Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 06-11-2019, 11:01   #1 (permalink)
Crazy Poster
Member: 971036
p8 lite ale-l21 explorer problem
Hello friend I am trying to recover data from p8 lite ale-l21 but I have problem to extract data from explorer tab. This is my log:
eMMC_tool Suite ver. 1.5.3.0 (release date: 28.12.2018)
Microsoft Windows 7 (64 bit) build 7601 (6.1.7600.16385)
Looking for EasyJTAG box...
EasyJTAG API ver. 2201
EasyJTAG Box Serial = 07DECE1077452591
Card Serial = AAB422F2
EasyJTAG Box Firmware = 2.38
Changelog:
28.12.2018 (ver 1.5.3.0)
Fix: Bugs that have been found through your crash report
Fix: Scatter file processing (MTK)
Fix: Contact Extractor
Fix: Preloader parser
Fix: FAT partitions mounting
Fix: Minor interface changes
Add: Explorer: Work with Qualcomm HS-USB QDLoader 9008 interface
Add: Reset FRP via Qualcomm HS-USB QDLoader 9008 interface (General - Advanced - Remove FRP)
Add: Remove Android locks via Qualcomm HS-USB QDLoader 9008 interface (General - Advanced - Remove Android Locks)
Add: Auto/Manual loaders select for Qualcom HS-USB QDLoader 9008 interface
Add: Samsung firmware lz4 unpack support (Write by vendor - Samsung)
Add: Import from cm2qlm xml backups (Write by vendor - Qualcomm)
Add: Unpack Bootloader.img archive from Motorola firmware files
Add: Import GP partition parameters from ExtCSD backups (General - eMMC HW Partitions)
Add: Import Boot and RPMB sizes from ExtCSD backups (General - eMMC HW Partitions)
Add: Allow to create a GP with zero size (fix "Error writing at address: 000000000000", fine for Samsung eMMC, and may be destroy SanDisk and other eMMC)
Add: Explorer: Pin and Password decoding (only English and Russian letters)
Setting interface to EasyJtag2/E-Socket
Setting bus width to 8 Bit
Setting frequence to 42 Mhz
EMMC Device Information :
EMMC CID: 150100523331314D420641D8CADC23E7
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufacture : SAMSUNG , EMMC NAME: R311MB , HEX: 523331314D42 , S/N: 41D8CADC , rev. 0x06
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2016
EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x02 , width 8bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: R311MB_41D8CADC_20190611_115611.extcsd
EMMC Init completed.
Operation: Reading from eMMC...
Reading from: ROM1 , start: 0x000000000000 , size: 0x000000020000
Output file: C:\Program Files\Z3X\EASYJTAGPLUS\EMMC_NONAME_ROM1_0000000000 00_000000020000.bin
eMMC switching to ROM1
Reading partition...
Done reading partition. Read speed: 3106,08 Kb/s
All done time: [00:01:48:599]
Backup saved: R311MB_41D8CADC_20190611_115813.extcsd
Operation: File Explorer...
Scan from: R311MB
Vendor: Qualcomm
Searching GPT ...
GPT header is not found
Searching MBR ...
MBR header is not found
Partition table not found
Scan done
What can I do to solve the problem. Tnx
Old 06-11-2019, 15:40   #2 (permalink)
Member: 13148
Thanks Meter: 1,034
Partition Table not found.
You need write only GPT from worked phone (first 128KB of ROM1)
or use forenstic analyze from eMMC File Manager (EasyJTAG Box Addon "Emmc File Manager" addon Released.)
Old 06-11-2019, 16:01   #3 (permalink)
Crazy Poster
Member: 971036
Ok I will try addon. Where can I download the program? Thx
Old 06-11-2019, 16:19   #4 (permalink)
Crazy Poster
Member: 971036
Generation: GPT [QC/SAMS]
Box Voltage set to: [2800] mV
Scanner Thread Created.
Setup HiPower CLK: [OFF]
Connecting To EasyJtag Box: [2800mV/42MHz/8BIT]
EasyJtag Box Found! Result: [0/OK]
EasyJtag S/N: [07DECE1077452591]
EasyJtag Firm: [2.38]
Box Bus Width = 8 BIT
Box Hardware = EasyJtag 2nd Generation
Search EMMC Chip...
Testing Box Interface
PIN CLK : 1671 mV - Pin OK
PIN CMD : 1679 mV - Pin OK
PIN DAT0: 1679 mV - Pin OK
PIN DAT1: 1676 mV - Pin OK
PIN DAT2: 1680 mV - Pin OK
PIN DAT3: 1679 mV - Pin OK
PIN DAT4: 1679 mV - Pin OK
PIN DAT5: 1678 mV - Pin OK
PIN DAT6: 1680 mV - Pin OK
PIN DAT7: 1677 mV - Pin OK
Test End
EMMC Chip Found! [0/OK]
EMMC CID: [150100523331314D420641D8CADC23E7]
EMMC CSD: [D02701320F5903FFF6DBFFEF8E406069]
EMMC VENDOR: [SAMSUNG]
EMMC NAME: [R311MB]
EMMC ROM1 Size: [30535680 Block(s)/14910 MB]
EMMC ROM2/3 Size: [8192 Block(s)/4096 KB]
EMMC RPMB Size: [8192 Block(s)/4096 KB]
Switch To ROM1 Part: [0/OK]
Scanning Data From EMMC. Please wait..
Error Reading Sector: [0], Count: [5], Err: [-3/R_DATA_TOUT_ERR]
Try again #1
Try again #2
Try again #3
Resetting EasyJtag Box...
Try again #1
Try again #2
Try again #3
Too Many Errors. Stopped. Err: [-3/R_DATA_TOUT_ERR]
Error While Reading. Exit. Code: [-3/R_DATA_TOUT_ERR]
Error While Scan Partitions. Scanner Shutdown..
Scanner Thread Terminated, Elapsed: [00:00:06:920]
Found 0 Partition(s)..
ERROR: Search Partitions Fail.
Check EMMC or Run Pool Test..
This is log of EMMC File manger program. What can I do?
Old 06-11-2019, 23:32   #5 (permalink)
Member: 13148
Thanks Meter: 1,034
You eMMC have 0 bad sector
Tr to read userdata area
Begin adress: 0x0000F7C00000
Lenght: 0x0002AC200000
Page generated in 0.22713 seconds with 7 queries
