11-28-2019, 01:28 | #151 (permalink) | |
No Life Poster Join Date: Oct 2010 Location: Abidjan Age: 38
Member: 1418143 Status: Offline Thanks Meter: 353 | Quote:
I have one bricked with GPT issu maybe writing good backup might help | |
12-18-2019, 12:57 | #154 (permalink) |
Freak Poster Join Date: Oct 2010
Member: 1429499 Status: Offline Thanks Meter: 28 | OPPO A5S PASSWORD RESET DONE Detected LINUX(Android) SYSTEM : 0x008D800000 (4.203GB) Short EXT fs info: Size: 4.203GB Block size: 4.0KB Inode size: 256 Inodes: 275808 Short Android info: Build ID: O11019 Release Base ID: 8.1.0 Security Path: 2019-09-05 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: full_oppo6765_18511-user 8.1.0 O11019 1568646877 release-keys Backup saved: BuildProp_20191218_1627.txt --------------------------------------------- Detected USERDATA USERDATA : 0x01AA800000 (22.398GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 763AE212 01EE0DEB 05FC1C6D 709136EC B80C9593 EA66FA3F 6E7A2561 9B5F2498 v:â..î.ë.ü.mp‘6ì¸.•“êfú?nz%a›_$.; 86E17556 77664E9E 29CBD4D3 D711C8D2 1D8CAD40 24608A8C D8C0E0DD 5E27415B †áuVwfNž)ËÔÓ×.ÈÒ.Œ*@$`ŠŒØÀàÝ^'A[; 7B5E21B8 EA0670F5 11CFC3CF C339D220 17AA770A D739EFB6 F8614258 997E696A {^!¸ê.põ.ÏÃÏÃ9Ò .ªw.×9ï¶øaBX.~ij; C9D386B0 1208F485 173CB383 A3C4299A 290610F9 A56FA6A8 08BC3225 FD22F6DD ÉÓ†°..ô….<³ƒ£Ä)š)..ù¥o¦¨.¼2%ý"öÝ; 02FB9D12 2856E028 1BF2EF9B 3E59D0E6 4F15D525 1D3C473C 7969937E 8BB860E1 .û..(Và(.òï›>YÐæO.Õ%.<G<yi“~‹¸`á; 6FC6C87E 68A250E4 25875FC4 13911E8C 08D1AE3D 79696644 74E66329 950F56AD oÆÈ~h¢Pä%‡_Ä.‘.Œ.Ñ®=yifDtæc)•.V*; B5CC79FF 99286D82 2D1044C3 34CBB814 E93B5694 D18AD004 A55068DE 2EF6419A µÌyÿ.(m‚-.DÃ4˸.é;V”ÑŠÐ.¥PhÞ.öAš; D2D7C098 C31226F0 22C0BDFB FE87921C BDCE8019 9407FFB5 08A54BF8 2D1B5FBC Ò×À.Ã.&ð"À½ûþ‡’.½Î..”.ÿµ.¥Kø-._¼; Done. Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0500B0041FDAE20A, ,FW Ver.: 01.63 CMD Pullup Level:2062 mV CMD Active Level:2619 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514436334D42030699D3BF660C eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 06/2019 Rev.0x3 eMMC NAME: QD63MB , S/N: 110744511 eMMC NAME (HEX): 514436334D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 59 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected (Android Userdata) USERDATA : 0x01AA800000 (22.398GB) Read EXT fs info Formatting EXT fs... (may take a while...) mmc_write_blocks(0x1AA946000 , 1000 ), Failed: CARD Ready Timeout Error mmc_write_blocks(0x1AA800400 , 400 ), Failed: CMD Timeout Error mmc_write_blocks(0x1AA94C000 , 1000 ), Failed: CMD Timeout Error Returned 5... Read EXT fs info NEW Created filesystem with parameters: Size: 24051167232 Block size: 21474840576 Blocks per group: 32768 Inodes per group: 8160 Inode size: 256 Inodes: 1468800 Label: Trying to mount FS... Shutting down EXT4... Done. Detected (Android Cache)) CACHE : 0x019A800000 (256.0MB) Read EXT fs info Read EXT fs info Created filesystem with parameters: Size: 268435456 Block size: 4096 Blocks per group: 32768 Inodes per group: 8192 Inode size: 256 Inodes: 16384 Label: Formatting EXT fs... (may take a while...) Returned 28... Read EXT fs info NEW Created filesystem with parameters: Size: 268435456 Block size: 4096 Blocks per group: 32768 Inodes per group: 8192 Inode size: 256 Inodes: 16384 Label: Trying to mount FS... Shutting down EXT4... Done. --------------------------------------------- Done. Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0500B0041FDAE20A, ,FW Ver.: 01.63 CMD Pullup Level:2052 mV CMD Active Level:2516 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514436334D42030699D3BF660C eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 06/2019 Rev.0x3 eMMC NAME: QD63MB , S/N: 110744511 eMMC NAME (HEX): 514436334D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 59 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QD63MB_ 110744511_20191218_1648.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x008D800000 (4.203GB) Short EXT fs info: Size: 4.203GB Block size: 4.0KB Inode size: 256 Inodes: 275808 Short Android info: Build ID: O11019 Release Base ID: 8.1.0 Security Path: 2019-09-05 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: full_oppo6765_18511-user 8.1.0 O11019 1568646877 release-keys Backup saved: BuildProp_20191218_1648.txt --------------------------------------------- Detected USERDATA USERDATA : 0x01AA800000 (22.398GB) Short EXT fs info: Size: 22.398GB Block size: 4.0KB Inode size: 256 Inodes: 1468800 Short userdata info: mmc_write_blocks(0x1AA91F000 , 1000 ), Failed: DATA SND CRC Error mmc_write_blocks(0x1AA925000 , 1000 ), Failed: CMD Timeout Error Unable to read gesture.key , code 5 mmc_write_blocks(0x1AA91F000 , 1000 ), Failed: CMD Timeout Error mmc_write_blocks(0x1AA920000 , 1000 ), Failed: CMD Timeout Error mmc_write_blocks(0x1AA921000 , 1000 ), Failed: CMD Timeout Error mmc_write_blocks(0x1AA922000 , 1000 ), Failed: CMD Timeout Error mmc_write_blocks(0x1AA923000 , 1000 ), Failed: CMD Timeout Error mmc_write_blocks(0x1AA924000 , 1000 ), Failed: CMD Timeout Error mmc_write_blocks(0x1AA925000 , 1000 ), Failed: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0500B0041FDAE20A, ,FW Ver.: 01.63 CMD Pullup Level:2052 mV CMD Active Level:2382 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514436334D42030699D3BF660C eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 06/2019 Rev.0x3 eMMC NAME: QD63MB , S/N: 110744511 eMMC NAME (HEX): 514436334D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 59 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QD63MB_ 110744511_20191218_1648.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x008D800000 (4.203GB) Short EXT fs info: Size: 4.203GB Block size: 4.0KB Inode size: 256 Inodes: 275808 Short Android info: Build ID: O11019 Release Base ID: 8.1.0 Security Path: 2019-09-05 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: full_oppo6765_18511-user 8.1.0 O11019 1568646877 release-keys Backup saved: BuildProp_20191218_1648.txt --------------------------------------------- Detected USERDATA USERDATA : 0x01AA800000 (22.398GB) Short EXT fs info: Size: 22.398GB Block size: 4.0KB Inode size: 256 Inodes: 1468800 Short userdata info: Unable to read gesture.key , code 2 Done. Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0500B0041FDAE20A, ,FW Ver.: 01.63 CMD Pullup Level:2052 mV CMD Active Level:2670 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514436334D42030699D3BF660C eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 06/2019 Rev.0x3 eMMC NAME: QD63MB , S/N: 110744511 eMMC NAME (HEX): 514436334D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 59 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected (Android Userdata) USERDATA : 0x01AA800000 (22.398GB) Erasing... Done. Detected (Android Cache)) CACHE : 0x019A800000 (256.0MB) Erasing... Done. --------------------------------------------- Done. |
The Following User Says Thank You to Reason gurung For This Useful Post: |
12-24-2019, 12:44 | #155 (permalink) |
Freak Poster Join Date: Jan 2008 Location: phone care
Member: 667941 Status: Offline Sonork: 100.1611812 Thanks Meter: 61 | realme 3 rmx1827 dead after frp fix. realme 3 rmx1827 dead recover after frp... Setting interface to EasyJtag2/E-Socket Setting bus width to 4 Bit Setting frequence to 14 MHz EMMC Device Information : EMMC CID: 150100474436424D42013D0A6A3A5667 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: GD6BMB , HEX: 474436424D42 , S/N: 3D0A6A3A , rev. 0x01 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2019 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 403 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: GD6BMB_3D0A6A3A_20191224_161240.extcsd EMMC Init completed. Operation: Writing all eMMC Regions... Operation: Writing BootConfig ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x02 Reg: 162 Value: 0x01 Done Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000 Filename: boot1.bin eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 1448.31 KB/s Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000 Filename: boot2.bin eMMC switching to ROM3 Writing partition... Done writing partition. Write speed: 1411.93 KB/s Writing to: ROM1 , start: 0x000000000000 , size: 0x000000100000 Filename: userarea_1MiB.bin eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 5052.82 KB/s All done time: [00:00:07:883] |
The Following User Says Thank You to anjuman For This Useful Post: |
01-05-2020, 15:42 | #157 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Realme C2 RMX1941 Pinlock & FRP Reset Done !! Easy JTAG Plus Realme C2 RMX1941 Pinlock & FRP Reset Done !! Easy JTAG Plus Wbr, AniAXN |
The Following 2 Users Say Thank You to AniAxn For This Useful Post: |
01-08-2020, 13:09 | #159 (permalink) |
Member: 1429499 Status: Offline Thanks Meter: 28 | !OPPO A1K PASSWORD REMOVE DONE ---------- eMMC Device Information ---------- eMMC CID : 150100514436334D42034AC2D80E162A eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 01/2019 Rev.0x3 eMMC NAME: QD63MB , S/N: 1254283278 eMMC NAME (HEX): 514436334D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 788 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QD63MB_1254283278_20200108_1630.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0074800000 (4.687GB) Short EXT fs info: Size: 4.613GB Block size: 4.0KB Inode size: 256 Inodes: 302512 Short Android info: Unable to read prop.plist , code : 2 Backup saved: BuildProp_20200108_1630.txt --------------------------------------------- Detected USERDATA USERDATA : 0x01BB800000 (22.132GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0500B0041FDAE20A, ,FW Ver.: 01.63 CMD Pullup Level:2052 mV CMD Active Level:2629 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514436334D42034AC2D80E162A eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 01/2019 Rev.0x3 eMMC NAME: QD63MB , S/N: 1254283278 eMMC NAME (HEX): 514436334D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 788 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected (Android Userdata) USERDATA : 0x01BB800000 (22.132GB) Erasing... Done. Detected (Android Cache)) CACHE : 0x01A0800000 (432.0MB) Erasing... Done. --------------------------------------------- Done. |
01-10-2020, 15:49 | #160 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | OPPO A3S Password Reset Done One Click With Easy Jtag Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN2 Firmware... IO: 3300 mV Box S/N: 99A6985582C3A1F2, ,FW Ver.: 02.50 CMD Pullup Level:2142 mV CMD Active Level:3054 mV Box IO Level:3300 mV CLK Rate:12000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A484147346132A5C769650785C1 eMMC CSD : D02701328F5903FFFFFFFFE78A400017 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 08/2018 Rev.0xA5 eMMC NAME: HAG4a2 , S/N: 3345573127 eMMC NAME (HEX): 484147346132 EMMC ROM1 (Main User Data) Capacity: 15028 MB , 0x1D5A000 pages , 0x3AB400000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB RPMB Info mmc_init Error, Reason: CARD Status Error EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (35) Done. |
01-11-2020, 22:24 | #161 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 10 (64 bit) build 17763 (10.0.17763.771) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = 417A1E88471829FA Card Serial = AAF96E71 EasyJTAG Box Firmware = 2.44 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 1 MHz CMD Pullup Level: 234 mV CMD Active Level: 1811 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 1 MHz CMD Pullup Level: 384 mV CMD Active Level: 2673 mV EMMC Device Information : EMMC CID: 150100475036424D420178566821C599 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: GP6BMB , HEX: 475036424D42 , S/N: 78566821 , rev. 0x01 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2018 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 5123 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: GP6BMB_78566821_20200112_002127.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: oppodycnvbk, [000000005000 - 000000A05000], size: 000000A00000 (10.0 MB) Partition: oppostanvbk, [000000A05000 - 000001405000], size: 000000A00000 (10.0 MB) Partition: modemst1, [000001405000 - 000001585000], size: 000000180000 (1.50 MB) Partition: modemst2, [000001585000 - 000001705000], size: 000000180000 (1.50 MB) Partition: persist, [000001705000 - 000003705000], size: 000002000000 (32.0 MB) Partition: opporeserve1, [000003705000 - 000003F05000], size: 000000800000 (8.00 MB) Partition: opporeserve2, [000003F05000 - 000007F05000], size: 000004000000 (64.0 MB) Partition: fsc, [000007F05000 - 000007F05400], size: 000000000400 (1.00 KB) Partition: ssd, [000007F06000 - 000007F08000], size: 000000002000 (8.00 KB) Partition: sbl1, [000007F08000 - 000007F88000], size: 000000080000 (512. KB) Partition: rpm, [000007F88000 - 000008008000], size: 000000080000 (512. KB) Partition: tz, [000008008000 - 000008208000], size: 000000200000 (2.00 MB) Partition: devcfg, [000008208000 - 000008248000], size: 000000040000 (256. KB) Partition: sbl1bak, [000008248000 - 0000082C8000], size: 000000080000 (512. KB) Partition: rpmbak, [0000082C8000 - 000008348000], size: 000000080000 (512. KB) Partition: tzbak, [000008348000 - 000008548000], size: 000000200000 (2.00 MB) Partition: devcfgbak, [000008548000 - 000008588000], size: 000000040000 (256. KB) Partition: dsp, [000008588000 - 000009588000], size: 000001000000 (16.0 MB) Partition: DDR, [000009800000 - 000009808000], size: 000000008000 (32.0 KB) Partition: fsg, [000009808000 - 000009988000], size: 000000180000 (1.50 MB) Partition: sec, [000009988000 - 00000998C000], size: 000000004000 (16.0 KB) Partition: aboot, [00000998C000 - 000009A8C000], size: 000000100000 (1.00 MB) Partition: abootbak, [000009A8C000 - 000009B8C000], size: 000000100000 (1.00 MB) Partition: modem, [000009B8C000 - 000011B8C000], size: 000008000000 (128. MB) Partition: dtbo, [000011B8C000 - 00001238C000], size: 000000800000 (8.00 MB) Partition: vbmeta, [00001238C000 - 00001239C000], size: 000000010000 (64.0 KB) Partition: boot, [00001239C000 - 00001639C000], size: 000004000000 (64.0 MB) Partition: recovery, [00001639C000 - 00001A39C000], size: 000004000000 (64.0 MB) Partition: devinfo, [00001A39C000 - 00001A49C000], size: 000000100000 (1.00 MB) Partition: splash, [00001A800000 - 00001B300000], size: 000000B00000 (11.0 MB) Partition: LOGO, [00001B300000 - 00001D300000], size: 000002000000 (32.0 MB) Partition: DRIVER, [00001D300000 - 00001F300000], size: 000002000000 (32.0 MB) Partition: cache, [00001F300000 - 00002F300000], size: 000010000000 (256. MB) Partition: misc, [00002F300000 - 00002F400000], size: 000000100000 (1.00 MB) Partition: keystore, [00002F400000 - 00002F480000], size: 000000080000 (512. KB) Partition: config, [00002F480000 - 00002F488000], size: 000000008000 (32.0 KB) Partition: oem, [00002F488000 - 00002F588000], size: 000000100000 (1.00 MB) Partition: limits, [00002F800000 - 00002F808000], size: 000000008000 (32.0 KB) Partition: mota, [000030000000 - 000030080000], size: 000000080000 (512. KB) Partition: dip, [000030080000 - 000030180000], size: 000000100000 (1.00 MB) Partition: mdtp, [000030180000 - 000032180000], size: 000002000000 (32.0 MB) Partition: syscfg, [000032180000 - 000032200000], size: 000000080000 (512. KB) Partition: mcfg, [000032200000 - 000032600000], size: 000000400000 (4.00 MB) Partition: lksecapp, [000032800000 - 000032820000], size: 000000020000 (128. KB) Partition: cmnlib, [000032820000 - 000032920000], size: 000000100000 (1.00 MB) Partition: cmnlib64, [000032920000 - 000032A20000], size: 000000100000 (1.00 MB) Partition: keymaster, [000032A20000 - 000032B20000], size: 000000100000 (1.00 MB) Partition: lksecappbak, [000032B20000 - 000032B40000], size: 000000020000 (128. KB) Partition: cmnlibbak, [000032B40000 - 000032C40000], size: 000000100000 (1.00 MB) Partition: cmnlib64bak, [000032C40000 - 000032D40000], size: 000000100000 (1.00 MB) Partition: keymasterbak, [000032D40000 - 000032E40000], size: 000000100000 (1.00 MB) Partition: apdp, [000033000000 - 000033040000], size: 000000040000 (256. KB) Partition: msadp, [000033040000 - 000033080000], size: 000000040000 (256. KB) Partition: dpo, [000033080000 - 000033082000], size: 000000002000 (8.00 KB) Partition: logdump, [000033082000 - 000037082000], size: 000004000000 (64.0 MB) Partition: vm-kystore, [000037082000 - 000037182000], size: 000000100000 (1.00 MB) Partition: vm-data, [000037182000 - 000037B82000], size: 000000A00000 (10.0 MB) Partition: hyp, [000038000000 - 000038800000], size: 000000800000 (8.00 MB) Partition: vm-system, [000038800000 - 00003C800000], size: 000004000000 (64.0 MB) Partition: vm-linux, [00003C800000 - 00003E800000], size: 000002000000 (32.0 MB) Partition: system, [00003E800000 - 00013C800000], size: 0000FE000000 (3.97 GB) Partition: vendor, [00013C800000 - 00017E760000], size: 000041F60000 (1.03 GB) Partition: userdata, [00017E800000 - 000E8F7FBE00], size: 000D10FFBE00 (52.2 GB) GPT header successfully parsed Get firmware version Manufacturer = OPPO CPU Abi = arm64-v8a Android release = 8.1.0 Brand = OPPO Device = CPH1903 Model = CPH1903 Firmware version = CPH1903EX_11_A.15 Firmware date = Sat Nov 16 14:41:09 CST 2019 Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 1 MHz CMD Pullup Level: 383 mV CMD Active Level: 3121 mV EMMC Device Information : EMMC CID: 150100475036424D420178566821C599 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: GP6BMB , HEX: 475036424D42 , S/N: 78566821 , rev. 0x01 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2018 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 5123 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: GP6BMB_78566821_20200112_002245.extcsd EMMC Init completed. Operation: MoviNand Format + Reset ... EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB Sending Internal Reconfiguration Request... Waiting configuration Apply! Restoring configuration... EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB Wiping Card... Please do not touch it! Successfully Please don't forget to repair extCSD from backup! |
01-12-2020, 21:18 | #163 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | cph1901 a7 === Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 1201401CBB19DC97, ,FW Ver.: 01.63 CMD Pullup Level:2072 mV CMD Active Level:3062 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100475036424D4201C8819BDF26DC eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 02/2019 Rev.0x1 eMMC NAME: GP6BMB , S/N: 3363937247 eMMC NAME (HEX): 475036424D42 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 3730 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (33) Done. |
The Following User Says Thank You to chand_gee For This Useful Post: |
01-19-2020, 06:16 | #164 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Realme C2 Dead During Remove UserLock Cmd Line Missing Remove Cpu+Emmc Make Micro Jumper Remove Lock All Job Successfully Done With Easy-Jtag Image- Remove User Lock Successfully Alive Handset |
The Following 8 Users Say Thank You to Deepesh Sharma For This Useful Post: |
