Old 08-04-2019, 12:55   #76 (permalink)
Member: 2453200
Thanks Meter: 102
Originally Posted by Gsmnirmal View Post
oppo a1k emmc pinout send bro
The Following User Says Thank You to Resident_Evil For This Useful Post:
Old 08-07-2019, 12:28   #77 (permalink)
Member: 2332340
Thanks Meter: 8
Yes all done. I already done with 1generation box work fine
Old 08-08-2019, 01:24   #78 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
done 1 but i get Mediatek usb port only ,phone can't power on at all
any suggestion ? thank you
Old 08-09-2019, 21:05   #79 (permalink)
Member: 2196491
Thanks Meter: 3
Which option use in easy zteg to remove password for oppo a1k or c2. I used oppo reset option command done but pattern not remove.
Old 08-11-2019, 21:18   #80 (permalink)
engcobocell's Avatar
Member: 2590583
Thanks Meter: 198
Sound strange
Please can you post logo
Sent from my SM-A520F using Tapatalk
Old 08-11-2019, 23:17   #81 (permalink)
buffer2k11's Avatar
Member: 2604648
Thanks Meter: 346
oppo reset function use only for qualcomm
for mtk use android frp clear option
br,
The Following User Says Thank You to buffer2k11 For This Useful Post:
Old 08-13-2019, 07:48   #82 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 940
OPPO A3S remove pass code done
Z3X EasyJtag Software ver. 3.6.1.2
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 0F01300C22E581EB, ,FW Ver.: 01.63
CMD Pullup Level:1990 mV
CMD Active Level:2588 mV
Box IO Level:2800 mV
CLK Rate:14000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 150100514536334D420663F768F0B52A
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 11/2018 Rev.0x6
eMMC NAME: QE63MB , S/N: 1677158640
eMMC NAME (HEX): 514536334D42
IC Name: Samsung , KMQE60013M-B318/16GB @BGA221
EMMC ROM1 (Main User Data) Capacity: 14910 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 67468 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QE63MB_1677158640_20190813_1323.extcsd
Done.
CLK Rate:14000 kHz
Bus Width:1bit,SDR
EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes
Partition table scan:
GPT: present
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB
Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
First usable sector: 34
Last usable sector: 30535646
Partition info successfully found
------ Android information ------
Detected LINUX(Android) CACHE : 0x001F300000 (256.0MB)
Erasing...
Done.
Detected LINUX(Android) USERDATA : 0x015B800000 (9.129GB)
Erasing...
Done.
Done.
Running:Format FRP Partition...
CMD Active Level:2578 mV
CLK Rate:14000 kHz
Bus Width:1bit,SDR
GPT: present
Formatting FRP...
Detected LINUX(Android) CACHE : 0x001F300000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) CONFIG : 0x002F480000 (32.0KB) formatting...
Done.
Detected LINUX(Android) USERDATA : 0x015B800000 (9.129GB) , formatting...
Done.
Done.
Done.
CLK Rate:14000 kHz
Bus Width:1bit,SDR
Done.
The Following 3 Users Say Thank You to Deni's For This Useful Post:
Old 08-14-2019, 18:21   #83 (permalink)
Member: 418250
Thanks Meter: 2
did you found solution?
Old 08-16-2019, 04:32   #84 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
U use oppo reset button
So ur boot configuration is change
Post log 4 better help
The Following User Says Thank You to VIJAY2U2 For This Useful Post:
Old 08-16-2019, 07:20   #85 (permalink)
Member: 2831834
Pls help to by pass lockscreen on oppo f11 when i go to recovery mode the wipe data or erase data has a password to it says enter the lockscreen
Old 08-18-2019, 12:14   #86 (permalink)
Member: 2582195
Thanks Meter: 3
real me 2 unlock done
http://i68.tinypic.com/2e1zk42.jpg
POWER OF JTAG PLUS
Old 08-18-2019, 15:17   #87 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
thank you here's log:
EasyJtag Suite Classic ver.: 3.6.1.4 / wxWidgets 3.1.2-W-U started.
OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights OK
Android Explorer ver:1.0.0.13
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
eMMC Odin ver:1.0.0.6
QUALCOMM Direct ver:1.0.6936.8894
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 3.0.0.0, are OK
Z3X Card Serial : AAE1-01DB , ver: 22
Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Found 3 serial devices
COM241 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Control Port (COM241)
COM183 root\rimports RIM Virtual Serial Port v2 (COM183)
COM90 root\rimports RIM Virtual Serial Port v2 (COM90)
Selected pinout: EasyJTAG GEN1 ISP Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.6.1.4
Box S/N: 13130E17E1AD950F, ,FW Ver.: 01.63
CMD Pullup Level:2010 mV
CMD Active Level:2516 mV
CLK Rate:7000 kHz
Bus Width:1bit,SDR
eMMC CID : 150100514436334D4203980BCEA8266E
eMMC Date: 02/2019 Rev.0x3
eMMC NAME: QD63MB , S/N: 2550910632
eMMC NAME (HEX): 514436334D42
EMMC ROM1 (Main User Data) Capacity: 29820 MB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 718 times
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48.
Backup saved: QD63MB_2550910632_20190725_0258.extcsd
GPT: present
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Disk identifier (GUID): 00000000-0000-0000-0000-000000000000
Last usable sector: 61071326
Found Data areas (firmware parts) count is: 42
P0 (BOOT_PARA) [0x8000 0x100000] Size: 1.0MB
P1 (RECOVERY) [0x108000 0x2000000] Size: 32.0MB
P2 (PARA) [0x2108000 0x80000] Size: 512.0KB
P3 (OPPORESERVE1) [0x2188000 0x800000] Size: 8.0MB
P4 (OPPORESERVE2) [0x2988000 0x4000000] Size: 64.0MB
P5 (OPPORESERVE3) [0x6988000 0x4000000] Size: 64.0MB
P6 (OPPO_CUSTOM) [0xa988000 0x100000] Size: 1.0MB
P7 (EXPDB) [0xaa88000 0x1400000] Size: 20.0MB
P8 (FRP) [0xbe88000 0x100000] Size: 1.0MB
P9 (VBMETA) [0xbf88000 0x800000] Size: 8.0MB
P10 (NVCFG) [0xc788000 0x2000000] Size: 32.0MB
P11 (NVDATA) [0xe788000 0x4000000] Size: 64.0MB
P12 (METADATA) [0x12788000 0x2000000] Size: 32.0MB
P13 (PROTECT1) [0x14788000 0x800000] Size: 8.0MB
P14 (PROTECT2) [0x14f88000 0x878000] Size: 8.468MB
P15 (SECCFG) [0x15800000 0x800000] Size: 8.0MB
P16 (PERSIST) [0x16000000 0x3000000] Size: 48.0MB
P17 (SEC1) [0x19000000 0x200000] Size: 2.0MB
P18 (PROINFO) [0x19200000 0x300000] Size: 3.0MB
P19 (MD1IMG) [0x19500000 0x6400000] Size: 100.0MB
P20 (SPMFW) [0x1f900000 0x100000] Size: 1.0MB
P21 (SCP1) [0x1fa00000 0x100000] Size: 1.0MB
P22 (SCP2) [0x1fb00000 0x100000] Size: 1.0MB
P23 (SSPM_1) [0x1fc00000 0x100000] Size: 1.0MB
P24 (SSPM_2) [0x1fd00000 0x100000] Size: 1.0MB
P25 (GZ1) [0x1fe00000 0x1000000] Size: 16.0MB
P26 (GZ2) [0x20e00000 0x1000000] Size: 16.0MB
P27 (NVRAM) [0x21e00000 0x4000000] Size: 64.0MB
P28 (LK) [0x25e00000 0x100000] Size: 1.0MB
P29 (LK2) [0x25f00000 0x100000] Size: 1.0MB
P30 (BOOT) [0x26000000 0x2000000] Size: 32.0MB
P31 (LOGO) [0x28000000 0x1000000] Size: 16.0MB
P32 (DTBO) [0x29000000 0x1000000] Size: 16.0MB
P33 (TEE1) [0x2a000000 0x500000] Size: 5.0MB
P34 (TEE2) [0x2a500000 0xb00000] Size: 11.0MB
P35 (ODM) [0x2b000000 0x10000000] Size: 256.0MB
P36 (VENDOR) [0x3b000000 0x39800000] Size: 920.0MB
P37 (SYSTEM) [0x74800000 0x12c000000] Size: 4.687GB
P38 (CACHE) [0x1a0800000 0x1b000000] Size: 432.0MB
P39 (USERDATA) [0x1bb800000 0x5888fbe00] Size: 22.132GB
P40 (OTP) [0x7440fbe00 0x2b00000] Size: 43.0MB
P41 (FLASHINFO) [0x746bfbe00 0x1000000] Size: 16.0MB
Detected LINUX(Android) SYSTEM : 0x0074800000 (4.687GB)
Unable to read prop.plist , code : 2
Detected USERDATA USERDATA : 0x01BB800000 (22.132GB)
Unable to mount USERDATA , code : 95
Done.
Selected eMMC Interface
CMD Pullup Level:2021 mV
CLK Rate:7000 kHz
Bus Width:1bit,SDR
EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes
GPT: present
Detected LINUX(Android) CACHE : 0x01A0800000 (432.0MB)
Erasing...
Done.
Detected LINUX(Android) USERDATA : 0x01BB800000 (22.132GB)
Erasing...
Done.
Done.
Old 08-19-2019, 02:08   #88 (permalink)
Member: 1813906
Sonork: 100.1618216
Thanks Meter: 33
Oppo A3s CPH1853 remove lock screen and frp just one click Oppo reset
Selected pinout: GEN2 ISP Pinout
Z3X EasyJtag Software ver. 3.6.1.14
Loading eMMC GEN2 Firmware... IO: 2800 mV
Box S/N: F0491474C976AB1B, ,FW Ver.: 02.48
CMD Pullup Level:2075 mV
CMD Active Level:2716 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Checking security ...
CMD Pullup Level:2073 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
eMMC CID : 150100514536334D4204E51AAAA826AD
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Date: 02/2019 Rev.0x4
eMMC NAME: QE63MB , S/N: 3843730088
EMMC RPMB is programmed and written 13074 times
Backup saved: QE63MB_3843730088_20190818_1743.extcsd
Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB)
Build ID: OPM1.171019.026
Release Base ID: 8.1.0
Architecture ABI: arm64-v8a
Device manufacturer: OPPO
Build Description: S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20190624.211613 release-keys
Detected USERDATA USERDATA : 0x015B800000 (9.129GB)
Done.
CMD Active Level:2714 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
Writing Recovery Command to MISC (33)
Done.
Old 08-21-2019, 06:38   #89 (permalink)
Registered User
Member: 1784151
Sonork: 0
Thanks Meter: 75
I have Easy-JTAG and not used anymore bcoz i dont know this update. Wow, amazing,, just use Z3X Box... will use both product again together.
Thanks to Easy-JTAG team for this awesome news
Old 08-21-2019, 06:52   #90 (permalink)
Registered User
Member: 1784151
Sonork: 0
Thanks Meter: 75
I love Easy JTAG, this need activation? I have Easy JTAG Box and Z3X Box
Page generated in 0.31470 seconds with 10 queries
