Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 08-04-2019, 08:59   #76 (permalink)
Member: 933096
Sonork: inocentedeti
Thanks Meter: 18
good job sir, clear and sound safe to remove FRP via TP
Old 08-09-2019, 21:05   #77 (permalink)
Member: 2196491
Thanks Meter: 2
Which option use in easy zteg to remove password for oppo a1k or c2. I used oppo reset option command done but pattern not remove.
Old 08-11-2019, 21:18   #78 (permalink)
engcobocell's Avatar
Member: 2590583
Thanks Meter: 167
Sound strange
Please can you post logo
Sent from my SM-A520F using Tapatalk
Old 08-11-2019, 23:17   #79 (permalink)
buffer2k11's Avatar
Member: 2604648
Thanks Meter: 297
oppo reset function use only for qualcomm
for mtk use android frp clear option
br,
Old 08-13-2019, 07:48   #80 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 748
OPPO A3S remove pass code done
Z3X EasyJtag Software ver. 3.6.1.2
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 0F01300C22E581EB, ,FW Ver.: 01.63
CMD Pullup Level:1990 mV
CMD Active Level:2588 mV
Box IO Level:2800 mV
CLK Rate:14000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 150100514536334D420663F768F0B52A
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 11/2018 Rev.0x6
eMMC NAME: QE63MB , S/N: 1677158640
eMMC NAME (HEX): 514536334D42
IC Name: Samsung , KMQE60013M-B318/16GB @BGA221
EMMC ROM1 (Main User Data) Capacity: 14910 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 67468 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QE63MB_1677158640_20190813_1323.extcsd
Done.
CLK Rate:14000 kHz
Bus Width:1bit,SDR
EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes
Partition table scan:
GPT: present
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB
Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
First usable sector: 34
Last usable sector: 30535646
Partition info successfully found
------ Android information ------
Detected LINUX(Android) CACHE : 0x001F300000 (256.0MB)
Erasing...
Done.
Detected LINUX(Android) USERDATA : 0x015B800000 (9.129GB)
Erasing...
Done.
Done.
Running:Format FRP Partition...
CMD Active Level:2578 mV
CLK Rate:14000 kHz
Bus Width:1bit,SDR
GPT: present
Formatting FRP...
Detected LINUX(Android) CACHE : 0x001F300000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) CONFIG : 0x002F480000 (32.0KB) formatting...
Done.
Detected LINUX(Android) USERDATA : 0x015B800000 (9.129GB) , formatting...
Done.
Done.
Done.
CLK Rate:14000 kHz
Bus Width:1bit,SDR
Done.
The Following 2 Users Say Thank You to Deni's For This Useful Post:
Old 08-16-2019, 07:20   #81 (permalink)
Member: 2831834
Pls help to by pass lockscreen on oppo f11 when i go to recovery mode the wipe data or erase data has a password to it says enter the lockscreen
Old 08-18-2019, 12:14   #82 (permalink)
Member: 2582195
Thanks Meter: 2
real me 2 unlock done
http://i68.tinypic.com/2e1zk42.jpg
POWER OF JTAG PLUS
Old 08-19-2019, 02:08   #83 (permalink)
Member: 1813906
Sonork: 100.1618216
Thanks Meter: 20
Oppo A3s CPH1853 remove lock screen and frp just one click Oppo reset
Selected pinout: GEN2 ISP Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.6.1.14
Loading eMMC GEN2 Firmware... IO: 2800 mV
Box S/N: F0491474C976AB1B, ,FW Ver.: 02.48
CMD Pullup Level:2075 mV
CMD Active Level:2716 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Checking security ...
CMD Pullup Level:2073 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
eMMC CID : 150100514536334D4204E51AAAA826AD
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Date: 02/2019 Rev.0x4
eMMC NAME: QE63MB , S/N: 3843730088
EMMC RPMB is programmed and written 13074 times
Backup saved: QE63MB_3843730088_20190818_1743.extcsd
Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB)
Build ID: OPM1.171019.026
Release Base ID: 8.1.0
Architecture ABI: arm64-v8a
Device manufacturer: OPPO
Build Description: S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20190624.211613 release-keys
Detected USERDATA USERDATA : 0x015B800000 (9.129GB)
Unable to mount USERDATA , code : 95
Done.
CMD Active Level:2714 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
Writing Recovery Command to MISC (33)
Done.
Old 08-21-2019, 06:52   #84 (permalink)
Member: 1784151
Sonork: 0
Thanks Meter: 71
I love Easy JTAG, this need activation? I have Easy JTAG Box and Z3X Box
Page generated in 0.22958 seconds with 7 queries
