03-03-2014, 11:44 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Cambodia
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | P6200 after repair boot can't flash by Odin Code: Initialising: SAMSUNG GT-P6200 Config ver.:1.00 I/O Level set to : 2800 mV Box S/N: xxxxxxxxxxxxx ,FW Ver.: 01.48 Connecting to Target... JTAG device: S5PC210 CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4 CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9 Halting CPU... Init target ... Starting target communication... Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x00010015 Name : MAG4FA Size : 14.7 G , (30777344) Blocks EMMC #1 : ID : 0x00010000 Name : MAG4FA Size : 512.0 K , (1024) Blocks eMMC flash device(s) found, Device ID : 0x00150001 NAND Writing GPT... eMMC Write OK! Elapsed time: 54.163296s (75.623 KiB/s) NAND Writing SBL1... eMMC Write OK! Elapsed time: 26.925648s (47.538 KiB/s) NAND Writing SBL2... eMMC Write OK! Elapsed time: 13.650024s (93.773 KiB/s) NAND Writing PARAM... eMMC Write OK! Elapsed time: 95.986969s (85.345 KiB/s) NAND Writing ROM2... eMMC Write OK! Elapsed time: 68.764923s (7.446 KiB/s) All Done. How can i fix it?pls help me thanks |
03-03-2014, 12:22 | #2 (permalink) |
Freak Poster Join Date: Jul 2011 Location: Gsm college
Member: 1610262 Status: Offline Sonork: 100.1608508 Thanks Meter: 44 | Try different firmware if same extract your firmware with 7zip delet data.img and save reflash phone with out data.img report your job here if done or not |
The Following User Says Thank You to .::PHONECRAKER::. For This Useful Post: |
03-04-2014, 02:11 | #3 (permalink) | |
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | Quote:
<ID:0/059> Odin v.3 engine (ID:59).. <ID:0/059> File analysis.. <ID:0/059> SetupConnection.. <ID:0/059> Initialzation.. <ID:0/059> Get PIT for mapping.. <ID:0/059> Firmware update start.. <ID:0/059> boot.bin <ID:0/059> NAND Write Start!! <ID:0/059> Sbl.bin <ID:0/059> param.lfs <ID:0/059> boot.bin <ID:0/059> <ID:0/059> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) pls help me,thanks | |
