Old 07-03-2019, 07:52   #16 (permalink)
akash48's Avatar
Member: 1588653
Sonork: imran_Gill
Thanks Meter: 83
sir where is setup link
The Following User Says Thank You to akash48 For This Useful Post:
Old 07-03-2019, 11:16   #17 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
You need read stiked topics
http://forum.gsmhosting.com/vbb/f672.../#post13717222
The Following User Says Thank You to layder For This Useful Post:
Old 07-03-2019, 14:31   #18 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 952
As I see from log this is a Qualcomm based device. Does this function work with MTK based devices too?
Old 07-04-2019, 06:13   #19 (permalink)
Member: 1100311
Sonork: 100.1624110
Thanks Meter: 39
only media recoverd. massages and contact not recovered.
The Following User Says Thank You to sackam2010 For This Useful Post:
Old 07-04-2019, 09:04   #20 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,424
Smile OPPO A3s F.R.p & Pattern Done Stuck In Qlcm Mode Done
Special Thanks To My bro Mukesh Jha Jadeja ..::CHAIN::.. Who had helped me To Recover from Qlcm Mode Love You Bro You Are Great
Running:Reset PIN/PASS/GESTURE Locks
Z3X EasyJtag Software ver. 3.6.1.4
Loading eMMC GEN1 Firmware... IO: 1800 mV
Box S/N: 1818041DBF5EF1D5, ,FW Ver.: 01.63
CMD Pullup Level:1722 mV
CMD Active Level:1825 mV
Box IO Level:1800 mV
CLK Rate:14000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 90014A68423861503E03C7D06AB2C5CC
eMMC CSD : D02700328F5903FFFFFFFFEF8E400042
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 12/2018 Rev.0x3
eMMC NAME: hB8aP> , S/N: 3352324786
eMMC NAME (HEX): 68423861503E
EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 31274 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Partition info successfully found
------ Android information ------
Detected LINUX(Android) USERDATA : 0x0158000000 (23.745GB)
Mount EXT4 fs...
Unable to mount USER , code : 95
Done.
Running:Format FRP Partition...
CMD Pullup Level:1732 mV
CMD Active Level:1835 mV
CLK Rate:14000 kHz
Bus Width:1bit,SDR
Formatting FRP...
Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) CONFIG : 0x002FC80000 (32.0KB) formatting...
Done.
Detected LINUX(Android) USERDATA : 0x0158000000 (23.745GB) , formatting...
Done.
Done.
Done.
The Following 4 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 07-04-2019, 09:37   #21 (permalink)
Member: 230504
Thanks Meter: 68
help request
Please can you give more details about repair procedure ??
thanks in advance
Old 07-04-2019, 09:50   #22 (permalink)
Member: 655261
Thanks Meter: 46
help me..how to Recover from Qlcm Mode ?
Old 07-04-2019, 10:26   #23 (permalink)
Member: 1683245
Sonork: 100.1668667
Thanks Meter: 23
Will u plse help me i also facing a problem
Old 07-04-2019, 10:50   #24 (permalink)
gayansuranga's Avatar
Member: 230004
Thanks Meter: 174
replace clk resistor the same value
Old 07-04-2019, 10:55   #25 (permalink)
Member: 655261
Thanks Meter: 46
thanks but still QLC mode
Old 07-04-2019, 11:00   #26 (permalink)
Member: 230004
Thanks Meter: 174
it must be the same.. jumping it will not work try some same size resistors in apple. I don't really remember the value
Old 07-04-2019, 11:06   #27 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 940
remove and make jumper.......tested by me
Old 07-04-2019, 11:41   #28 (permalink)
Member: 655261
Thanks Meter: 46
thanks..but not ok for me...
Old 07-04-2019, 11:44   #29 (permalink)
Member: 230004
Thanks Meter: 174
what was the reason your needed to go with emmc direct. was it a user lock or somthing
Old 07-04-2019, 14:15   #30 (permalink)
VC_INDIA's Avatar
Member: 1236722
Sonork: 100.1601546
Thanks Meter: 4,180
Oppo A3s Done By Easy Jtag
The Following 3 Users Say Thank You to VC_INDIA For This Useful Post:
Page generated in 0.26738 seconds with 9 queries
