Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 07-21-2019, 10:52   #61 (permalink)
royalnasim's Avatar
Member: 1037372
Thanks Meter: 483
Thumbs up Oppo a3s hang on logo and unlock done by easy jtag plus
OPPO A3S HANG ON LOGO AND UNLOCK DONE BY EASY JTAG PLUS
The Following User Says Thank You to royalnasim For This Useful Post:
Old 07-21-2019, 18:28   #62 (permalink)
Member: 1409573
Sonork: 100.1615416
Thanks Meter: 58
oppo a3s reset done
Old 07-21-2019, 18:35   #63 (permalink)
Member: 1409573
Sonork: 100.1615416
Thanks Meter: 58
Old 07-22-2019, 16:24   #64 (permalink)
Member: 1409573
Sonork: 100.1615416
Thanks Meter: 58
another one done
Old 07-23-2019, 18:59   #65 (permalink)
umar342's Avatar
Member: 1246696
Sonork: 100.1681950
Thanks Meter: 56
i have1 realme 2 set is dead via isp pinout i try on line flash oppo survise center but not flash set still dead set show full info when i cannect isp pinout dose any one khow what should i do
Old 07-25-2019, 12:56   #66 (permalink)
Member: 1095362
Thanks Meter: 55
Originally Posted by VC_INDIA View Post
Wipe
FRP
Regard
VC_INDIA
Bro,
Can u share pinout?
tried to search on google but not working.
where is gnd??
Old 07-25-2019, 13:17   #67 (permalink)
Member: 1095362
Thanks Meter: 55
Originally Posted by khanraheem143 View Post
Bro,
Can u share pinout?
where is gnd??
Z3X EasyJtag Software ver. 3.6.1.11
Loading eMMC GEN1 Firmware... IO: 3300 mV
Box S/N: 06009012EE2027F8, ,FW Ver.: 01.63
Warning: CMD Pullup Level (0 mV) too low , check cables etc.!
CMD Active Level:237 mV
Box IO Level:3300 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Can't init device, Reason: CMD CRC Error
Done.
CMD Pullup Level:2031 mV
CMD Active Level:2949 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Can't init device, Reason: CMD Timeout Error
Done.
CMD Active Level:3000 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
Old 07-27-2019, 18:01   #68 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 772
proof for thoes who say wire lenth must be 2 inch in order to detect emmc
Old 07-28-2019, 09:30   #69 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 1,708
Thumbs up Oppo A5 (CPH1809) unlock done
eMMC CID : 150100524436344D4201D4D5D49C554E
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 05/2018 Rev.0x1
eMMC NAME: RD64MB , S/N: 3570783388
eMMC NAME (HEX): 524436344D42
EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 3472 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Writing Recovery Command to MISC (33)
Done.
Old 07-28-2019, 12:28   #70 (permalink)
Member: 1128042
Sonork: 100.1666710
Thanks Meter: 124
OPPO CPH1901 A7 PATTERN UNLOCK DONE SUCCESS ,ONE CLICK WITH EASYJTAG PLUS
Old 07-31-2019, 12:06   #71 (permalink)
Member: 2353294
Thanks Meter: 3
oppo f11 pro cph1969 format frp done
Running:Format FRP Partition...
Z3X EasyJtag Software ver. 3.6.1.9
Loading eMMC GEN1 Firmware... IO: 1800 mV
FW Ver.: 01.63
CMD Pullup Level:1722 mV
CMD Active Level:1742 mV
Box IO Level:1800 mV
CLK Rate:14000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 90014A6844456150330360E5680F3686
eMMC CSD : D02700328F5903FFFFFFFFEF8E400042
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 03/2019 Rev.0x3
eMMC NAME: hDEaP3 , S/N: 1625647119
eMMC NAME (HEX): 684445615033
EMMC ROM1 (Main User Data) Capacity: 119280 MB , 0xE8F8000 pages , 0x1D1F000000 bytes
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 347 times
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48.
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: E8F8000 sectors 116.5 GiB
Soft (Partitioned) Disk/Image size: E8F7FBC sectors 116.5 GiB
Disk identifier (GUID): 00000000-0000-0000-0000-000000000000
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,244285406
Partition info successfully found
Formatting FRP...
Detected LINUX(Android) FRP : 0x000DE88000 (1.0MB) formatting...
Done.
Detected LINUX(Android) CACHE : 0x01D0800000 (432.0MB) , formatting...
Done.
Detected LINUX(Android) USERDATA : 0x01EB800000 (108.746GB) , formatting...
Done.
The Following User Says Thank You to nagisa_moe For This Useful Post:
Old 08-01-2019, 03:12   #72 (permalink)
inat's Avatar
Member: 149576
Thanks Meter: 56
oppo A7 (cph1903) password removed
Detected LINUX(Android) SYSTEM : 0x003E800000 (3.968GB)
Build ID: OPM1.171019.026
Release Base ID: 8.1.0
Architecture ABI: arm64-v8a
Device manufacturer: OPPO
Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20190711.000250 release-keys
Detected USERDATA USERDATA : 0x017E800000 (52.264GB)
Unable to mount USERDATA , code : 95
Done.
Checking security ...
Loading eMMC GEN2 Firmware... IO: 2800 mV
Box S/N: DBB477427EC2E4FA, ,FW Ver.: 02.44
CMD Pullup Level:2053 mV
CMD Active Level:2718 mV
Box IO Level:2800 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
eMMC CID : 1501005248363441420522C49A61C5D9
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Date: 12/2018 Rev.0x5
eMMC NAME: RH64AB , S/N: 583309921
eMMC NAME (HEX): 524836344142
EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes
EMMC RPMB is programmed and written 1098 times
Done.
Old 08-02-2019, 13:29   #73 (permalink)
Member: 2453200
Thanks Meter: 83
Oppo A1k Unlock Done With Easy Jtag
User lock
eMMC CID : 150100514436334D42034F34D81D16BD
eMMC Date: 01/2019 Rev.0x3
eMMC NAME: QD63MB , S/N: 1328863261
eMMC NAME (HEX): 514436334D42
EMMC RPMB is programmed and written 303 times
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326
------ Android information ------
Detected (Android Userdata) USERDATA : 0x01BB800000 (22.132GB)
Erasing...
Done.
Detected (Android Cache)) CACHE : 0x01A0800000 (432.0MB)
Erasing...
Done.
Done.
FRP Logs
Formatting FRP...
Detected LINUX(Android) FRP : 0x000BE88000 (1.0MB) formatting...
Done.
Detected LINUX(Android) CACHE : 0x01A0800000 (432.0MB) , formatting...
Done.
Detected LINUX(Android) USERDATA : 0x01BB800000 (22.132GB) , formatting...
Done.
Done.
Done.
Done Many A1k Without Any risk
Regard
Devil
The Following 3 Users Say Thank You to Resident_Evil For This Useful Post:
Old 08-04-2019, 08:59   #74 (permalink)
Member: 933096
Sonork: inocentedeti
Thanks Meter: 18
good job sir, clear and sound safe to remove FRP via TP
Old 08-04-2019, 11:56   #75 (permalink)
Member: 2860027
Sonork: 100.650600
Post easyjtag plus
oppo a1k emmc pinout send bro
Page generated in 0.30278 seconds with 8 queries
