09-11-2019, 12:05 | #106 (permalink) |
Freak Poster Join Date: Sep 2012 Location: KSA
Member: 1813906 Status: Offline Sonork: 100.1618216 Thanks Meter: 33 | EasyJtag Suite Classic ver.: 3.6.1.14 / wxWidgets 3.1.2-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights OK Android Explorer ver:1.0.0.13 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.0.6 QUALCOMM Direct ver:1.0.6671.7138 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 3.0.0.0 Z3X Card Serial : AAxxxxxx , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 2 serial devices COM27 USB\VID_05C6&PID_9008&REV_0000 Qualcomm HS-USB QDLoader 9008 (COM27) COM13 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM13) Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.1.14 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: F049147xxxxxxxx, ,FW Ver.: 02.48 CMD Pullup Level:2086 mV CMD Active Level:2742 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A68423861503E030DA78063A531 eMMC CSD : D02700328F5903FFFFFFFFEF8E400043 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 10/2018 Rev.0x3 eMMC NAME: hB8aP> , S/N: 229081187 eMMC NAME (HEX): 68423861503E EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 50663 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: hB8aP>_ 229081187_20190911_1541.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Detected 65 partitions ------ P0 (OPPODYCNVBK) [0x5000 0xa00000] Size: 10.0MB P1 (OPPOSTANVBK) [0xa05000 0xa00000] Size: 10.0MB P2 (MODEMST1) [0x1405000 0x180000] Size: 1.500MB P3 (MODEMST2) [0x1585000 0x180000] Size: 1.500MB P4 (PERSIST) [0x1705000 0x2000000] Size: 32.0MB P5 (OPPORESERVE1) [0x3705000 0x800000] Size: 8.0MB P6 (OPPORESERVE2) [0x3f05000 0x4000000] Size: 64.0MB P7 (RESERVE_EXP1) [0x7f05000 0x200000] Size: 2.0MB P8 (RESERVE_EXP2) [0x8105000 0x200000] Size: 2.0MB P9 (FSC) [0x8305000 0x400] Size: 1.0KB P10 (SSD) [0x8306000 0x2000] Size: 8.0KB P11 (SBL1) [0x8308000 0x80000] Size: 512.0KB P12 (RPM) [0x8388000 0x80000] Size: 512.0KB P13 (TZ) [0x8408000 0x200000] Size: 2.0MB P14 (DEVCFG) [0x8608000 0x40000] Size: 256.0KB P15 (SBL1BAK) [0x8648000 0x80000] Size: 512.0KB P16 (RPMBAK) [0x86c8000 0x80000] Size: 512.0KB P17 (TZBAK) [0x8748000 0x200000] Size: 2.0MB P18 (DEVCFGBAK) [0x8948000 0x40000] Size: 256.0KB P19 (DSP) [0x8988000 0x1000000] Size: 16.0MB P20 (DDR) [0xa000000 0x8000] Size: 32.0KB P21 (FSG) [0xa008000 0x180000] Size: 1.500MB P22 (SEC) [0xa188000 0x4000] Size: 16.0KB P23 (ABOOT) [0xa18c000 0x100000] Size: 1.0MB P24 (ABOOTBAK) [0xa28c000 0x100000] Size: 1.0MB P25 (MODEM) [0xa38c000 0x8000000] Size: 128.0MB P26 (DTBO) [0x1238c000 0x800000] Size: 8.0MB P27 (VBMETA) [0x12b8c000 0x10000] Size: 64.0KB P28 (BOOT) [0x12b9c000 0x4000000] Size: 64.0MB P29 (RECOVERY) [0x16b9c000 0x4000000] Size: 64.0MB P30 (DEVINFO) [0x1ab9c000 0x100000] Size: 1.0MB P31 (SPLASH) [0x1b000000 0xb00000] Size: 11.0MB P32 (LOGO) [0x1bb00000 0x2000000] Size: 32.0MB P33 (DRIVER) [0x1db00000 0x2000000] Size: 32.0MB P34 (CACHE) [0x1fb00000 0x10000000] Size: 256.0MB P35 (MISC) [0x2fb00000 0x100000] Size: 1.0MB P36 (KEYSTORE) [0x2fc00000 0x80000] Size: 512.0KB P37 (CONFIG) [0x2fc80000 0x8000] Size: 32.0KB P38 (OEM) [0x2fc88000 0x100000] Size: 1.0MB P39 (LIMITS) [0x30000000 0x8000] Size: 32.0KB P40 (MOTA) [0x30800000 0x80000] Size: 512.0KB P41 (DIP) [0x30880000 0x100000] Size: 1.0MB P42 (MDTP) [0x30980000 0x2000000] Size: 32.0MB P43 (SYSCFG) [0x32980000 0x80000] Size: 512.0KB P44 (MCFG) [0x32a00000 0x400000] Size: 4.0MB P45 (LKSECAPP) [0x33000000 0x20000] Size: 128.0KB P46 (CMNLIB) [0x33020000 0x100000] Size: 1.0MB P47 (CMNLIB64) [0x33120000 0x100000] Size: 1.0MB P48 (KEYMASTER) [0x33220000 0x100000] Size: 1.0MB P49 (LKSECAPPBAK) [0x33320000 0x20000] Size: 128.0KB P50 (CMNLIBBAK) [0x33340000 0x100000] Size: 1.0MB P51 (CMNLIB64BAK) [0x33440000 0x100000] Size: 1.0MB P52 (KEYMASTERBAK) [0x33540000 0x100000] Size: 1.0MB P53 (APDP) [0x33800000 0x40000] Size: 256.0KB P54 (MSADP) [0x33840000 0x40000] Size: 256.0KB P55 (DPO) [0x33880000 0x2000] Size: 8.0KB P56 (LOGDUMP) [0x33882000 0x4000000] Size: 64.0MB P57 (VM-KYSTORE) [0x37882000 0x100000] Size: 1.0MB P58 (VM-DATA) [0x37982000 0xa00000] Size: 10.0MB P59 (HYP) [0x38800000 0x800000] Size: 8.0MB P60 (VM-SYSTEM) [0x39000000 0x4000000] Size: 64.0MB P61 (VM-LINUX) [0x3d000000 0x2000000] Size: 32.0MB P62 (SYSTEM) [0x3f000000 0xd6900000] Size: 3.352GB P63 (VENDOR) [0x115900000 0x41f60000] Size: 1.30GB P64 (USERDATA) [0x158000000 0x5efbfbe00] Size: 23.745GB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB) Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20190717.054518 release-keys --------------------------------------------- Detected USERDATA USERDATA : 0x0158000000 (23.745GB) Unable to mount USERDATA , code : 95 Done. Selected eMMC Interface Checking security ... Z3X EasyJtag Software ver. 3.6.1.14 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: F0491474C976AB1B, ,FW Ver.: 02.48 CMD Pullup Level:2083 mV CMD Active Level:2740 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A68423861503E030DA78063A531 eMMC CSD : D02700328F5903FFFFFFFFEF8E400043 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 10/2018 Rev.0x3 eMMC NAME: hB8aP> , S/N: 229081187 eMMC NAME (HEX): 68423861503E EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 50663 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (35) Done. |
09-17-2019, 03:52 | #109 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | watch our youtube channel based on mobile software and emmc- https://www.youtube.com/watch?v=mxBa...v0KrNxD8a6mh9Q |
09-20-2019, 18:07 | #112 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Realme C2 RMX1945 PIN Lock & FRP Reset Done !! Easy-Jtag Realme C2 RMX1945 PIN Lock & FRP Reset Done !! Easy-Jtag Wbr, AniAXN |
The Following 3 Users Say Thank You to AniAxn For This Useful Post: |
09-21-2019, 13:45 | #113 (permalink) |
Freak Poster Join Date: Mar 2019 Location: Bahawal Nagar Age: 34
Member: 2902578 Status: Offline Thanks Meter: 151 | OPPO A1K (CPH1923) Pattern + FRP Remove With EasyJtag Plus Proper Way to Remove pattern & FRP Offline With Z3XJtag There is no risk of dead / Bricked If You ARE skilled enough |
The Following 4 Users Say Thank You to Gulzar-Ahmad For This Useful Post: |
09-23-2019, 19:12 | #116 (permalink) |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | OPPO A3S CPH1803 SKhynix 32GB eMMC Unlock Done !! Easy Jtag OPPO A3S CPH1803 SKhynix 32GB eMMC Unlock Done !! Easy Jtag Pattern Lock & FRP Reset Done without Data Loss Wbr, AniAXN |
The Following 5 Users Say Thank You to AniAxn For This Useful Post: |
