03-21-2016, 18:29 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 48
Member: 58761 Status: Offline Thanks Meter: 5 | "partitioning not detected" when dumping emmc here the log: Z3X EasyJtag Software ver. 2.0.7.6 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0700F002DA19E094, ,FW Ver.: 01.52 CMD Pullup Level:1732 mV CMD Active Level:1804 mV HiPower™ mode is off! eMMC Device Information EMMC CID : 90014A4841473464040503A26D40A1F4 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 10/2014 Rev.0x5 EMMC NAME: HAG4d , S/N: 60976448 EMMC NAME (HEX): 48414734642000 EMMC ROM1 (Main User Data) Capacity: 15032 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 Backup saved: HAG4d _ 60976448_20160321_1831.extcsd Searching for partition tables... Partitioning not detected... Done. Z3X EasyJtag Software ver. 2.0.7.6 Skip loading eMMC Addon Firmware CMD Pullup Level:1732 mV CMD Active Level:1804 mV Reading 0x000100000000 bytes from 0x000000000000 ...ROM1 ( USER ROM) Output file :G:\EMMC_ROM1_HAG4d _ 60976448_00000000_100000000.bin After a few hours,I have a 4 GB file but diskinternals gives an error. Any hint? |
