Old 09-11-2019, 12:05   #106 (permalink)
Member: 1813906
Sonork: 100.1618216
Thanks Meter: 33
Oppo A3s CPH1803 successfully pin removed
EasyJtag Suite Classic ver.: 3.6.1.14 / wxWidgets 3.1.2-W-U started.
OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights OK
Android Explorer ver:1.0.0.13
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
eMMC Odin ver:1.0.0.6
QUALCOMM Direct ver:1.0.6671.7138
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 3.0.0.0
Z3X Card Serial : AAxxxxxx , ver: 22
Z3X Card Activation [JTAGPLUS] : ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Found 2 serial devices
COM27 USB\VID_05C6&PID_9008&REV_0000 Qualcomm HS-USB QDLoader 9008 (COM27)
COM13 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM13)
Selected pinout: GEN2 ISP Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.6.1.14
Loading eMMC GEN2 Firmware... IO: 2800 mV
Box S/N: F049147xxxxxxxx, ,FW Ver.: 02.48
CMD Pullup Level:2086 mV
CMD Active Level:2742 mV
Box IO Level:2800 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 90014A68423861503E030DA78063A531
eMMC CSD : D02700328F5903FFFFFFFFEF8E400043
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 10/2018 Rev.0x3
eMMC NAME: hB8aP> , S/N: 229081187
eMMC NAME (HEX): 68423861503E
EMMC ROM1 (Main User Data) Capacity: 29820 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 50663 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: hB8aP>_ 229081187_20190911_1541.extcsd
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326
Partition info successfully found
------ Detected 65 partitions ------
P0 (OPPODYCNVBK) [0x5000 0xa00000] Size: 10.0MB
P1 (OPPOSTANVBK) [0xa05000 0xa00000] Size: 10.0MB
P2 (MODEMST1) [0x1405000 0x180000] Size: 1.500MB
P3 (MODEMST2) [0x1585000 0x180000] Size: 1.500MB
P4 (PERSIST) [0x1705000 0x2000000] Size: 32.0MB
P5 (OPPORESERVE1) [0x3705000 0x800000] Size: 8.0MB
P6 (OPPORESERVE2) [0x3f05000 0x4000000] Size: 64.0MB
P7 (RESERVE_EXP1) [0x7f05000 0x200000] Size: 2.0MB
P8 (RESERVE_EXP2) [0x8105000 0x200000] Size: 2.0MB
P9 (FSC) [0x8305000 0x400] Size: 1.0KB
P10 (SSD) [0x8306000 0x2000] Size: 8.0KB
P11 (SBL1) [0x8308000 0x80000] Size: 512.0KB
P12 (RPM) [0x8388000 0x80000] Size: 512.0KB
P13 (TZ) [0x8408000 0x200000] Size: 2.0MB
P14 (DEVCFG) [0x8608000 0x40000] Size: 256.0KB
P15 (SBL1BAK) [0x8648000 0x80000] Size: 512.0KB
P16 (RPMBAK) [0x86c8000 0x80000] Size: 512.0KB
P17 (TZBAK) [0x8748000 0x200000] Size: 2.0MB
P18 (DEVCFGBAK) [0x8948000 0x40000] Size: 256.0KB
P19 (DSP) [0x8988000 0x1000000] Size: 16.0MB
P20 (DDR) [0xa000000 0x8000] Size: 32.0KB
P21 (FSG) [0xa008000 0x180000] Size: 1.500MB
P22 (SEC) [0xa188000 0x4000] Size: 16.0KB
P23 (ABOOT) [0xa18c000 0x100000] Size: 1.0MB
P24 (ABOOTBAK) [0xa28c000 0x100000] Size: 1.0MB
P25 (MODEM) [0xa38c000 0x8000000] Size: 128.0MB
P26 (DTBO) [0x1238c000 0x800000] Size: 8.0MB
P27 (VBMETA) [0x12b8c000 0x10000] Size: 64.0KB
P28 (BOOT) [0x12b9c000 0x4000000] Size: 64.0MB
P29 (RECOVERY) [0x16b9c000 0x4000000] Size: 64.0MB
P30 (DEVINFO) [0x1ab9c000 0x100000] Size: 1.0MB
P31 (SPLASH) [0x1b000000 0xb00000] Size: 11.0MB
P32 (LOGO) [0x1bb00000 0x2000000] Size: 32.0MB
P33 (DRIVER) [0x1db00000 0x2000000] Size: 32.0MB
P34 (CACHE) [0x1fb00000 0x10000000] Size: 256.0MB
P35 (MISC) [0x2fb00000 0x100000] Size: 1.0MB
P36 (KEYSTORE) [0x2fc00000 0x80000] Size: 512.0KB
P37 (CONFIG) [0x2fc80000 0x8000] Size: 32.0KB
P38 (OEM) [0x2fc88000 0x100000] Size: 1.0MB
P39 (LIMITS) [0x30000000 0x8000] Size: 32.0KB
P40 (MOTA) [0x30800000 0x80000] Size: 512.0KB
P41 (DIP) [0x30880000 0x100000] Size: 1.0MB
P42 (MDTP) [0x30980000 0x2000000] Size: 32.0MB
P43 (SYSCFG) [0x32980000 0x80000] Size: 512.0KB
P44 (MCFG) [0x32a00000 0x400000] Size: 4.0MB
P45 (LKSECAPP) [0x33000000 0x20000] Size: 128.0KB
P46 (CMNLIB) [0x33020000 0x100000] Size: 1.0MB
P47 (CMNLIB64) [0x33120000 0x100000] Size: 1.0MB
P48 (KEYMASTER) [0x33220000 0x100000] Size: 1.0MB
P49 (LKSECAPPBAK) [0x33320000 0x20000] Size: 128.0KB
P50 (CMNLIBBAK) [0x33340000 0x100000] Size: 1.0MB
P51 (CMNLIB64BAK) [0x33440000 0x100000] Size: 1.0MB
P52 (KEYMASTERBAK) [0x33540000 0x100000] Size: 1.0MB
P53 (APDP) [0x33800000 0x40000] Size: 256.0KB
P54 (MSADP) [0x33840000 0x40000] Size: 256.0KB
P55 (DPO) [0x33880000 0x2000] Size: 8.0KB
P56 (LOGDUMP) [0x33882000 0x4000000] Size: 64.0MB
P57 (VM-KYSTORE) [0x37882000 0x100000] Size: 1.0MB
P58 (VM-DATA) [0x37982000 0xa00000] Size: 10.0MB
P59 (HYP) [0x38800000 0x800000] Size: 8.0MB
P60 (VM-SYSTEM) [0x39000000 0x4000000] Size: 64.0MB
P61 (VM-LINUX) [0x3d000000 0x2000000] Size: 32.0MB
P62 (SYSTEM) [0x3f000000 0xd6900000] Size: 3.352GB
P63 (VENDOR) [0x115900000 0x41f60000] Size: 1.30GB
P64 (USERDATA) [0x158000000 0x5efbfbe00] Size: 23.745GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB)
Build ID: OPM1.171019.026
Release Base ID: 8.1.0
Architecture ABI: arm64-v8a
Device manufacturer: OPPO
Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20190717.054518 release-keys
Detected USERDATA USERDATA : 0x0158000000 (23.745GB)
Unable to mount USERDATA , code : 95
Done.
Selected eMMC Interface
Checking security ...
Box S/N: F0491474C976AB1B, ,FW Ver.: 02.48
CMD Pullup Level:2083 mV
CMD Active Level:2740 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes
Writing Recovery Command to MISC (35)
Done.
Old 09-16-2019, 21:39   #107 (permalink)
Member: 2521152
Thanks Meter: 11
https://m.youtube.com/watch?feature=...&v=VTqAM1fRK5E
Sent from my ONEPLUS A5000 using Tapatalk
The Following User Says Thank You to ashekh04 For This Useful Post:
Old 09-16-2019, 23:58   #108 (permalink)
Member: 112185
Sonork: 100.1612613
Thanks Meter: 163
ISP pinout or EMMC??
vcc connected ??
Old 09-17-2019, 03:52   #109 (permalink)
Member: 2298369
Thanks Meter: 440
watch our youtube channel based on mobile software and emmc-
https://www.youtube.com/watch?v=mxBa...v0KrNxD8a6mh9Q
Old 09-17-2019, 06:24   #110 (permalink)
Member: 2521152
Thanks Meter: 11
vcc connected ??
Isp connected
VCC and vccq usb attached
Old 09-20-2019, 13:04   #111 (permalink)
Member: 2219233
Sonork: palani
Thanks Meter: 59
realme 1 cph 1861 need isp pinouts
realme 1 cph 1861 need isp pinouts // masters plz need help // if you have pls post me
Old 09-20-2019, 18:07   #112 (permalink)
AniAxn's Avatar
Member: 1045758
Sonork: 100.1613661(Offline)
Thanks Meter: 4,307
Arrow Realme C2 RMX1945 PIN Lock & FRP Reset Done !! Easy-Jtag
Wbr,
AniAXN
The Following 3 Users Say Thank You to AniAxn For This Useful Post:
Old 09-21-2019, 13:45   #113 (permalink)
Member: 2902578
Thanks Meter: 151
Thumbs up OPPO A1K (CPH1923) Pattern + FRP Remove With EasyJtag Plus
Proper Way to Remove pattern & FRP Offline With Z3XJtag
There is no risk of dead / Bricked If You ARE skilled enough
http://www.youtube.com/watch?v=XHk-1D5mGwI
The Following 4 Users Say Thank You to Gulzar-Ahmad For This Useful Post:
Old 09-21-2019, 23:04   #114 (permalink)
Member: 39679
Thanks Meter: 41
Oppo F11 Pro Done
Oppo F11 Pro done with easy jtag
Wipe user data and FRP
see log
Old 09-23-2019, 10:40   #115 (permalink)
Crazy Poster
Member: 2203177
Thanks Meter: 9
oppo f11 pro pinlock ok
Old 09-23-2019, 19:12   #116 (permalink)
AniAxn's Avatar
Member: 1045758
Thanks Meter: 4,307
Arrow OPPO A3S CPH1803 SKhynix 32GB eMMC Unlock Done !! Easy Jtag
Pattern Lock & FRP Reset Done without Data Loss
Wbr,
AniAXN
The Following 5 Users Say Thank You to AniAxn For This Useful Post:
Old 09-24-2019, 07:09   #117 (permalink)
jamohaki's Avatar
Member: 83397
Thanks Meter: 204
which button did use "reset oppo or clear pin" ?
Old 09-24-2019, 10:11   #118 (permalink)
Member: 667941
Sonork: 100.1611812
Thanks Meter: 61
for oppo reset oppo
for mtk ..wipe user data
The Following User Says Thank You to anjuman For This Useful Post:
Old 09-25-2019, 13:16   #119 (permalink)
ufst boy's Avatar
Member: 2927649
Thanks Meter: 568
googd report brother
Old 09-25-2019, 13:42   #120 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
after wipe data i get only mediatek usb port on pc ,phone doenst power on
how to solve it
thank you
Page generated in 0.26728 seconds with 10 queries
