Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 07-04-2019, 14:47   #31 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,523
Smile
Originally Posted by vnsun View Post
help me..how to Recover from Qlcm Mode ?
Originally Posted by RAJESH.GN1 View Post
Will u plse help me i also facing a problem
thanks but still QLC mode
Just Short clk Resistance
don't do any wipe or format operation just do as below
Clear PIN/GST/PASS
Android FRp Clear
Or
Reset OPPO
These options are enough for Pin Pattern frp
The Following 4 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 07-04-2019, 14:53   #32 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 1,708
1853 or 1803 ???
i have a a3s phone but pinout not match ??
i need oppo a3s cph1853 pinout .
Old 07-04-2019, 15:06   #33 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 1,708
this pinout not match with a3s cph1853
Old 07-05-2019, 03:51   #34 (permalink)
umar342's Avatar
Member: 1246696
Sonork: 100.1681950
Thanks Meter: 56
OPPO a3a unlock without data lose
]https://www.youtube.com/watch?v=1hCn02uRmjQ&t=1s
Old 07-05-2019, 05:14   #35 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 1,708
DONE WITH THIS PINOUT
EasyJtag Suite Classic ver.: 3.6.1.9 / wxWidgets 3.1.2-W-U started.
OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights OK
Android Explorer ver:1.0.0.13
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
eMMC Odin ver:1.0.0.6
QUALCOMM Direct ver:1.0.6671.7138
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 3.0.1.0, are OK
Z3X Card Serial : AAAA-6B50 , ver: 22
Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Found 2 serial devices
COM1 ACPI\PNP0501 Communications Port (COM1)
COM39 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Control Port (COM39)
Selected pinout: EasyJTAG GEN1 ISP Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.6.1.9
Loading eMMC GEN1 Firmware... IO: 3300 mV
Box S/N: 0900301095CE53A5, ,FW Ver.: 01.63
CMD Pullup Level:2031 mV
CMD Active Level:2495 mV
Box IO Level:3300 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 150100514536334D4204EF97E48026A0
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 02/2019 Rev.0x4
eMMC NAME: QE63MB , S/N: 4019709056
eMMC NAME (HEX): 514536334D42
IC Name: Samsung , KMQE60013M-B318/16GB @BGA221
EMMC ROM1 (Main User Data) Capacity: 14910 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 7045 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QE63MB_4019709056_20190705_0953.extcsd
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB
Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646
Partition info successfully found
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB)
Build ID: OPM1.171019.026
Release Base ID: 8.1.0
Architecture ABI: arm64-v8a
Device manufacturer: OPPO
Build Description: S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20190315.232714 release-keys
Detected USERDATA USERDATA : 0x015B800000 (9.129GB)
Unable to mount USERDATA , code : 95
Done.
CMD Pullup Level:2041 mV
CMD Active Level:2629 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes
Writing Recovery Command to MISC (33)
Done.
THANKS EASY Jtag team
The Following 5 Users Say Thank You to pintu_das For This Useful Post:
Old 07-05-2019, 05:33   #36 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 1,708
Thumbs up OPPO A3s (CPH1853) PATTERN REMOVE DONE WITH GREAT EASY JTAG BOX
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Done.
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Done.
Thanks Easy Jtag team
The Following User Says Thank You to pintu_das For This Useful Post:
Old 07-05-2019, 05:48   #37 (permalink)
umar342's Avatar
Member: 1246696
Sonork: 100.1681950
Thanks Meter: 56
Old 07-05-2019, 06:08   #38 (permalink)
Digital EDGE's Avatar
Member: 1240161
Thanks Meter: 100
Are you using an Old Box?
The Following 2 Users Say Thank You to Digital EDGE For This Useful Post:
Old 07-05-2019, 09:41   #39 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 1,708
yes brother it's my old box .........
Old 07-05-2019, 10:36   #40 (permalink)
VC_INDIA's Avatar
Member: 1236722
Sonork: 100.1601546
Thanks Meter: 3,529
1853 or 1803 ???
ITs CPH1803 bro......
The Following 2 Users Say Thank You to VC_INDIA For This Useful Post:
Old 07-05-2019, 12:51   #41 (permalink)
4star's Avatar
Member: 1596162
Sonork: 100.1616391
Thanks Meter: 96
Originally Posted by akash48 View Post
sir where is setup link
https://groundslife.com/FNtVX
Old 07-05-2019, 16:57   #42 (permalink)
umar342's Avatar
Member: 1246696
Sonork: 100.1681950
Thanks Meter: 56
i done with old box
The Following 2 Users Say Thank You to umar342 For This Useful Post:
Old 07-06-2019, 14:06   #43 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 1,708
now one more unlock done
model A3s (CPH1803) WITH THIS ISP
CMD Pullup Level:2887 mV
CMD Active Level:3124 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
eMMC CID : 150100514536334D4203ADA4E08085A2
eMMC Date: 08/2018 Rev.0x3
eMMC NAME: QE63MB , S/N: 2913263744
EMMC RPMB is programmed and written 72558 times
Backup saved: QE63MB_2913263744_20190706_1829.extcsd
Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB)
Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20190323.213841 release-keys
Detected USERDATA USERDATA : 0x0158000000 (9.184GB)
Done.
CMD Pullup Level:2959 mV
CMD Active Level:3165 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Writing Recovery Command to MISC (35)
Done.
The Following 4 Users Say Thank You to pintu_das For This Useful Post:
Old 07-07-2019, 16:45   #44 (permalink)
VC_INDIA's Avatar
Member: 1236722
Sonork: 100.1601546
Thanks Meter: 3,529
Oppo A1k CPH1923 UNlock Done By Easy Jtag
Wipe
FRP
Regard
VC_INDIA
The Following 5 Users Say Thank You to VC_INDIA For This Useful Post:
Old 07-08-2019, 05:53   #45 (permalink)
Member: 953334
Sonork: 100.1614005
Smile OPPO A3S CPH1853 One Click Reset Done
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 1818041DBF5EF1D5, ,FW Ver.: 01.63
CMD Pullup Level:2000 mV
CMD Active Level:2609 mV
Box IO Level:2800 mV
CLK Rate:7000 kHz
Bus Width:1bit,SDR
eMMC CID : 150100514536334D42069AF3682CC538
eMMC Date: 12/2018  Rev.0x6
eMMC NAME: QE63MB , S/N: 2599643180
EMMC RPMB is programmed and written 1453 times
Backup saved: QE63MB_2599643180_20190708_0940.extcsd
Card Supported Command sets [S_CMD_SET: 0x01]
HPI Features [HPI_FEATURE: 0x01]:
implementation based on CMD13
Background operations support [BKOPS_SUPPORT: 0x01]
Max Packet Read Cmd [MAX_PACKED_READS: 0x3f]
Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f]
Data TAG support [DATA_TAG_SUPPORT: 0x01]
Data TAG Unit Size [TAG_UNIT_SIZE: 0x02]
Tag Resources Size [TAG_RES_SIZE: 0x00]
Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05]
Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07]
Extended partition attribute support [EXT_SUPPORT: 0x03]
Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a]
Power off notification [POWER_OFF_LONG_TIME: 0x3c]
Cache Size [CACHE_SIZE] is 65536 KiB
------------------------- eMMC v5+ -------------------------
Supported modes [SUPPORTED_MODES: 0x03]
FFU features [FFU_FEATURES: 0x00]
Operation codes timeout [OPERATION_CODE_TIMEOUT: 0x00]
FFU Argument [FFU_ARG: 0xc7810000]
Number of FW sectors correctly programmed[NUM_OF_FW_SECT_CORR_PROG: 0]
Vendor proprietary health report:
[VENDOR_PROPRIETARY_HEALTH_REPORT[301]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[300]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[299]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[298]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[297]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[296]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[295]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[294]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[293]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[292]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[291]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[290]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[289]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[288]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[287]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[286]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[285]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[284]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[283]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[282]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[281]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[280]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[279]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[278]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[277]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[276]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[275]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[274]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[273]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[272]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[271]]:0x00
[VENDOR_PROPRIETARY_HEALTH_REPORT[270]]:0x00
_(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_B: 0x01]
 i.e. 0% - 10% device life time used
_(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_A: 0x01]
Pre EOL information [PRE_EOL_INFO: 0x01]
 i.e. Normal
Optimal read size [OPTIMAL_READ_SIZE: 0x00]
Optimal write size [OPTIMAL_WRITE_SIZE: 0x08]
Optimal trim unit size [OPTIMAL_TRIM_UNIT_SIZE: 0x01]
Device version [DEVICE_VERSION: 0x00 - 0x00]
Firmware version:
[FIRMWARE_VERSION[261]]: 0x00
[FIRMWARE_VERSION[260]]: 0x00
[FIRMWARE_VERSION[259]]: 0x00
[FIRMWARE_VERSION[258]]: 0x00
[FIRMWARE_VERSION[257]]: 0x00
[FIRMWARE_VERSION[256]]: 0x00
[FIRMWARE_VERSION[255]]: 0x00
[FIRMWARE_VERSION[254]]: 0x06
Power class for 200MHz, DDR at VCC= 3.6V [PWR_CL_DDR_200_360: 0x00]
Background operations status [BKOPS_STATUS: 0x00]
1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x1e]
Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00]
Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00]
Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00]
Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00]
Minimum Performance for 8bit at 52MHz in DDR mode:
 [MIN_PERF_DDR_W_8_52: 0x00]
 [MIN_PERF_DDR_R_8_52: 0x00]
TRIM Multiplier [TRIM_MULT: 0x02]
Secure Feature support [SEC_FEATURE_SUPPORT: 0x55]
Boot Information [BOOT_INFO: 0x07]
 Device supports alternative boot method
 Device supports dual data rate during boot
 Device supports high speed timing during boot
Boot partition size [BOOT_SIZE_MULTI: 0x20]
Access size [ACC_SIZE: 0x07]
High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01]
High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01]
Reliable write sector count [REL_WR_SEC_C: 0x01]
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10]
Sleep current (VCC) [S_C_VCC: 0x07]
Sleep current (VCCQ) [S_C_VCCQ: 0x07]
Sleep/awake timeout [S_A_TIMEOUT: 0x11]
Sector Count [SEC_COUNT: 0x01d1f000]
Minimum Write Performance for 8bit:
 [MIN_PERF_W_8_52: 0x00]
 [MIN_PERF_R_8_52: 0x00]
 [MIN_PERF_W_8_26_4_52: 0x00]
 [MIN_PERF_R_8_26_4_52: 0x00]
Minimum Write Performance for 4bit:
 [MIN_PERF_W_4_26: 0x00]
 [MIN_PERF_R_4_26: 0x00]
Power classes registers:
 [PWR_CL_26_360: 0x00]
 [PWR_CL_52_360: 0x00]
 [PWR_CL_26_195: 0x00]
 [PWR_CL_52_195: 0x00]
Partition switching timing [PARTITION_SWITCH_TIME: 0x02]
Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x0a]
I/O Driver Strength [DRIVER_STRENGTH: 0x1f]
Card Type [CARD_TYPE: 0x57]
CSD structure version [CSD_STRUCTURE: 0x02]
Command set [CMD_SET: 0x00]
Command set revision [CMD_SET_REV: 0x00]
Power class [POWER_CLASS: 0x00]
High-speed interface timing [HS_TIMING: 0x00]
Erased memory content [ERASED_MEM_CONT: 0x00]
Boot configuration bytes [PARTITION_CONFIG: 0x38]
 No access to boot partition
Boot config protection [BOOT_CONFIG_PROT: 0x00]
Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00]
High-density erase group definition [ERASE_GROUP_DEF: 0x00]
Boot write protection status registers [BOOT_WP_STATUS]: 0x00
Boot Area Write protection [BOOT_WP]: 0x00
Power ReadOnly locking: possible
Permanent ReadOnly locking: possible
Read Only lock status: not locked
User area write protection register [USER_WP]: 0x00
FW configuration [FW_CONFIG]: 0x00
RPMB Size [RPMB_SIZE_MULT]: 0x20
Write reliability setting register [WR_REL_SET]: 0x1f
Write reliability parameter register [WR_REL_PARAM]: 0x14
Enable background operations handshake [BKOPS_EN]: 0x02
HPI management [HPI_MGMT]: 0x00
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0003a3
Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00
General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000
 [GP_SIZE_MULT_3]: 0x000000
 [GP_SIZE_MULT_2]: 0x000000
 [GP_SIZE_MULT_1]: 0x000000
Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000
Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000
Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00
Periodic Wake-up [PERIODIC_WAKEUP]: 0x00
Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01
Native sector size [NATIVE_SECTOR_SIZE]: 0x00
Sector size emulation [USE_NATIVE_SECTOR]: 0x00
Sector size [DATA_SECTOR_SIZE]: 0x00
1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00
Class 6 commands control [CLASS_6_CTRL]: 0x00
Number of addressed group to be released[DYNCAP_NEEDED]: 0x00
Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000
Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000
Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000
Packed command status [PACKED_COMMAND_STATUS]: 0x00
Packed command failure index [PACKED_FAILURE_INDEX]: 0x00
Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00
Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00
------ Detected 64 partitions ------
P0 (OPPODYCNVBK) [0x5000 0xa00000] Size: 10.0MB
P1 (OPPOSTANVBK) [0xa05000 0xa00000] Size: 10.0MB
P2 (MODEMST1) [0x1405000 0x180000] Size: 1.500MB
P3 (MODEMST2) [0x1585000 0x180000] Size: 1.500MB
P4 (PERSIST) [0x1705000 0x2000000] Size: 32.0MB
P5 (OPPORESERVE1) [0x3705000 0x800000] Size: 8.0MB
P6 (OPPORESERVE2) [0x3f05000 0x4000000] Size: 64.0MB
P7 (FSC) [0x7f05000 0x400] Size: 1.0KB
P8 (SSD) [0x7f06000 0x2000] Size: 8.0KB
P9 (SBL1) [0x7f08000 0x80000] Size: 512.0KB
P10 (RPM) [0x7f88000 0x80000] Size: 512.0KB
P11 (TZ) [0x8008000 0x200000] Size: 2.0MB
P12 (DEVCFG) [0x8208000 0x40000] Size: 256.0KB
P13 (SBL1BAK) [0x8248000 0x80000] Size: 512.0KB
P14 (RPMBAK) [0x82c8000 0x80000] Size: 512.0KB
P15 (TZBAK) [0x8348000 0x200000] Size: 2.0MB
P16 (DEVCFGBAK) [0x8548000 0x40000] Size: 256.0KB
P17 (DSP) [0x8588000 0x1000000] Size: 16.0MB
P18 (DDR) [0x9800000 0x8000] Size: 32.0KB
P19 (FSG) [0x9808000 0x400000] Size: 4.0MB
P20 (SEC) [0x9c08000 0x4000] Size: 16.0KB
P21 (ABOOT) [0x9c0c000 0x100000] Size: 1.0MB
P22 (ABOOTBAK) [0x9d0c000 0x100000] Size: 1.0MB
P23 (MODEM) [0x9e0c000 0x8000000] Size: 128.0MB
P24 (DTBO) [0x11e0c000 0x800000] Size: 8.0MB
P25 (VBMETA) [0x1260c000 0x10000] Size: 64.0KB
P26 (BOOT) [0x1261c000 0x4000000] Size: 64.0MB
P27 (RECOVERY) [0x1661c000 0x4000000] Size: 64.0MB
P28 (DEVINFO) [0x1a61c000 0x100000] Size: 1.0MB
P29 (SPLASH) [0x1a800000 0xb00000] Size: 11.0MB
P30 (LOGO) [0x1b300000 0x2000000] Size: 32.0MB
P31 (DRIVER) [0x1d300000 0x2000000] Size: 32.0MB
P32 (CACHE) [0x1f300000 0x10000000] Size: 256.0MB
P33 (MISC) [0x2f300000 0x100000] Size: 1.0MB
P34 (KEYSTORE) [0x2f400000 0x80000] Size: 512.0KB
P35 (CONFIG) [0x2f480000 0x8000] Size: 32.0KB
P36 (LOG) [0x2f488000 0x4000000] Size: 64.0MB
P37 (OEM) [0x33488000 0x100000] Size: 1.0MB
P38 (LIMITS) [0x33800000 0x8000] Size: 32.0KB
P39 (MOTA) [0x34000000 0x80000] Size: 512.0KB
P40 (DIP) [0x34080000 0x100000] Size: 1.0MB
P41 (MDTP) [0x34180000 0x2000000] Size: 32.0MB
P42 (SYSCFG) [0x36180000 0x80000] Size: 512.0KB
P43 (MCFG) [0x36200000 0x400000] Size: 4.0MB
P44 (LKSECAPP) [0x36800000 0x20000] Size: 128.0KB
P45 (CMNLIB) [0x36820000 0x100000] Size: 1.0MB
P46 (CMNLIB64) [0x36920000 0x100000] Size: 1.0MB
P47 (KEYMASTER) [0x36a20000 0x100000] Size: 1.0MB
P48 (LKSECAPPBAK) [0x36b20000 0x20000] Size: 128.0KB
P49 (CMNLIBBAK) [0x36b40000 0x100000] Size: 1.0MB
P50 (CMNLIB64BAK) [0x36c40000 0x100000] Size: 1.0MB
P51 (KEYMASTERBAK) [0x36d40000 0x100000] Size: 1.0MB
P52 (APDP) [0x37000000 0x40000] Size: 256.0KB
P53 (MSADP) [0x37040000 0x40000] Size: 256.0KB
P54 (DPO) [0x37080000 0x2000] Size: 8.0KB
P55 (LOGDUMP) [0x37082000 0x4000000] Size: 64.0MB
P56 (VM-KYSTORE) [0x3b082000 0x100000] Size: 1.0MB
P57 (VM-DATA) [0x3b182000 0xa00000] Size: 10.0MB
P58 (HYP) [0x3c000000 0x800000] Size: 8.0MB
P59 (VM-SYSTEM) [0x3c800000 0x4000000] Size: 64.0MB
P60 (VM-LINUX) [0x40800000 0x2000000] Size: 32.0MB
P61 (SYSTEM) [0x42800000 0xd6900000] Size: 3.352GB
P62 (VENDOR) [0x119100000 0x41f60000] Size: 1.30GB
P63 (USERDATA) [0x15b800000 0x2485fbe00] Size: 9.129GB
Build Description:  S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20190509.095130 release-keys
Done.
Selected eMMC Interface
CMD Pullup Level:1990 mV
CLK Rate:7000 kHz
Bus Width:1bit,SDR
Done.
The Following 5 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Page generated in 0.26228 seconds with 8 queries
