Old 01-20-2020, 06:38   #166 (permalink)
Member: 667941
Sonork: 100.1611812
Thanks Meter: 61
Originally Posted by Deepesh Sharma View Post
Realme C2 Dead During Remove UserLock Cmd Line Missing
Remove Cpu+Emmc Make Micro Jumper Remove Lock
All Job Successfully Done With Easy-Jtag
Image-
Remove User Lock
Successfully Alive Handset
really hard work...but i know after we done this type job...we fully satisfy with our work..
brother what is system path???
The Following 2 Users Say Thank You to anjuman For This Useful Post:
Old 01-21-2020, 13:26   #167 (permalink)
Member: 575256
Thanks Meter: 34
how do it
Originally Posted by royalnasim View Post
OPPO REALME 2 PATTERN AND FRP UNLOCK DONE WITH EASY JTAG PLUS
Howww step by step to do itt brooo
Old 02-16-2020, 18:09   #168 (permalink)
khalidahmed's Avatar
Member: 2298142
Thanks Meter: 240
CPH1911 OPPOF11
The Following 2 Users Say Thank You to khalidahmed For This Useful Post:
Old 02-25-2020, 19:07   #169 (permalink)
mobile_media's Avatar
Member: 1708706
Sonork: 100.1605514
Thanks Meter: 36
oppo a3s pin unlock done by EasyJTAG ....
Z3X EasyJtag Software ver. 3.6.2.1
Loading eMMC GEN1 Firmware... IO: 3300 mV
Box S/N: 1901700C4536D1DB, ,FW Ver.: 01.63
CMD Pullup Level:2000 mV
CMD Active Level:2949 mV
Box IO Level:3300 mV
CLK Rate:7000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 150100514536334D4206C7939BF3B5F0
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 11/2018 Rev.0x6
eMMC NAME: QE63MB , S/N: 3348339699
eMMC NAME (HEX): 514536334D42
IC Name: Samsung , KMQE60013M-B318/16GB @BGA221
EMMC ROM1 (Main User Data) Capacity: 14910 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 29238 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QE63MB_3348339699_20200225_2358.extcsd
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB
Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646
Partition info successfully found
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 216432
Short Android info:
Backup saved: BuildProp_20200225_2358.txt
Build ID: OPM1.171019.026
Release Base ID: 8.1.0
Security Path: 2019-12-05
Architecture ABI: arm64-v8a
Device manufacturer: OPPO
Build Description: S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20191205.151001 release-keys
Detected USERDATA USERDATA : 0x015B800000 (9.129GB)
Unable to mount USERDATA , code : 95
Userdata Superblock contents::
811793B6 2DBB662E 5486697F 13D3BA1C B1819378 FBD74967 68BEAB16 8E968018 ..“¶-»f.T†i..Óº.±.“xû×Igh¾«.Ž–..;
96F3F7CA 6875D287 1812559A F54802EE 14BE02D4 A7C69AA0 474E4F02 9C15B493 –ó÷ÊhuÒ‡..UšõH.î.¾.ԧƚ GNO.œ.´“;
D0632551 72854E10 CBE6913A 39BC827B C8446767 B8EBFE5F E729D00F 793E4CC6 Ðc%Qr…N.Ëæ‘:9¼‚{ÈDgg¸ëþ_ç)Ð.y>LÆ;
1275016F AB040D95 B3344616 3EA5EFF6 6647854B 71D86C7A CEE0AA53 A3743806 .u.o«..•³4F.>¥ïöfG…KqØlzÎàªS£t8.;
56AC0125 B970B9EC 5F6CCC6B B0DFE538 0DE2E222 BE17BB5D 5352A43C CBEA2D51 V¬.%¹p¹ì_lÌk°ßå8.ââ"¾.»]SR¤<Ëê-Q;
5489499F 894A848A 3585F500 A07E1887 E4989154 F6E5BE22 5156CD47 DA42B44C T‰IŸ‰J„Š5…õ. ~.‡ä.‘Töå¾"QVÍGÚB´L;
2EEB6927 2C99FFDD 57E3AD24 75337B60 4019FD10 B9FABF3F DE22091A 1BE4C1EB .ëi',.ÿÝWã*$u3{`@.ý.¹ú¿?Þ" ..äÁë;
EE15ABDA 6A12E0AB 88213552 DB56B08A 223546C8 F507F435 60B3A87B 6691F1DD î.«Új.à«.!5RÛV°Š"5FÈõ.ô5`³¨{f‘ñÝ;
Done.
Running:Format FRP Partition...
CMD Active Level:3042 mV
CLK Rate:7000 kHz
Bus Width:1bit,SDR
EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes
Formatting FRP...
Detected LINUX(Android) CACHE : 0x001F300000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) CONFIG : 0x002F480000 (32.0KB) formatting...
Done.
Detected LINUX(Android) USERDATA : 0x015B800000 (9.129GB) , formatting...
Done.
Done.
Done.
CMD Pullup Level:2010 mV
CMD Active Level:3031 mV
CLK Rate:7000 kHz
Bus Width:1bit,SDR
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 216432
Short Android info:
00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................;
Done.
Running:Reset PIN/PASS/GESTURE Locks
CMD Active Level:3021 mV
CLK Rate:7000 kHz
Bus Width:1bit,SDR
Mount EXT4 fs...
Unable to mount USER , code : 95
Done.
Old 03-01-2020, 17:07   #170 (permalink)
.::THE ROCK::.'s Avatar
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Oppo a5 cph1809 pattern unlock (safe media file) easy jtag
OPPO A5 CPH1809
PATTERN UNLOCK
(SAFE MEDIA FILE) EASY JTAG
INFO OR UNLOCK LOG
Z3X EasyJtag Software ver. 3.6.2.3
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63
CMD Pullup Level:2062 mV
CMD Active Level:2402 mV
Box IO Level:2800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
eMMC CID : 150100524436344D4201BD1ACEF61594
eMMC Date: 01/2018  Rev.0x1
eMMC NAME: RD64MB , S/N: 3172650742
eMMC NAME (HEX): 524436344D42
EMMC ROM1 (Main User Data)   Capacity: 29820 MB
EMMC RPMB is programmed and written 16167 times
Backup saved: RD64MB_3172650742_20200301_1954.extcsd
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Logical sector size: 0x200  bytes ,First/Last usable sector: 34,61071326
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 216432
Short Android info:
Security Path:  2019-05-05
Build Description:  S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20190509.095130 release-keys
Backup saved: BuildProp_20200301_1954.txt
Detected USERDATA USERDATA : 0x015B800000 (23.690GB)
 6E845C2C 2EFF97AF FFE33E90 1B1BA1EF 8F7B84B8 FB8F17C6 CE1643C0 38EA6FEF     n„\,.ÿ—¯ÿã>...¡ï.{„¸û..ÆÎ.CÀ8êoï;
 64E3678D 9FB2C7F9 CD5BC108 4D87B8FF 9226E9D1 8000A6C2 D2DD14C3 006942C9     dãg.Ÿ²ÇùÍ[Á.M‡¸ÿ’&éÑ..¦ÂÒÝ.Ã.iBÉ;
 0F328DFE 4DA97666 8C61E877 2B5C3491 88943987 EE9A7050 EDC8C897 62EADFB2     .2.þM©vfŒaèw+\4‘.”9‡îšpPíÈÈ—bêß²;
 FDBB5818 B4BFD0ED 9658B9D6 F7101B4A F8524861 D5EEFB56 A2E7227E 95D82617     ý»X.´¿Ðí–X¹Ö÷..JøRHaÕîûV¢ç"~•Ø&.;
 DCECAA0C EC25AD56 EAABB6EE 921B093E 93F976F7 36F8C8EE B79E697D 8DC8FD8B     Üìª.ì%*V꫶î’.    >“ùv÷6øÈî·ži}.Èý‹;
 C24BFDF9 A671A616 1EAA5949 CE5B4552 5B4246C7 45FC3E0E D01AA2AA C8C5423D     ÂKýù¦q¦..ªYIÎ[ER[BFÇEü>.Ð.¢ªÈÅB=;
 8B75C13F A8B1E87D 6AD918D4 F17E9820 54DCBAB9 E481A414 7D306CAE 07E188A1     ‹uÁ?¨±è}jÙ.Ôñ~. Tܺ¹ä.¤.}0l®.á.¡;
 1C8EAF03 910FA633 EEAAAE94 73B25057 86163EAE 6FC0A1E0 AA1A509F 72CB6AAA     .Ž¯.‘.¦3”s²PW†.>®oÀ¡àª.PŸrËjª;
Done.
CMD Active Level:2547 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
EMMC ROM1 (Main User Data)   Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes
Writing Recovery Command to MISC (33)
Done.
Old 03-07-2020, 11:38   #171 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Thumbs up Oppo a1k cph1923 pattern unlock easy jtag
OPPO A1K CPH1923
PATTERN UNLOCK
EASY JTAG
INFO OR UNLOCK LOG
CMD Pullup Level:2052 mV
CMD Active Level:2970 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
eMMC CID : 150100514436334D4203781EDE2FC592
eMMC Date: 12/2018  Rev.0x3
eMMC NAME: QD63MB , S/N: 2015288879
eMMC NAME (HEX): 514436334D42
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 4441 times
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x02 , width 8bits  , Partition config [179]: 0x48.
Backup saved: QD63MB_2015288879_20200307_1514.extcsd
Disk identifier (GUID): 00000000-0000-0000-0000-000000000000
Detected LINUX(Android) SYSTEM : 0x0074800000 (4.687GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 302512
Short Android info:
Unable to read prop.plist , code : 2
Backup saved: BuildProp_20200307_1514.txt
Detected USERDATA USERDATA : 0x01BB800000 (22.132GB)
Done.
CMD Pullup Level:2041 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Formatting FRP...
Detected LINUX(Android) FRP : 0x000BE88000 (1.0MB) formatting...
Done.
Detected LINUX(Android) CACHE : 0x01A0800000 (432.0MB) , formatting...
Done.
Detected LINUX(Android) USERDATA : 0x01BB800000 (22.132GB) , formatting...
Done.
Done.
Done.
Old 03-08-2020, 11:10   #172 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
Oppo realme 2 password unlock done very safe
Z3X EasyJtag Software ver. 3.6.1.9
Box S/N: 0500D01E3BC5A469, ,FW Ver.: 01.63
CMD Pullup Level:2021 mV
CMD Active Level:2340 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
eMMC CID : 90014A484347386134A266667256754E
eMMC CSD : D02701328F5903FFFFFFFFEF8A400026
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 07/2018  Rev.0xA2
eMMC NAME: HCG8a4 , S/N: 1717989974
eMMC NAME (HEX): 484347386134
EMMC ROM1 (Main User Data)   Capacity: 59640 MB
EMMC RPMB is programmed and written 44965 times
Backup saved: HCG8a4_1717989974_20200308_1606.extcsd
Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB
Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB
Logical sector size: 0x200  bytes ,First/Last usable sector: 34,122142686
Build Description:  S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20181017.230706 release-keys
Detected USERDATA USERDATA : 0x015B800000 (52.811GB)
Done.
CMD Pullup Level:2031 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
EMMC ROM1 (Main User Data)   Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes
Done.
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Backup saved: HCG8a4_1717989974_20200308_1610.extcsd
Done.
Old 03-09-2020, 08:18   #173 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 940
OPPO F11 pattern lock done
Old 03-10-2020, 13:04   #174 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
Oppo cph1901 oppo a7 password unlock done
CMD Pullup Level:1206 mV
CMD Active Level:2320 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
eMMC CID : 90014A484347386134A469EA893B9578
eMMC Date: 09/2018  Rev.0xA4
eMMC NAME: HCG8a4 , S/N: 1776978235
EMMC RPMB is programmed and written 119037 times
Backup saved: HCG8a4_1776978235_20200310_1253.extcsd
------ Detected 63 partitions ------
P0 (OPPODYCNVBK) [0x5000 0xa00000] Size: 10.0MB
P1 (OPPOSTANVBK) [0xa05000 0xa00000] Size: 10.0MB
P2 (MODEMST1) [0x1405000 0x180000] Size: 1.500MB
P3 (MODEMST2) [0x1585000 0x180000] Size: 1.500MB
P4 (PERSIST) [0x1705000 0x2000000] Size: 32.0MB
P5 (OPPORESERVE1) [0x3705000 0x800000] Size: 8.0MB
P6 (OPPORESERVE2) [0x3f05000 0x4000000] Size: 64.0MB
P7 (FSC) [0x7f05000 0x400] Size: 1.0KB
P8 (SSD) [0x7f06000 0x2000] Size: 8.0KB
P9 (SBL1) [0x7f08000 0x80000] Size: 512.0KB
P10 (RPM) [0x7f88000 0x80000] Size: 512.0KB
P11 (TZ) [0x8008000 0x200000] Size: 2.0MB
P12 (DEVCFG) [0x8208000 0x40000] Size: 256.0KB
P13 (SBL1BAK) [0x8248000 0x80000] Size: 512.0KB
P14 (RPMBAK) [0x82c8000 0x80000] Size: 512.0KB
P15 (TZBAK) [0x8348000 0x200000] Size: 2.0MB
P16 (DEVCFGBAK) [0x8548000 0x40000] Size: 256.0KB
P17 (DSP) [0x8588000 0x1000000] Size: 16.0MB
P18 (DDR) [0x9800000 0x8000] Size: 32.0KB
P19 (FSG) [0x9808000 0x180000] Size: 1.500MB
P20 (SEC) [0x9988000 0x4000] Size: 16.0KB
P21 (ABOOT) [0x998c000 0x100000] Size: 1.0MB
P22 (ABOOTBAK) [0x9a8c000 0x100000] Size: 1.0MB
P23 (MODEM) [0x9b8c000 0x8000000] Size: 128.0MB
P24 (DTBO) [0x11b8c000 0x800000] Size: 8.0MB
P25 (VBMETA) [0x1238c000 0x10000] Size: 64.0KB
P26 (BOOT) [0x1239c000 0x4000000] Size: 64.0MB
P27 (RECOVERY) [0x1639c000 0x4000000] Size: 64.0MB
P28 (DEVINFO) [0x1a39c000 0x100000] Size: 1.0MB
P29 (SPLASH) [0x1a800000 0xb00000] Size: 11.0MB
P30 (LOGO) [0x1b300000 0x2000000] Size: 32.0MB
P31 (DRIVER) [0x1d300000 0x2000000] Size: 32.0MB
P32 (CACHE) [0x1f300000 0x10000000] Size: 256.0MB
P33 (MISC) [0x2f300000 0x100000] Size: 1.0MB
P34 (KEYSTORE) [0x2f400000 0x80000] Size: 512.0KB
P35 (CONFIG) [0x2f480000 0x8000] Size: 32.0KB
P36 (OEM) [0x2f488000 0x100000] Size: 1.0MB
P37 (LIMITS) [0x2f800000 0x8000] Size: 32.0KB
P38 (MOTA) [0x30000000 0x80000] Size: 512.0KB
P39 (DIP) [0x30080000 0x100000] Size: 1.0MB
P40 (MDTP) [0x30180000 0x2000000] Size: 32.0MB
P41 (SYSCFG) [0x32180000 0x80000] Size: 512.0KB
P42 (MCFG) [0x32200000 0x400000] Size: 4.0MB
P43 (LKSECAPP) [0x32800000 0x20000] Size: 128.0KB
P44 (CMNLIB) [0x32820000 0x100000] Size: 1.0MB
P45 (CMNLIB64) [0x32920000 0x100000] Size: 1.0MB
P46 (KEYMASTER) [0x32a20000 0x100000] Size: 1.0MB
P47 (LKSECAPPBAK) [0x32b20000 0x20000] Size: 128.0KB
P48 (CMNLIBBAK) [0x32b40000 0x100000] Size: 1.0MB
P49 (CMNLIB64BAK) [0x32c40000 0x100000] Size: 1.0MB
P50 (KEYMASTERBAK) [0x32d40000 0x100000] Size: 1.0MB
P51 (APDP) [0x33000000 0x40000] Size: 256.0KB
P52 (MSADP) [0x33040000 0x40000] Size: 256.0KB
P53 (DPO) [0x33080000 0x2000] Size: 8.0KB
P54 (LOGDUMP) [0x33082000 0x4000000] Size: 64.0MB
P55 (VM-KYSTORE) [0x37082000 0x100000] Size: 1.0MB
P56 (VM-DATA) [0x37182000 0xa00000] Size: 10.0MB
P57 (HYP) [0x38000000 0x800000] Size: 8.0MB
P58 (VM-SYSTEM) [0x38800000 0x4000000] Size: 64.0MB
P59 (VM-LINUX) [0x3c800000 0x2000000] Size: 32.0MB
P60 (SYSTEM) [0x3e800000 0xfe000000] Size: 3.968GB
P61 (VENDOR) [0x13c800000 0x41f60000] Size: 1.30GB
P62 (USERDATA) [0x17e800000 0xd10ffbe00] Size: 52.264GB
Detected LINUX(Android) SYSTEM : 0x003E800000 (3.968GB)
Build Description:  msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20191231.163024 release-keys
Detected USERDATA USERDATA : 0x017E800000 (52.264GB)
Done.
Selected eMMC Interface
CMD Pullup Level:1216 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Done.
Old 03-10-2020, 13:07   #175 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
Another oppo a3s password unlock easily free
Loading eMMC GEN1 Firmware... IO: 1800 mV
CMD Pullup Level:1680 mV
CMD Active Level:1732 mV
Box IO Level:1800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
eMMC CID : 90014A68423861503E031FD11C28B58E
eMMC CSD : D02700328F5903FFFFFFFFEF8E400042
eMMC Date: 11/2018  Rev.0x3
eMMC NAME: hB8aP> , S/N:  533797928
eMMC NAME (HEX): 68423861503E
EMMC RPMB is programmed and written 95719 times
Backup saved: hB8aP>_ 533797928_20200310_1304.extcsd
------ Detected 65 partitions ------
P7 (RESERVE_EXP1) [0x7f05000 0x200000] Size: 2.0MB
P8 (RESERVE_EXP2) [0x8105000 0x200000] Size: 2.0MB
P9 (FSC) [0x8305000 0x400] Size: 1.0KB
P10 (SSD) [0x8306000 0x2000] Size: 8.0KB
P11 (SBL1) [0x8308000 0x80000] Size: 512.0KB
P12 (RPM) [0x8388000 0x80000] Size: 512.0KB
P13 (TZ) [0x8408000 0x200000] Size: 2.0MB
P14 (DEVCFG) [0x8608000 0x40000] Size: 256.0KB
P15 (SBL1BAK) [0x8648000 0x80000] Size: 512.0KB
P16 (RPMBAK) [0x86c8000 0x80000] Size: 512.0KB
P17 (TZBAK) [0x8748000 0x200000] Size: 2.0MB
P18 (DEVCFGBAK) [0x8948000 0x40000] Size: 256.0KB
P19 (DSP) [0x8988000 0x1000000] Size: 16.0MB
P20 (DDR) [0xa000000 0x8000] Size: 32.0KB
P21 (FSG) [0xa008000 0x180000] Size: 1.500MB
P22 (SEC) [0xa188000 0x4000] Size: 16.0KB
P23 (ABOOT) [0xa18c000 0x100000] Size: 1.0MB
P24 (ABOOTBAK) [0xa28c000 0x100000] Size: 1.0MB
P25 (MODEM) [0xa38c000 0x8000000] Size: 128.0MB
P26 (DTBO) [0x1238c000 0x800000] Size: 8.0MB
P27 (VBMETA) [0x12b8c000 0x10000] Size: 64.0KB
P28 (BOOT) [0x12b9c000 0x4000000] Size: 64.0MB
P29 (RECOVERY) [0x16b9c000 0x4000000] Size: 64.0MB
P30 (DEVINFO) [0x1ab9c000 0x100000] Size: 1.0MB
P31 (SPLASH) [0x1b000000 0xb00000] Size: 11.0MB
P32 (LOGO) [0x1bb00000 0x2000000] Size: 32.0MB
P33 (DRIVER) [0x1db00000 0x2000000] Size: 32.0MB
P34 (CACHE) [0x1fb00000 0x10000000] Size: 256.0MB
P35 (MISC) [0x2fb00000 0x100000] Size: 1.0MB
P36 (KEYSTORE) [0x2fc00000 0x80000] Size: 512.0KB
P37 (CONFIG) [0x2fc80000 0x8000] Size: 32.0KB
P38 (OEM) [0x2fc88000 0x100000] Size: 1.0MB
P39 (LIMITS) [0x30000000 0x8000] Size: 32.0KB
P40 (MOTA) [0x30800000 0x80000] Size: 512.0KB
P41 (DIP) [0x30880000 0x100000] Size: 1.0MB
P42 (MDTP) [0x30980000 0x2000000] Size: 32.0MB
P43 (SYSCFG) [0x32980000 0x80000] Size: 512.0KB
P44 (MCFG) [0x32a00000 0x400000] Size: 4.0MB
P45 (LKSECAPP) [0x33000000 0x20000] Size: 128.0KB
P46 (CMNLIB) [0x33020000 0x100000] Size: 1.0MB
P47 (CMNLIB64) [0x33120000 0x100000] Size: 1.0MB
P48 (KEYMASTER) [0x33220000 0x100000] Size: 1.0MB
P49 (LKSECAPPBAK) [0x33320000 0x20000] Size: 128.0KB
P50 (CMNLIBBAK) [0x33340000 0x100000] Size: 1.0MB
P51 (CMNLIB64BAK) [0x33440000 0x100000] Size: 1.0MB
P52 (KEYMASTERBAK) [0x33540000 0x100000] Size: 1.0MB
P53 (APDP) [0x33800000 0x40000] Size: 256.0KB
P54 (MSADP) [0x33840000 0x40000] Size: 256.0KB
P55 (DPO) [0x33880000 0x2000] Size: 8.0KB
P56 (LOGDUMP) [0x33882000 0x4000000] Size: 64.0MB
P57 (VM-KYSTORE) [0x37882000 0x100000] Size: 1.0MB
P58 (VM-DATA) [0x37982000 0xa00000] Size: 10.0MB
P59 (HYP) [0x38800000 0x800000] Size: 8.0MB
P60 (VM-SYSTEM) [0x39000000 0x4000000] Size: 64.0MB
P61 (VM-LINUX) [0x3d000000 0x2000000] Size: 32.0MB
P62 (SYSTEM) [0x3f000000 0xd6900000] Size: 3.352GB
P63 (VENDOR) [0x115900000 0x41f60000] Size: 1.30GB
P64 (USERDATA) [0x158000000 0x5efbfbe00] Size: 23.745GB
Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB)
Build Description:  msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20191225.101315 release-keys
Detected USERDATA USERDATA : 0x0158000000 (23.745GB)
Done.
CMD Pullup Level:1670 mV
CMD Active Level:1742 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Writing Recovery Command to MISC (35)
Done.
The Following User Says Thank You to kothamamun For This Useful Post:
Old 03-13-2020, 11:31   #176 (permalink)
faizafirdous's Avatar
Member: 1281866
Thanks Meter: 330
Arrow Realme c1 rmx1811 passcode and frp removed
Realme c1 passcode and frp removed with easy jitag plus
Loading eMMC GEN2 Firmware... IO: 2800 mV
Box S/N: 226B4FCD777309DB, ,FW Ver.: 02.50
CMD Pullup Level:2092 mV
CMD Active Level:2730 mV
CLK Rate:4000 kHz
Bus Width:1bit,SDR
eMMC CID : 150100514536334D4203B0C5E0455589
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Date: 05/2018  Rev.0x3
eMMC NAME: QE63MB , S/N: 2965758021
EMMC RPMB is programmed and written 52056 times
Backup saved: QE63MB_2965758021_20200312_2035.extcsd
------ Detected 64 partitions ------
P19 (FSG) [0x9808000 0x400000] Size: 4.0MB
P20 (SEC) [0x9c08000 0x4000] Size: 16.0KB
P21 (ABOOT) [0x9c0c000 0x100000] Size: 1.0MB
P22 (ABOOTBAK) [0x9d0c000 0x100000] Size: 1.0MB
P23 (MODEM) [0x9e0c000 0x8000000] Size: 128.0MB
P24 (DTBO) [0x11e0c000 0x800000] Size: 8.0MB
P25 (VBMETA) [0x1260c000 0x10000] Size: 64.0KB
P26 (BOOT) [0x1261c000 0x4000000] Size: 64.0MB
P27 (RECOVERY) [0x1661c000 0x4000000] Size: 64.0MB
P28 (DEVINFO) [0x1a61c000 0x100000] Size: 1.0MB
P36 (LOG) [0x2f488000 0x4000000] Size: 64.0MB
P37 (OEM) [0x33488000 0x100000] Size: 1.0MB
P38 (LIMITS) [0x33800000 0x8000] Size: 32.0KB
P39 (MOTA) [0x34000000 0x80000] Size: 512.0KB
P40 (DIP) [0x34080000 0x100000] Size: 1.0MB
P41 (MDTP) [0x34180000 0x2000000] Size: 32.0MB
P42 (SYSCFG) [0x36180000 0x80000] Size: 512.0KB
P43 (MCFG) [0x36200000 0x400000] Size: 4.0MB
P44 (LKSECAPP) [0x36800000 0x20000] Size: 128.0KB
P45 (CMNLIB) [0x36820000 0x100000] Size: 1.0MB
P46 (CMNLIB64) [0x36920000 0x100000] Size: 1.0MB
P47 (KEYMASTER) [0x36a20000 0x100000] Size: 1.0MB
P48 (LKSECAPPBAK) [0x36b20000 0x20000] Size: 128.0KB
P49 (CMNLIBBAK) [0x36b40000 0x100000] Size: 1.0MB
P50 (CMNLIB64BAK) [0x36c40000 0x100000] Size: 1.0MB
P51 (KEYMASTERBAK) [0x36d40000 0x100000] Size: 1.0MB
P52 (APDP) [0x37000000 0x40000] Size: 256.0KB
P53 (MSADP) [0x37040000 0x40000] Size: 256.0KB
P54 (DPO) [0x37080000 0x2000] Size: 8.0KB
P55 (LOGDUMP) [0x37082000 0x4000000] Size: 64.0MB
P56 (VM-KYSTORE) [0x3b082000 0x100000] Size: 1.0MB
P57 (VM-DATA) [0x3b182000 0xa00000] Size: 10.0MB
P58 (HYP) [0x3c000000 0x800000] Size: 8.0MB
P59 (VM-SYSTEM) [0x3c800000 0x4000000] Size: 64.0MB
P60 (VM-LINUX) [0x40800000 0x2000000] Size: 32.0MB
P61 (SYSTEM) [0x42800000 0xd6900000] Size: 3.352GB
P62 (VENDOR) [0x119100000 0x41f60000] Size: 1.30GB
P63 (USERDATA) [0x15b800000 0x2485fbe00] Size: 9.129GB
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 216432
Short Android info:
Backup saved: BuildProp_20200312_2035.txt
Build Description:  S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20190516.094149 release-keys
 A5065328 48BF7B90 C2BB2D6C 9758A237 B8C0F3CD 08BC4D8B B63B8F75 5F2CB4E3     ¥.S(H¿{.»-l—X¢7¸ÀóÍ.¼M‹¶;.u_,´ã;
 A60E49FA CC559F90 1E217D6B FFEBBB0A 469200E0 DA713A75 29FC15B7 8FF50F9E     ¦.IúÌUŸ..!}kÿë».F’.àÚq:u)ü.·.õ.ž;
 21A21853 F507D22B 44421E7B 5CE8D85C 77B042EC B1A4BCB7 C37419A5 D0B50878     !¢.Sõ.Ò+DB.{\èØ\w°B챤¼·Ãt.¥Ðµ.x;
 DBDE1BE8 9247B2D1 5C603781 BFD559E1 D76B5BDC D8179547 38FECDC4 A6412F46     ÛÞ.è’G²Ñ\`7.¿ÕYá×k[ÜØ.•G8þÍĦA/F;
 87E2C30A C6201380 9980BFFC DE997414 0F58A002 A800EAE3 8A2B40EF 043BE108     ‡âÃ.Æ ....¿üÞ.t..X .¨.êãŠ+@ï.;á.;
 062AB34D 3D975BEE 6742AE05 3D8FC113 813719F8 B2B2CE16 720D5511 4111CEB1     .*³M=—[îgB®.=.Á..7.ø²²Î.r.U.A.α;
 BC3C9C4B 89C3932C 1B929978 D41E6286 A6C2A727 D450800A C8CCDC40 AE85BED7     ¼<œK‰Ã“,.’.xÔ.b†¦Â§'ÔP..ÈÌÜ@®…¾×;
 C1D90E46 2925B5C5 03975ECC 45545364 5ACF6E05 97AFE443 148059CF ACBA5B4E     ÁÙ.F)%µÅ.—^ÌETSdZÏn.—¯äC..YϬº[N;
Done.
Checking security ...
CMD Pullup Level:2094 mV
CMD Active Level:2731 mV
CLK Rate:4000 kHz
Bus Width:1bit,SDR
Formatting FRP...
Done.
Done.
Done.
Done.
Done.
Old 03-24-2020, 07:56   #177 (permalink)
Momin_Telecom's Avatar
Member: 1478271
Sonork: 100.1608386
Thanks Meter: 1,806
Realme 3 pro RMX1851 Unlock done
CMD Pullup Level:2108 mV
CMD Active Level:2552 mV
CLK Rate:18000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
eMMC CID : 90014A68433861503E033F1434B76655
eMMC CSD : D02700328F5903FFFFFFFFEF8E400043
eMMC Date: 06/2019  Rev.0x3
eMMC NAME: hC8aP> , S/N: 1058288823
eMMC NAME (HEX): 68433861503E
EMMC RPMB is programmed and written 5887 times
Backup saved: hC8aP>_1058288823_20200324_1213.extcsd
Disk identifier (GUID): 3534BCDA-F9EC-447C-8F22-ADD7295733A4
Detected LINUX(Android) SYSTEM : 0x0053800000 (5.195GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 335216
Short Android info:
Backup saved: BuildProp_20200324_1213.txt
Detected USERDATA USERDATA : 0x0214A20000 (49.918GB)
Done.
Box S/N: 9028BF1A68474000, ,FW Ver.: 02.50
CMD Pullup Level:2105 mV
CMD Active Level:2628 mV
CLK Rate:18000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Writing Recovery Command to MISC (43)
mmc_write_blocks(0x29822000 , 1000 ), Failed: CMD Timeout Error
Done.
CMD Pullup Level:2104 mV
CMD Active Level:2553 mV
CLK Rate:18000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
CMD Active Level:2626 mV
CLK Rate:18000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Formatting FRP...
Detected LINUX(Android) FRP : 0x00299D2000 (512.0KB) formatting...
Done.
Detected LINUX(Android) CACHE : 0x0043800000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) USERDATA : 0x0214A20000 (49.918GB) , formatting...
Done.
Done.
Done.
Old 04-23-2020, 05:45   #178 (permalink)
nagesss's Avatar
Member: 2306223
Sonork: 1660968:1234
Thanks Meter: 117
Oppo a3s pin code remove by easy jtag old box
Oppo Reset option only reset phone no frp clear...
Again with frp clear option all job done...pin code and frp...
Sent from my SM-A305F using Tapatalk
Old 04-23-2020, 08:22   #179 (permalink)
Member: 575256
Thanks Meter: 34
OPPO A3S pin pattern
OPPO A3S Pin - Pattern By Easyjtag, No data loss. 1. Select a vendor 2. Click the emmc tab 3. Click Anvanced 4. Click Reset OPPO Previously you have to do ISP jumper first, guys, follow the photo, OK, after that, turn it on immediately, done without missing the data. The loading takes about 15 minutes, please wait patientlyOPPO A3S Pin - Pattern By Easyjtag, No data loss. 1. Select a vendor 2. Click the emmc tab 3. Click Anvanced 4. Click Reset OPPO Previously you have to do ISP jumper first, guys, follow the photo, OK, after that, turn it on immediately, done without missing the data. The loading takes about 15 minutes, please wait patiently
Old 05-02-2020, 02:11   #180 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
Originally Posted by 4star View Post
REALME RMX1811 USER LOCK DONE WITHOUT DATA LOSE
I have reset pass code by click clear pin/GST/Pass now my phone hang on logo only .Pls hlep me
Page generated in 0.46039 seconds with 10 queries
