0x36c40000 0x100000] Size: 1.0MB
P51 (KEYMASTERBAK) [0x36d40000 0x100000] Size: 1.0MB
P52 (APDP) [0x37000000 0x40000] Size: 256.0KB
P53 (MSADP) [0x37040000 0x40000] Size: 256.0KB
P54 (DPO) [0x37080000 0x2000] Size: 8.0KB
P55 (LOGDUMP) [0x37082000 0x4000000] Size: 64.0MB
P56 (VM-KYSTORE) [0x3b082000 0x100000] Size: 1.0MB
P57 (VM-DATA) [0x3b182000 0xa00000] Size: 10.0MB
P58 (HYP) [0x3c000000 0x800000] Size: 8.0MB
P59 (VM-SYSTEM) [0x3c800000 0x4000000] Size: 64.0MB
P60 (VM-LINUX) [0x40800000 0x2000000] Size: 32.0MB
P61 (SYSTEM) [0x42800000 0xd6900000] Size: 3.352GB
P62 (VENDOR) [0x119100000 0x41f60000] Size: 1.30GB
P63 (USERDATA) [0x15b800000 0x5ec3fbe00] Size: 23.690GB
Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB)
Build ID: OPM1.171019.026
Release Base ID: 8.1.0
Architecture ABI: arm64-v8a
Device manufacturer: OPPO
Build Description: S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20190222.123456 release-keys
Detected USERDATA USERDATA : 0x015B800000 (23.690GB)
Unable to mount USERDATA , code : 95
Done.
Checking security ...
CMD Pullup Level:2092 mV
CMD Active Level:2696 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Detected LINUX(Android) USERDATA : 0x015B800000 (23.690GB)
Mount EXT4 fs...
Unable to mount USER , code : 95
Done.
CMD Pullup Level:2094 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Writing Recovery Command to MISC (33)
Done.
Oppo K1
Loading eMMC GEN2 Firmware... IO: 1800 mV
CMD Pullup Level:1806 mV
CMD Active Level:1867 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
eMMC CID : 15010044483644414202C47CCCB0A569
eMMC Date: 10/2018 Rev.0x2
eMMC NAME: DH6DAB , S/N: 3296513200
eMMC NAME (HEX): 444836444142
EMMC ROM1 (Main User Data) Capacity: 59640 MB
EMMC RPMB is programmed and written 1052 times
Backup saved: DH6DAB_3296513200_20190715_1222.extcsd
------ Detected 69 partitions ------
P2 (MODEMST1) [0x1405000 0x200000] Size: 2.0MB
P3 (MODEMST2) [0x1605000 0x200000] Size: 2.0MB
P4 (PERSIST) [0x1805000 0x2000000] Size: 32.0MB
P5 (OPPORESERVE1) [0x3805000 0x800000] Size: 8.0MB
P6 (OPPORESERVE2) [0x4005000 0x4000000] Size: 64.0MB
P7 (CARRIER) [0x8005000 0x800000] Size: 8.0MB
P8 (XBL) [0x9000000 0x380000] Size: 3.500MB
P9 (XBLBAK) [0x9380000 0x380000] Size: 3.500MB
P10 (TZ) [0x9700000 0x400000] Size: 4.0MB
P11 (TZBAK) [0x9b00000 0x400000] Size: 4.0MB
P12 (RPM) [0x9f00000 0x80000] Size: 512.0KB
P13 (RPMBAK) [0x9f80000 0x80000] Size: 512.0KB
P14 (HYP) [0xa000000 0x80000] Size: 512.0KB
P15 (HYPBAK) [0xa080000 0x80000] Size: 512.0KB
P16 (PMIC) [0xa100000 0x80000] Size: 512.0KB
P17 (PMICBAK) [0xa180000 0x80000] Size: 512.0KB
P18 (FSG) [0xa200000 0x200000] Size: 2.0MB
P19 (BOOT) [0xa800000 0x4000000] Size: 64.0MB
P20 (BOOTBAK) [0xe800000 0x4000000] Size: 64.0MB
P21 (RECOVERY) [0x12800000 0x4000000] Size: 64.0MB
P22 (KEYMASTER) [0x16800000 0x100000] Size: 1.0MB
P23 (KEYMASTERBAK) [0x16900000 0x100000] Size: 1.0MB
P24 (CMNLIB) [0x16a00000 0x100000] Size: 1.0MB
P25 (CMNLIB64) [0x16b00000 0x100000] Size: 1.0MB
P26 (CMNLIBBAK) [0x16c00000 0x100000] Size: 1.0MB
P27 (CMNLIB64BAK) [0x16d00000 0x100000] Size: 1.0MB
P28 (MDTPSECAPP) [0x16e00000 0x400000] Size: 4.0MB
P29 (MDTPSECAPPBAK) [0x17200000 0x400000] Size: 4.0MB
P30 (MDTP) [0x17600000 0x2000000] Size: 32.0MB
P31 (MDTPBAK) [0x19600000 0x2000000] Size: 32.0MB
P32 (DSP) [0x1b600000 0x1000000] Size: 16.0MB
P33 (DSPBAK) [0x1c600000 0x1000000] Size: 16.0MB
P34 (ABL) [0x1d600000 0x100000] Size: 1.0MB
P35 (ABLBAK) [0x1d700000 0x100000] Size: 1.0MB
P36 (DIP) [0x1d800000 0x100000] Size: 1.0MB
P37 (DEVINFO) [0x1d900000 0x1000] Size: 4.0KB
P38 (APDP) [0x1d901000 0x40000] Size: 256.0KB
P39 (MSADP) [0x1d941000 0x40000] Size: 256.0KB
P40 (DPO) [0x1d981000 0x400] Size: 1.0KB
P41 (SPLASH) [0x1d982000 0x20a4000] Size: 32.640MB
P42 (LIMITS) [0x1fa26000 0x1000] Size: 4.0KB
P43 (TOOLSFV) [0x1fa27000 0x100000] Size: 1.0MB
P44 (LOGFS) [0x20000000 0x800000] Size: 8.0MB
P45 (DDR) [0x20800000 0x100000] Size: 1.0MB
P46 (SEC) [0x20900000 0x4000] Size: 16.0KB
P47 (BLUETOOTH) [0x20904000 0x100000] Size: 1.0MB
P48 (BLUETOOTHBAK) [0x20a04000 0x100000] Size: 1.0MB
P49 (FSC) [0x21000000 0x400] Size: 1.0KB
P50 (SSD) [0x21001000 0x2000] Size: 8.0KB
P51 (MISC) [0x21003000 0x100000] Size: 1.0MB
P52 (KEYSTORE) [0x21103000 0x80000] Size: 512.0KB
P53 (DEVCFG) [0x21183000 0x100000] Size: 1.0MB
P54 (DEVCFGBAK) [0x21283000 0x100000] Size: 1.0MB
P55 (FRP) [0x21383000 0x80000] Size: 512.0KB
P56 (LOGDUMP) [0x21403000 0x4000000] Size: 64.0MB
P57 (STI) [0x25403000 0x200000] Size: 2.0MB
P58 (LOGO) [0x25603000 0x1000000] Size: 16.0MB
P59 (DRIVER) [0x26603000 0x2000000] Size: 32.0MB
P60 (VBMETA) [0x28800000 0x10000] Size: 64.0KB
P61 (VBMETABAK) [0x28810000 0x10000] Size: 64.0KB
P62 (MODEM) [0x28820000 0x8000000] Size: 128.0MB
P63 (CACHE) [0x31000000 0x10000000] Size: 256.0MB
P64 (SYSTEM) [0x41000000 0x150000000] Size: 5.250GB
P65 (VENDOR) [0x191000000 0x60000000] Size: 1.500GB
P66 (ODM) [0x1f1000000 0x10000000] Size: 256.0MB
P67 (STORSEC) [0x201000000 0x20000] Size: 128.0KB
P68 (USERDATA) [0x201800000 0xc8dffbe00] Size: 50.217GB
Detected LINUX(Android) SYSTEM : 0x0041000000 (5.250GB)
Build ID: OPM1.171019.011
Build Description: sdm660_64-user 8.1.0 OPM1.171019.011 eng.root.20190523.001645 release-keys
Detected USERDATA USERDATA : 0x0201800000 (50.217GB)
Done.
CMD Pullup Level:1805 mV
CMD Active Level:1866 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes
Detected LINUX(Android) USERDATA : 0x0201800000 (50.217GB)
Mount EXT4 fs...
Done.
CLK Rate:24000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Writing Recovery Command to MISC (51)
Done.
Old 07-15-2019, 13:03   #57 (permalink)
Member: 2185549
Thanks Meter: 461
oppo a3s done
wipe userdata and frp done by emmc
EasyJtag Suite Classic ver.: 3.6.1.2 / wxWidgets 3.1.0-W-U started.
OS ver.: Windows 10 (build 10586), 64-bit edition. Admin rights FAIL
Android Explorer ver:1.0.0.13
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
eMMC Odin ver:1.0.0.6
QUALCOMM Direct ver:1.0.6936.8894
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 10.0.10586.306, are OK
Z3X Card Serial : AAF9-6E71 , ver: 22
Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Found 3 serial devices
COM50 USB\VID_0325&PID_0032&REV_0100&MI_00 USB Serial Device (COM50)
COM4 root\rimports RIM Virtual Serial Port v2 (COM4)
COM5 root\rimports RIM Virtual Serial Port v2 (COM5)
Selected pinout: EasyJTAG GEN1 ISP Pinout
Z3X EasyJtag Software ver. 3.6.1.2
Loading eMMC GEN1 Firmware... IO: 3300 mV
Box S/N: 12FFA012870558E8, ,FW Ver.: 01.63
Warning: CMD Pullup Level (0 mV) too low , check cables etc.!
CMD Active Level:1165 mV
CLK Rate:1000 kHz
Bus Width:1bit,SDR
Done.
CMD Pullup Level:1691 mV
CMD Active Level:2660 mV
CLK Rate:1000 kHz
Bus Width:1bit,SDR
Done.
CMD Active Level:2887 mV
CLK Rate:1000 kHz
Bus Width:1bit,SDR
eMMC CID : 150100514536334D420680B8CEFE654C
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Date: 06/2018 Rev.0x6
eMMC NAME: QE63MB , S/N: 2159595262
eMMC NAME (HEX): 514536334D42
IC Name: Samsung , KMQE60013M-B318/16GB @BGA221
EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes
EMMC RPMB is programmed and written 69466 times
Backup saved: QE63MB_2159595262_20190715_1458.extcsd
Card Supported Command sets [S_CMD_SET: 0x01]
HPI Features [HPI_FEATURE: 0x01]:
implementation based on CMD13
Background operations support [BKOPS_SUPPORT: 0x01]
Max Packet Read Cmd [MAX_PACKED_READS: 0x3f]
Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f]
Data TAG support [DATA_TAG_SUPPORT: 0x01]
Data TAG Unit Size [TAG_UNIT_SIZE: 0x02]
Tag Resources Size [TAG_RES_SIZE: 0x00]
Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05]
Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07]
Extended partition attribute support [EXT_SUPPORT: 0x03]
Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a]
Power off notification [POWER_OFF_LONG_TIME: 0x3c]
Cache Size [CACHE_SIZE] is 65536 KiB
------------------------- eMMC v5+ -------------------------
Supported modes [SUPPORTED_MODES: 0x03]
FFU features [FFU_FEATURES: 0x00]
Operation codes timeout [OPERATION_CODE_TIMEOUT: 0x00]
FFU Argument [FFU_ARG: 0xc7810000]
Number of FW sectors correctly programmed[NUM_OF_FW_SECT_CORR_PROG: 0]
Vendor proprietary health report:
[VENDOR_PROPRIETARY_HEALTH_REPORT[301]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[300]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[299]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[298]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[297]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[296]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[295]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[294]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[293]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[292]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[291]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[290]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[289]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[288]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[287]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[286]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[285]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[284]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[283]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[282]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[281]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[280]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[279]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[278]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[277]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[276]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[275]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[274]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[273]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[272]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[271]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[270]]:0x00
_(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_B: 0x04]
i.e. 30% - 40% device life time used
_(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_A: 0x04]
Pre EOL information [PRE_EOL_INFO: 0x01]
i.e. Normal
Optimal read size [OPTIMAL_READ_SIZE: 0x00]
Optimal write size [OPTIMAL_WRITE_SIZE: 0x08]
Optimal trim unit size [OPTIMAL_TRIM_UNIT_SIZE: 0x01]
Device version [DEVICE_VERSION: 0x00 - 0x00]
Firmware version:
[FIRMWARE_VERSION[261]]: 0x00
[FIRMWARE_VERSION[260]]: 0x00
[FIRMWARE_VERSION[259]]: 0x00
[FIRMWARE_VERSION[258]]: 0x00
[FIRMWARE_VERSION[257]]: 0x00
[FIRMWARE_VERSION[256]]: 0x00
[FIRMWARE_VERSION[255]]: 0x00
[FIRMWARE_VERSION[254]]: 0x06
Power class for 200MHz, DDR at VCC= 3.6V [PWR_CL_DDR_200_360: 0x00]
Background operations status [BKOPS_STATUS: 0x00]
1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x1e]
Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00]
Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00]
Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00]
Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00]
Minimum Performance for 8bit at 52MHz in DDR mode:
[MIN_PERF_DDR_W_8_52: 0x00]
[MIN_PERF_DDR_R_8_52: 0x00]
TRIM Multiplier [TRIM_MULT: 0x02]
Secure Feature support [SEC_FEATURE_SUPPORT: 0x55]
Boot Information [BOOT_INFO: 0x07]
Device supports alternative boot method
Device supports dual data rate during boot
Device supports high speed timing during boot
Boot partition size [BOOT_SIZE_MULTI: 0x20]
Access size [ACC_SIZE: 0x07]
High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01]
High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01]
Reliable write sector count [REL_WR_SEC_C: 0x01]
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10]
Sleep current (VCC) [S_C_VCC: 0x07]
Sleep current (VCCQ) [S_C_VCCQ: 0x07]
Sleep/awake timeout [S_A_TIMEOUT: 0x11]
Sector Count [SEC_COUNT: 0x01d1f000]
Minimum Write Performance for 8bit:
[MIN_PERF_W_8_52: 0x00]
[MIN_PERF_R_8_52: 0x00]
[MIN_PERF_W_8_26_4_52: 0x00]
[MIN_PERF_R_8_26_4_52: 0x00]
Minimum Write Performance for 4bit:
[MIN_PERF_W_4_26: 0x00]
[MIN_PERF_R_4_26: 0x00]
Power classes registers:
[PWR_CL_26_360: 0x00]
[PWR_CL_52_360: 0x00]
[PWR_CL_26_195: 0x00]
[PWR_CL_52_195: 0x00]
Partition switching timing [PARTITION_SWITCH_TIME: 0x02]
Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x0a]
I/O Driver Strength [DRIVER_STRENGTH: 0x1f]
Card Type [CARD_TYPE: 0x57]
CSD structure version [CSD_STRUCTURE: 0x02]
Command set [CMD_SET: 0x00]
Command set revision [CMD_SET_REV: 0x00]
Power class [POWER_CLASS: 0x00]
High-speed interface timing [HS_TIMING: 0x00]
Erased memory content [ERASED_MEM_CONT: 0x00]
Boot configuration bytes [PARTITION_CONFIG: 0x38]
No access to boot partition
Boot config protection [BOOT_CONFIG_PROT: 0x00]
Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00]
High-density erase group definition [ERASE_GROUP_DEF: 0x00]
Boot write protection status registers [BOOT_WP_STATUS]: 0x00
Boot Area Write protection [BOOT_WP]: 0x00
Power ReadOnly locking: possible
Permanent ReadOnly locking: possible
Read Only lock status: not locked
User area write protection register [USER_WP]: 0x00
FW configuration [FW_CONFIG]: 0x00
RPMB Size [RPMB_SIZE_MULT]: 0x20
Write reliability setting register [WR_REL_SET]: 0x1f
Write reliability parameter register [WR_REL_PARAM]: 0x14
Enable background operations handshake [BKOPS_EN]: 0x02
HPI management [HPI_MGMT]: 0x00
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0003a3
Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00
General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000
[GP_SIZE_MULT_3]: 0x000000
[GP_SIZE_MULT_2]: 0x000000
[GP_SIZE_MULT_1]: 0x000000
Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000
Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000
Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00
Periodic Wake-up [PERIODIC_WAKEUP]: 0x00
Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01
Native sector size [NATIVE_SECTOR_SIZE]: 0x00
Sector size emulation [USE_NATIVE_SECTOR]: 0x00
Sector size [DATA_SECTOR_SIZE]: 0x00
1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00
Class 6 commands control [CLASS_6_CTRL]: 0x00
Number of addressed group to be released[DYNCAP_NEEDED]: 0x00
Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000
Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000
Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000
Packed command status [PACKED_COMMAND_STATUS]: 0x00
Packed command failure index [PACKED_FAILURE_INDEX]: 0x00
Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00
Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00
Partition table scan:
GPT: present
Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB
Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
First usable sector: 34
Last usable sector: 30535646
Found Data areas (firmware parts) count is: 65
P7 (RESERVE_EXP1) [0x7f05000 0x200000] Size: 2.0MB
P8 (RESERVE_EXP2) [0x8105000 0x200000] Size: 2.0MB
P9 (FSC) [0x8305000 0x400] Size: 1.0KB
P10 (SSD) [0x8306000 0x2000] Size: 8.0KB
P11 (SBL1) [0x8308000 0x80000] Size: 512.0KB
P12 (RPM) [0x8388000 0x80000] Size: 512.0KB
P13 (TZ) [0x8408000 0x200000] Size: 2.0MB
P14 (DEVCFG) [0x8608000 0x40000] Size: 256.0KB
P15 (SBL1BAK) [0x8648000 0x80000] Size: 512.0KB
P16 (RPMBAK) [0x86c8000 0x80000] Size: 512.0KB
P17 (TZBAK) [0x8748000 0x200000] Size: 2.0MB
P18 (DEVCFGBAK) [0x8948000 0x40000] Size: 256.0KB
P19 (DSP) [0x8988000 0x1000000] Size: 16.0MB
P20 (DDR) [0xa000000 0x8000] Size: 32.0KB
P21 (FSG) [0xa008000 0x180000] Size: 1.500MB
P22 (SEC) [0xa188000 0x4000] Size: 16.0KB
P23 (ABOOT) [0xa18c000 0x100000] Size: 1.0MB
P24 (ABOOTBAK) [0xa28c000 0x100000] Size: 1.0MB
P25 (MODEM) [0xa38c000 0x8000000] Size: 128.0MB
P26 (DTBO) [0x1238c000 0x800000] Size: 8.0MB
P27 (VBMETA) [0x12b8c000 0x10000] Size: 64.0KB
P28 (BOOT) [0x12b9c000 0x4000000] Size: 64.0MB
P29 (RECOVERY) [0x16b9c000 0x4000000] Size: 64.0MB
P30 (DEVINFO) [0x1ab9c000 0x100000] Size: 1.0MB
P31 (SPLASH) [0x1b000000 0xb00000] Size: 11.0MB
P32 (LOGO) [0x1bb00000 0x2000000] Size: 32.0MB
P33 (DRIVER) [0x1db00000 0x2000000] Size: 32.0MB
P34 (CACHE) [0x1fb00000 0x10000000] Size: 256.0MB
P35 (MISC) [0x2fb00000 0x100000] Size: 1.0MB
P36 (KEYSTORE) [0x2fc00000 0x80000] Size: 512.0KB
P37 (CONFIG) [0x2fc80000 0x8000] Size: 32.0KB
P38 (OEM) [0x2fc88000 0x100000] Size: 1.0MB
P39 (LIMITS) [0x30000000 0x8000] Size: 32.0KB
P40 (MOTA) [0x30800000 0x80000] Size: 512.0KB
P41 (DIP) [0x30880000 0x100000] Size: 1.0MB
P42 (MDTP) [0x30980000 0x2000000] Size: 32.0MB
P43 (SYSCFG) [0x32980000 0x80000] Size: 512.0KB
P44 (MCFG) [0x32a00000 0x400000] Size: 4.0MB
P45 (LKSECAPP) [0x33000000 0x20000] Size: 128.0KB
P46 (CMNLIB) [0x33020000 0x100000] Size: 1.0MB
P47 (CMNLIB64) [0x33120000 0x100000] Size: 1.0MB
P48 (KEYMASTER) [0x33220000 0x100000] Size: 1.0MB
P49 (LKSECAPPBAK) [0x33320000 0x20000] Size: 128.0KB
P50 (CMNLIBBAK) [0x33340000 0x100000] Size: 1.0MB
P51 (CMNLIB64BAK) [0x33440000 0x100000] Size: 1.0MB
P52 (KEYMASTERBAK) [0x33540000 0x100000] Size: 1.0MB
P53 (APDP) [0x33800000 0x40000] Size: 256.0KB
P54 (MSADP) [0x33840000 0x40000] Size: 256.0KB
P55 (DPO) [0x33880000 0x2000] Size: 8.0KB
P56 (LOGDUMP) [0x33882000 0x4000000] Size: 64.0MB
P57 (VM-KYSTORE) [0x37882000 0x100000] Size: 1.0MB
P58 (VM-DATA) [0x37982000 0xa00000] Size: 10.0MB
P59 (HYP) [0x38800000 0x800000] Size: 8.0MB
P60 (VM-SYSTEM) [0x39000000 0x4000000] Size: 64.0MB
P61 (VM-LINUX) [0x3d000000 0x2000000] Size: 32.0MB
P62 (SYSTEM) [0x3f000000 0xd6900000] Size: 3.352GB
P63 (VENDOR) [0x115900000 0x41f60000] Size: 1.30GB
P64 (USERDATA) [0x158000000 0x24bdfbe00] Size: 9.184GB
Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB)
Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20190323.213841 release-keys
Detected USERDATA USERDATA : 0x0158000000 (9.184GB)
Done.
CMD Pullup Level:1722 mV
CLK Rate:1000 kHz
Bus Width:1bit,SDR
GPT: present
Formatting FRP...
Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) CONFIG : 0x002FC80000 (32.0KB) formatting...
Done.
Detected LINUX(Android) USERDATA : 0x0158000000 (9.184GB) , formatting...
Done.
Done.
Done.
CMD Active Level:2897 mV
CLK Rate:1000 kHz
Bus Width:1bit,SDR
GPT: present
Erasing...
Done.
Erasing...
Done.
Done.
Old 07-15-2019, 13:09   #58 (permalink)
Member: 2185549
Thanks Meter: 461
oppo a3s done
CLK Rate:1000 kHz
Bus Width:1bit,SDR
Done.
CLK Rate:1000 kHz
Bus Width:1bit,SDR
Done.
CLK Rate:1000 kHz
Bus Width:1bit,SDR
i.e. Normal
Firmware version:
GPT: present
Done.
CLK Rate:1000 kHz
Bus Width:1bit,SDR
GPT: present
Formatting FRP...
Done.
Done.
Done.
Done.
Done.
CLK Rate:1000 kHz
Bus Width:1bit,SDR
GPT: present
Erasing...
Done.
Erasing...
Done.
Done.
Old 07-16-2019, 05:59   #59 (permalink)
royalnasim's Avatar
Member: 1037372
Thanks Meter: 470
Thumbs up Oppo a7 unlock done by easy jtag
OPPO A7 UNLOCK DONE BY EASY JTAG
Old 07-16-2019, 17:16   #60 (permalink)
meeza_84's Avatar
Member: 279362
Sonork: 100.1594141
Thanks Meter: 443
Realme C1,A3S Pattern Remove Done With Easy Jtag
Realme C1,A3S How To Reset Free Pattern Unlock | How To Hard Reset Realme C1 Easy Jtag
Page generated in 0.43114 seconds with 7 queries
